Seat pop
Discussion in '3rd Gen Tundras (2022+)' started by SirSwish32, Feb 3, 2022.
  1. Feb 3, 2022 at 5:32 AM
    SirSwish32
    SirSwish32 [OP] New Member
    North Carolina
    2022 Tundra SR5 XP 4X4
    1.75" Rough Country Level
    Anyone have a pop happen when you apply weight to the left side of driver seat when getting out of the vehicle? I am 190 pounds before anyone asks...
    It happens every single time I get out of the truck. I for some reason have this issue frequently. My F150 did the exact same thing but went away after a week.
  2. Feb 3, 2022 at 7:57 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Not heard about that on 2022s, but I have seen some reports on 2020, 2021. Was a seat rail issue fixed under warranty for the several instances I ran across.
  3. Feb 3, 2022 at 8:02 AM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    Same issue on a 2013. Thought I found a solution with the lumbar adjustment but it is getting worse. I would force Toyota to fix under warranty because it gets worse. They told me it was a loose bolt right before I exceeded warranty and now on my own. Most bumps now produce a clunk.
