Fumoto Valves
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Jan 27, 2019.
  1. Mar 16, 2019 at 7:09 AM
    #121
    Tifford
    Tifford New Member
    Central New York
    2024 Tundra Double Cab (stock for now)
    I have one on mine and I like it. Makes oil changes less messy.
  2. Oct 20, 2019 at 1:08 AM
    #122
    Part_time
    Part_time [OP] Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Reporting back,glad I went with the Fumoto valve. I try and sell it to my friends that do their own maintenance. Not literally the idea,very pleased.
    Tundra_Dawg likes this.
  3. Oct 20, 2019 at 1:15 AM
    #123
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Do you recommend the long or short stem?
  4. Oct 20, 2019 at 1:26 AM
    #124
    Part_time
    Oregon
  5. Oct 20, 2019 at 1:36 AM
    #125
    Part_time
    Oregon
  6. Oct 20, 2019 at 2:04 AM
    #126
    They have a short stem as well. Just not sure if there is a clearance issue.
  7. Oct 20, 2019 at 2:45 AM
    #127
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Is it possible to shear one off while wheeling?
  8. Oct 20, 2019 at 4:38 AM
    #128
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    You oil pan will likely have a gash at that point.
    Mine is above the crossmember on a 6 inch lift.
    unclebeejo808[QUOTED] likes this.
  9. Oct 20, 2019 at 5:30 AM
    #129
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    It’s still tucked up there pretty good. Here is mine.1AF957D8-5ABE-4252-B80C-72B9F8D7AEC8.jpg
    hANNAbONE, Bob_Wiley, saybng and 2 others like this.
  10. Oct 20, 2019 at 6:17 AM
    #130
    Jrharvey02
    Jrharvey02 New Member
  11. Oct 20, 2019 at 6:20 AM
    #131
    ProtoJ
    ProtoJ New Member
    mine went in smoothly and tightened with a crescent wrench. When it was fully tight the handle of the valve lined up perfectly.
    Jrharvey02[QUOTED] likes this.
  12. Oct 20, 2019 at 9:24 AM
    #132
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    When installing the Jowett housing what do you do with the center screen and spring? I put mine on this housing but now thinking about it the Fumoto valve wont work as it is supposed to. I am sure I will have to take it off next change and remove the spring?
    TIA, Mike
    saybng and Prostar 190[QUOTED] like this.
  13. Oct 20, 2019 at 9:32 AM
    #133
    longhornfan2324
    longhornfan2324 New Member
    I have already changed my oil using the housing and it works as intended. I didn't get the valve with the nipple for a hose but the oil flows nice and smooth out of the valve.
  14. Oct 20, 2019 at 9:44 AM
    #134
    Scud
    Scud New Member
    Working on it :-)
    Did you transfer the center screen and spring from the original housing into the Jowett?
    Thanks, Mike
  15. Oct 20, 2019 at 9:59 AM
    #135
    Tundra_Dawg
    Tundra_Dawg Boss Moss
    Arizona
    2017 MGM Platinum
    PPE headers, TRD exhaust, ICON 3" lift, Raceline wheels, Powertrax Tonneau cover; 2019 TRD Pro headlights and fogs; TRD pro grille; Victory 4x4 sliders.
    Anything is possible, but it does not extend below the oil pan and that location is reasonably protected by my RCI skid plate. While I can reach my hand up there and open the valve or attach a hose, it would take wheeling over some sort of spiked object to be at risk.
  16. Oct 20, 2019 at 10:01 AM
    #136
    unclebeejo808
    Oahu
    Thanks. Gonna order one now
  17. Oct 20, 2019 at 10:12 AM
    #137
    longhornfan2324
    Yup just bent the tabs to remove the screen and spring and moved them into the new housing. Reverse the process to put in the new housing and its way easier. I also put the same valve system on the oil pan with a RCI Offroad skid plate so looking for ward to the next oil change in a few thousand miles.
  18. Oct 20, 2019 at 10:16 AM
    #138
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Great thread! Tagged to save info for the future.
    Voyagermike likes this.
  19. Oct 20, 2019 at 1:00 PM
    #139
    Yes you just install the screen.
  20. Feb 2, 2022 at 7:39 PM
    #140
    Part_time
    Oregon
    Back to oil changes, I may start a thread on this. I have a coworker that tells me every oil change he does or close to it, he puts in the amount of oil to be replaced with diesel. Runs it for 5 minutes and drains. He is getting 300,000 plus miles out of his car.
    Has anyone done something like this or heard of doing this? Interested on reply.
  21. Feb 2, 2022 at 7:43 PM
    #141
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Trooper2 likes this.
  22. Feb 3, 2022 at 3:45 AM
    #142
    Bammer
    Monroe, CT
    I added 1 quart of ATF you my old Chevy Aveo that had a lifter tick. Ran it at idle for 1 hour, DO NOT REV ! Drained and refilled with fresh oil, tick gone and smooth as glass.
  23. Feb 3, 2022 at 7:21 AM
    #143
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  24. Feb 4, 2022 at 7:51 AM
    #144
    odin1701
    odin1701 New Member
    2021 Tundra LTD TRD OR MGM
    I had the canister style on my Tacoma. I actually like them as it made oil changes totally mess free.
    I use something like this for draining the filter cartridge:
    https://www.amazon.com/Filter-Drain-Release-Toyota-Lexus/dp/B088LX23ZC
    After the cartridge drains, there's not really any mess pulling the old filter out and replacing it. Just a little bit that you can pour out and wipe off of things. I plan to get the same setup on my Tundra between that and the fumoto valve. Need to get an RCI skid though.
    Part_time[OP] likes this.
  25. Feb 4, 2022 at 8:00 AM
    #145
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  26. Feb 4, 2022 at 8:44 AM
    #146
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  27. Feb 4, 2022 at 10:21 AM
    #147
    Part_time
    Oregon
    I have that works good
  28. Feb 17, 2022 at 4:23 PM
    #148
    Haww3r220
    Haww3r220 New Member
    KY
    Jowett is out of stock, how often does he refill. I'm itching.
    Fallingblock likes this.
  29. Feb 17, 2022 at 5:16 PM
    #149
    Tundrapwr16
    Tundrapwr16 Best Toyota made ever
    Rob
    California
    2000 RC 3.4 liter white work truck .
    Pioneer radio and intermittent wiper switch and led lights. I also use AMZOIL Products only..
  30. Feb 17, 2022 at 5:38 PM
    #150
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    He hasn't done a run for a good couple of years. Really seems like that pure goodness is done.
