2020 brake pads
Discussion in '3rd Gen Tundras (2022+)' started by Sasquatchlives, Feb 1, 2022.
  1. Feb 1, 2022 at 6:08 AM
    Sasquatchlives
    Sasquatchlives [OP] New Member
    2020 toyota tundra sr5 with tss package
    Does anyone know of you need a special tool to change brake pads on 2020 sr5? Hearing may require a.special.tool.to compress pistons
    On my mustang the rear brakes require a special tool to compress the rear pistons.
    Wonder if same type of tool for just use a large c clamp
    Any help ????
  2. Feb 1, 2022 at 6:52 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Nothing extra really needed. The fronts are 4 piston Brembo style. They will move on you. Use the old pads and an extra set of hands. Nothing you can't do in your driveway.
  3. Feb 1, 2022 at 3:53 PM
    Sasquatchlives
  4. Feb 1, 2022 at 4:08 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I used two flat head screwdriver to do pads on my Evo X with Brembo brakes and 15' tundra.
