clunking noise 2020tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by dchaff, Feb 4, 2022.
  1. Feb 4, 2022 at 1:05 PM
    dchaff
    dchaff [OP] New Member
    i own a 2020 toyota tundra trd off road whenever i start off from being parked there is a clunking noise under truck dealer says it is the brake pads dropping they do this in case of mud and debris does this sound correct.
  2. Feb 4, 2022 at 1:09 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    My 2014 and 2017 make the same noise… I was told it was normal as well… I can’t remember what they said causes it… truck runs fine.
  3. Feb 4, 2022 at 1:11 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    There is an ABS check the truck makes on start off, not sure of the MPH, but it is low, 5-10MPH, clunk or thud where they ABS is doing a self check.
    Pac12AfterDark likes this.
  4. Feb 4, 2022 at 1:13 PM
    frichco228
    Frank
    Virginia
    Oh, one thing to check, if your truck has zerk fittings in the drive shafts/drivetrain, be sure to lube those at every oil change. If they get dry they can make a clunk, thud noise also.
  5. Feb 4, 2022 at 1:42 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    ABS system. Totally normal.
