U-Joint suggestions?
Discussion in '1st Gen Tundras (2000-2006)' started by jberkut4, Feb 2, 2022.
  1. Feb 2, 2022 at 7:57 PM
    jberkut4
    jberkut4 [OP] Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Squeaky noise keeps coming and going, almost positive its a U joint. Lots of options on rock auto, anyone have a suggestion for which U joint to get?
  2. Feb 2, 2022 at 8:00 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've always had good luck with Timken and Spicer
    des2mtn likes this.
  3. Feb 2, 2022 at 8:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Dana/spicer they’re the oem and rockauto sells them
  4. Feb 3, 2022 at 2:29 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Spicer...only Spicer! Don't ask me how I know this...
  5. Feb 3, 2022 at 4:13 AM
    growit
    growit New Member
    2006 Dbcb SR5
    Spicer Life Series
  6. Feb 3, 2022 at 7:52 AM
    This ^^
  7. Feb 4, 2022 at 5:18 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Went ahead and got the Spicer greasable joint, plan on installing it tomorrow. Thanks for the feedback
    DaWhiteTundra and texasrho83 like this.
  8. Feb 5, 2022 at 4:46 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Just did the job, U joint was toast. Weird thing now is the noise from u joint is gone, but new noise is coming from up front. If I put into drive and break quick, I can feel and hear something shift, then if I switch to reverse same thing. If I stay in drive and keep doing it it won’t do it again. Any ideas what it could be?
    Doris01TRD likes this.
  9. Feb 5, 2022 at 4:59 PM
    growit
    growit New Member
    2006 Dbcb SR5
    Maybe worn carrier bearing.
    DaWhiteTundra and Schcoman like this.
  10. Feb 5, 2022 at 5:47 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Kind of a thump or clunk?
    Check your transmission mount bolts. 2wd likes to come loose.
  11. Feb 5, 2022 at 5:50 PM
    Could be the carrier bearing. But since you have a 2WD there was also a TSB on the transmission mount which didn't affect 4WD trucks. More info on that (and the TSB for it) here, it only affected '05 and '06 trucks, and only 2WD.
    That said, double-check your retention clips on the U-joint caps, overall inspect your works. You don't have any zerks so there's nothing else to grease else I'd tell you to grease the prop shaft slip yoke.
  12. Feb 5, 2022 at 7:08 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Rockauto carries SKF too. I've had good experience with that brand before in the heavy diesel industry. Dana/Spicer still better for the 1st gens?
  13. Feb 5, 2022 at 7:59 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Installed Spicer joints in my shaft when I replaced my shaft support bearing. I no longer have problems with a droopy unsupported shaft.
    Doris01TRD and bmf4069 like this.
  14. Feb 7, 2022 at 1:28 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    We saw that both buschings for the control arms so we figured it could be that or something else in the front suspensions shifting when going from drive to reverse, maybe now that ujoint isn't totally shot, it is now making parts that weren't moving before move now. Also, a little bit of transmission fluid leaked out while the driveshaft was out, so I was planning on buying a quart to make sure its topped off. Anyone know what exact ATF fuid 05 Tundras take?
  15. Feb 7, 2022 at 2:51 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    DEXTRON III according to 05 FSM and OM, just like my 04 !
    brain fart !
  16. Feb 7, 2022 at 3:38 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    05 & 06 went to the sealed 5-speed and WS fluid iirc.
    I'm running Valvoline Maxlife Synthetic (red bottle) as its WS rated and also Dex III compatible afaik.
    BubbaW[QUOTED] likes this.
  17. Feb 7, 2022 at 3:52 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    :hattip:Yeah, my bad, brain saw power steering !
  18. Feb 10, 2022 at 8:43 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Topped off ATF, thunking noise seemed to go away with temp increase. New noise is a very faint whirring noise on decel. If its the pinion bearing, not worrying about it unless it gets worse. I can barely hear it over the AT's and flowmaster lol.
  19. Feb 11, 2022 at 5:51 AM
    Sealed transmission. There's a specific process to level off the fluid, pouring willy-nilly is probably not the best idea, unless you want to blow a seal or something. Someone posted a great video, start at the 16m23s mark for more info if the video doesn't auto-start in that spot.
    https://www.youtube.com/watch?v=gx5dU3UVcRs#t=16m23s
  20. Feb 11, 2022 at 12:23 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Only 1/8th of a quart leaked out while doing the u joint, so I just wanted to make sure it was topped off. Used a pump and once a steady stream was pouring out of the level check hole closed everything up. I’m not even sure there is a way too pour Willy nilly since there isn’t any dip stick tube
  21. Feb 11, 2022 at 12:59 PM
    There's no way to pour willy nilly necessarily. But OEM procedure is to heat the fluid up, then open the overflow to drain off excess. Not sure how much difference it'd make though having the fluid hot versus cold. I can't brain right now so the thought of trying to understand whether the fluid would be larger or smaller when heated is melting the wrinkles out of my gray matter.
  22. Jul 8, 2022 at 5:50 AM
    Archive
    Archive New Member Vendor
    Eric
    '22 Tundra CM 6.5' TRDOR
    Archive Garage Suspension
    Hey, since there's some transmission fluid talk in here, just a warning that early (2000 - ?) Tundra Owner's Manunals had misprinted the transmission fluid drain/fill capacity at only 2 qts. It is actually 4 qts/ 1 gallon, and the 2000 - 2002 fluid was originally Dex III, now serviced by "Dex/Merc". My 2000 manual had the misprint. I ran Castrol Transmax Dex/Merc in my 2000 Tundra, did 2 drain/refills and it shifted perfect, took exactly 1 gallon so it was a very easy service, didn't bother dropping the pan, just cracked the drain plug.
    I bet that misprint is responsible for same of the failures of the early trans, but mine with 245k on it was stout despite previous owners doing poor maintenance and I enjoyed revving that 2UZ out pretty often
    shifty` likes this.
