Deeper engine noise after exhaust add
Discussion in 'Performance and Tuning' started by Robster80, Feb 4, 2022.
  1. Feb 4, 2022 at 4:37 PM
    Robster80
    Robster80 [OP] New Member
    Is it typical to have much deeper engine noise after exhaust add? I love the exhaust sound but when driving around town or hills, light throttle, sometimes when slowing down, downshifting, theres so much bass/hum it basically vibrates the interior. I do have sensitive ears and had inner ear issues in the past maybe im just sensitive to it. I have the 12” dirty deeds system.
  2. Feb 4, 2022 at 4:57 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, its drone. Did you get the resonator? You need the resonator to cancel the drone.
    AZBoatHauler and FrenchToasty like this.
  3. Feb 4, 2022 at 5:04 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    I had a 10 inch DD exhaust last year.
    I had the resonator.
    I still had major drone as you describe no matter what i did
    ultimately i put the stock muffler system back on and the result was no vibration and complete silence
    omgboost likes this.
  4. Feb 4, 2022 at 5:05 PM
    Robster80
    Yea Ive got the res installed
  5. Feb 4, 2022 at 5:06 PM
    Robster80
    im tempted to do that. I had the 8 but swapped to 12 thinking that would fix this issue. But its no different at all. Maybe even worse.
  6. Feb 4, 2022 at 5:08 PM
    SouthWestGA
    25-55mph it was mind numbing for me. It resounded in my ears and my head. I couldn’t handle it.
  7. Feb 4, 2022 at 5:11 PM
    Robster80
    yep thats when i notice it the most. Alot of times ill hafta get off the throttle to make it stop or either speed up to make it stop
  8. Feb 5, 2022 at 5:16 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    I have the DD 14” system. On average, the noise level only marginally increased over stock but the tone/note in the cabin is much much better. While cruising, the truck may even be quieter. I am very happy with the setup.
    I do get a rumble/deep sound when RPM’s are ~1k and I press gas pedal lightly to try and increase speed ever so slightly. To me it sounds like the engine is bogging down, giving it gas when it’s not in the powerband. Truck did this stock also, it just wasn’t as noticeable with the stock muffler.
    If I press gas enough for truck to downshift, the noise disappears.
    I’ve played around with the truck in sport mode(shifter kicked to left to let me change gears). If I keep the truck out of 6th gear when going under 55mph, I never get the rumble. It holds RPM’s slightly higher through the gears which is actually pretty cool. Cruising in 6th doing 65-70+ doesn’t have any issues because the RPM’s are up to 1,500 +.
  9. Feb 5, 2022 at 5:20 AM
    Robster80
    Maybe i shoulda done longer mufflers i dunno. Theres literally no difference in the 8 and 12 with this sound im talking about tho. That was the whole reason i switched. The deep hum/drone is brutal. I checked for exhaust leak or anything but ive got everything properly installed
  10. Feb 5, 2022 at 5:36 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    If going from 8 to 12 didn’t cause a noticeable difference, I don’t think an extra 2”-4” would make a difference. Have you called Keith to get his thoughts?
    Are you getting the noise through the RPM band at those speeds or is it specific to a range like mine?
    I feel like the truck shifts to 6th as soon as I get to speed (for gas savings) and requires a meaningful step on the gas for it to downshift so the truck gets in the powerband to accelerate. (My test of moving shifter to manual mode confirms this).
    If the truck downshifted quicker, this could be eliminated (in my instance at least).
  11. Feb 5, 2022 at 5:40 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    my $.02
    the TRD system - which is sorta comparable to the 14" drones a tad. 1300-1400rpm
    my remedy...don't go that speed.
    TundraPJ likes this.
  12. Feb 5, 2022 at 6:22 AM
    Kanobi13
    Kanobi13 New Member
    I think it is person to person i have th 8 DD and no resonator and do not notice the exhaust or the drone.
  13. Feb 5, 2022 at 6:27 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The DD resonator works to kill drone, but it is still a very loud exhaust
  14. Feb 5, 2022 at 6:32 AM
    ARES35
    ARES35 New member for life
    Mile high
    Im running the 10" DD no res and find the drone minimal. If I have the back window down it is a little more pronounced. The wife and kids barely notice the exhaust in general unless i romp on it with the windows down lol
  15. Feb 5, 2022 at 6:36 AM
    Robster80
    ive got the res on , the exhaust itself when gunning it sounds amazing, but creeping around at slower rpms, up hills, light throttle it sounds like i have a 12 inch subwoofer stuck under the cab. Just alot of vibration,bass,deep frequency.
  16. Feb 5, 2022 at 6:58 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That’s probably the rumble coming out of the pipe. I had a 10 inch. I loved it but the sound was just too loud towing a travel trailer with the fam. No drone, just that deep rumble
  17. Feb 5, 2022 at 7:02 AM
    Robster80
    What do u have now?
  18. Feb 5, 2022 at 7:18 AM
    Perhaps a longer resonator would help. Or maybe the resonator is on but the hole never got drilled to make it functional
  19. Feb 5, 2022 at 7:25 AM
    Robster80
    Drilled the 2” hole Unless i didnt line the hole on pipe with hole in resonator properly somehow. However while waiting for 12” to arrive i used the stock system with resonator and the stock system was much quieter than without the res. So im guessing i installed it correctly
  20. Feb 5, 2022 at 7:32 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have a 5x11x22 magnaflow. Ive had it since 2011, just hair deeper than stock, but silent in 5th gear pulling trailer
    Darkness likes this.
  21. Feb 5, 2022 at 7:41 AM
    Robster80
    does the magnaflow have this same deep bass-ey sound in the cab?
  22. Feb 5, 2022 at 8:31 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Even the stock exhaust has drone if you listen for it. DD resonator will make it go away.
    I have the 10in DD system, ran without and then added resonator and I think the sound is perfect.
  23. Feb 5, 2022 at 1:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    no, it’s barely louder than stock
  24. Feb 6, 2022 at 9:21 AM
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    First off, call Keith and ask his input. He will help you if you need to change it to the larger system.
    Drone is definitely problematic in our trucks with modified exhaust. If you remove the cats it's ten times worse.
    Best things to do is get the resonator, don't dump pipes before the axle, and got as big a muffler as you can in there.
  25. Feb 6, 2022 at 9:31 AM
    SouthWestGA
    My stock exhaust did not have the same drone frequencies as the DD.
    I don’t think it’s the noise that’s the problem,it’s the frequency
    Darkness and Robster80[OP] like this.
  26. Feb 6, 2022 at 9:43 AM
    Robster80
    Ive got the resonator on it. I had the 8” at first. Ran with no res for a bit then installed the res. Definitely made a difference but it didnt help all that deep,bass-ey, low frequency hum at lower rpms, deccelerating,etc. i figured the larger 12” would lessen that particular frequency but it didnt
  27. Feb 6, 2022 at 10:24 AM
    808Tunderer
    808Tunderer New Member
    2021 DubCab SR5 4x4 TRD Offroad
    Stock
    What about at cold start, did you notice a difference from 8" to 12"?
  28. Feb 6, 2022 at 11:15 AM
    Robster80
    Not alot of difference imo really
    808Tunderer[QUOTED] likes this.
  29. Feb 11, 2022 at 11:06 AM
    Odin43
    Odin43 YNWA
    Rich
    NJ
    2021 MGM Platinum, 2015 Lexus LX 570
    I have the same drone with my 12" BAM with res around 1,100 rpm especially on hills. I'm sure it's installed correctly so I figured it was normal. I wish it wasn't there but the exhaust sounds so good everywhere else that I'm okay with a bit of drone in that specific situation.
  30. Feb 11, 2022 at 11:54 AM
    Robster80
    Yea thats where it mainly is in that 1100 rpm range. Wish there was a way to minimize it
