VSC and 2 to 4 wheel drive not functioning.
Discussion in 'General Tundra Discussion' started by MoToad, Feb 1, 2022.
  1. Feb 1, 2022 at 12:38 PM
    MoToad
    MoToad [OP] New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    This is a wild shot but if anyone has answers, it's probably you guys. My ride is connected to a Bullydog (came with it), an obvious back yard install with wires hanging out from under the dash. I found the accessories wire disconnected and put it back in properly and cleaned up the rat's nest. I don't know if it has anything to do with it or not but the VSC light is flashing, have no 4x4 indicator and seem to be locked in 4 wheel drive. I held the VSC button for 3 seconds, shut off the vehicle then restarted but it does not reset the VSC. And still nothing happens with the 2 to 4 wheel switch. Any suggestions would be greatly appreciated.
  2. Feb 2, 2022 at 5:09 AM
    blanchard7684
    blanchard7684 New Member
    Saltyhero13 likes this.
  3. Feb 3, 2022 at 8:45 AM
    2mchfun
    You may have rodent damage to the harness.
