Composite Bed
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Feb 5, 2022.
  1. Feb 5, 2022 at 7:58 AM
    WasAChevy
    WasAChevy [OP] New Member
    How are most people satisfied with the composite bed? Has anyone applied a bed liner in addition to the composite bed? Seems like stuff would slide.
  2. Feb 5, 2022 at 9:02 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    It’s slick when not sprayed. Looks like it’ll hold up just fine. I got the dealer to throw in a bed mat but I’ll be trying out the bedrug May xl when it comes out.
  3. Feb 5, 2022 at 9:56 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I’m happy with mine. It didn’t receive the factory bed liner but I don’t find it any more slick then my 2007 Tacoma bed. So far nothing has slid around but I would tie down something if I was worried about it.
  4. Feb 5, 2022 at 10:59 AM
    Dick Proenneke
    Dick Proenneke New Member
    Dick
    2022 Toyota Tundra Limited
    Tonneau, 3M, Tires
    The bed mat helps a lot.
    trazerr and kstateskier like this.
  5. Feb 5, 2022 at 11:55 AM
    CKM52
    CKM52 New Member
    IMG_20220205_134141.jpg I went ahead and had my bed sprayed. I was getting tired of listening to things smash into the sides with every turn. Very happy with the result.
    GODZILLA, 15whtrd, ryanwgregg and 2 others like this.
  6. Feb 5, 2022 at 12:03 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Never had a problem with a 14 Tacoma .. I for one like to easily slide stuff in/out and will tie down or use net for smaller stuff.
    Toyota1234 likes this.
  7. Feb 5, 2022 at 12:06 PM
    CKM52
    CKM52 New Member
    To clarify, I drive like an idiot around turns and on back roads. It may not be necessary for everyone.
    ja5er, GODZILLA, nuclear and 3 others like this.
  8. Feb 5, 2022 at 12:12 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I got the factory spray in liner on my 2022. Factory spray liner gets the tundra badge on back.
    rideandfly, ja5er, GODZILLA and 5 others like this.
  9. Feb 5, 2022 at 4:18 PM
    WasAChevy
    Cool! Didn't know that you can spray the composite with a traditional spray in liner. Very nice!
  10. Feb 5, 2022 at 4:20 PM
    WasAChevy
    Very nice! I have an allocation coming in next month and I didn't have the option to get the factory spray in.
    CKM52 likes this.
  11. Feb 5, 2022 at 4:26 PM
    t.friddy
    t.friddy New Member
    Charlotte, NC
    2019 Tundra SR5 DC
    Anyone know if they reinforced it at all in a way that limits bed spread from rtt or similar loads like Tacomas had issue with?
    Okierunner likes this.
  12. Feb 5, 2022 at 5:48 PM
    kmangino47
    kmangino47 New Member
    2022 limited TRD off-road
    waiting waiting waiting to take delivery
    learn something new everyday! I did not know the factory spray added the tundra on back! looks kool
  13. Feb 6, 2022 at 12:02 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    The factory spray in is nice and all but I'm going to be hauling plywood regularly and prefer it to slide out and not get scarred up. The no slip spray in bedliner is really aggressive. I can also see dirt getting embedded in it , needing a pressure washer to properly clean it out. Most 22's I see coming in have the spray in liner. Here atleast.
  14. Feb 6, 2022 at 1:43 PM
    Toyota1234
    Jack
    Agreed this is what I thought when I saw one. Seems it would tare stuff up. Hate to lay anything painted on it
  15. Feb 6, 2022 at 1:54 PM
    CKM52
    CKM52 New Member
    Based off my experience with spray in liners, I definitely recommend protecting anything you wouldn't want to rub with 60 grit sandpaper.
  16. Feb 6, 2022 at 5:29 PM
    TXBJJ
    TXBJJ New Member
    I previously had a Tacoma and it was slippery. A cheap bed may works great for this. Overall I liked the composite bed.
  17. Feb 7, 2022 at 6:11 AM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    My 2019 Taco bed was slippery, I added the bed mat and it helped a lot but made things harder to slide into the bed.
    I think the spray in liner would be a much better idea, whether OE or aftermarket Linex/etc.
  18. Feb 7, 2022 at 6:40 AM
    Osiris
    Osiris New Member
    20 Plat
    How does the factory spray compare to aftermarket sprays? Is it less aggressive? It doesn't look as rough as some of the aftermarket options like my dealer used on my 2.5 gen.
  19. Feb 7, 2022 at 9:10 AM
    Toyota1234
    Jack
    It is like a very course sand paper. If I fell on it I would expect to bleed. Other spray ins I have seen seemed more sticky but not so aggressive.
  20. Feb 7, 2022 at 3:23 PM
    kmangino47
    Hard 60 grit sand paper. It’s definitely aggressive
  21. Feb 12, 2022 at 6:58 PM
    Osiris
    Osiris New Member
    20 Plat
    Anyone tested how durable/thick the spray is by tossing your hitch or similar in the back?
  22. Feb 12, 2022 at 7:22 PM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    I have also heard that the new bed is not as deep as past generations has anyone confirmed this?
  23. Feb 12, 2022 at 8:25 PM
    kmangino47
    I had a large tile saw and half a tarp full of tile scraps in the bed today. That bed liner is gunna hold up just fine. It’s hard like plastic but abrasive like sand paper. Tile dust made a mess but looks like it will rinse right out.
  24. Feb 13, 2022 at 6:35 AM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Tossing your hitches in the back eh.
  25. Feb 13, 2022 at 6:42 AM
    rideandfly
    rideandfly New Member
    Keep our bed full with camping gear except for the area next to tailgate saved for cooler and/or gen-set. The composite bed looks like it would be slick when wet. Keep an aluminum step in the bed for reaching into front of the bed with the bed cover open. Installed a Toyota bed mat when we purchased our Tundra, it's all we need:
    Mattedfred likes this.
  26. Feb 13, 2022 at 6:55 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    is it 5.5 or 5 now? looks even smaller than prev gen
  27. Feb 13, 2022 at 7:04 AM
    rideandfly
    2022 CrewMax is a 5.5 bed.
  28. Feb 13, 2022 at 7:21 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    You need a CargoGlide pullout! You have no idea what you're missing out on carrying loads like that. I've used one in my last three trucks, rarely have a need to step into the bed.
  29. Feb 13, 2022 at 7:47 AM
    rideandfly
    I have seen those and they're very nice! Have a friend that uses one in his one ton pickup with shell.
    Did not say it well, I use a cheap folding aluminum step to keep from stepping into the bed when reaching over the side of the front of the bed next to the cab. Prefer a bed cover over a shell. Had two diamond back covers on our last two pickups, they are very nice, but decided to go with the Toyota bed cover this time.
    Thanks,
  30. Feb 13, 2022 at 1:20 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I'm new to this forum, I think I sent you a private conversation as to not side track the thread.
    Mattedfred[QUOTED] likes this.
