  1. Feb 1, 2022 at 7:02 AM
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
    I took every piece off. Just a few screws and pull tabs, not too much to it. The main thing is to be patient when spraying and let it cure for atleast a couple days. I let it cure for 30 hours or so and when i went to put the grill back into the surround, some of the paint peeled on the edge because it wasn't cured yet.
    MadMaxCanon[QUOTED] likes this.
  2. Feb 1, 2022 at 7:36 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    To the guys with a pedal commander -
    do you still press “tow haul” when towing? Or do you change setting on your pedal commander?
    Is there any conflicting programming - does the pedal commander make tow haul redundant?
  3. Feb 1, 2022 at 7:42 AM
    RobertD
    Robert
    DFW, Texas
    They do very different things. A throttle control adjusts the responsiveness of the pedal while tow/haul changes shift points. I'd still use tow/haul if you are actually pulling anything of weight.
    One person mentioned that they use tow/haul and then turn the sensitivity down via throttle controller when towing their horses so its a smoother take off.
    Hope that helps
  4. Feb 1, 2022 at 7:57 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I am considering doing this to my chrome surround and bulge and maybe the panels directly under the headlights too since those take alot of abuse. I already have 1 small chip that pisses me off everytime I look at it.
    Do you do the regular plasti dip first then the glosser?
  5. Feb 1, 2022 at 8:01 AM
    tgrave1
    tgrave1 New Member
    Huntington Beach, CA
    2020 SR5 TRD 4X4 Sport
    Eibach Pro Kit. Camburg UCA's. Coachbuilder bumper shims. Cab mount chop. N-Fab side steps. 18 inch Method 308 Roost wheels. Falken Wildpeak AT/3 tires (295-70-18). Gator EFX bed cover.
    Had a very small amount but hadn't installed the drain tubes before running it through a car wash. The only issue so far is there seems to be some kind of air pressure issue inside the cover that is blowing the provided bulkhead seal off of the top of the bed behind the cab. Not sure if there is an issue with the one sided tape on the foam seal not adhering to the spray on bedliner.
  6. Feb 1, 2022 at 8:02 AM
    DirtyMike5
    Baton Rouge
    I'd recommend it. I clean off the chrome with alcohol and get a nice surface it to stick to just like regular spray paint. I did 5-6 coats of plastidip and 3 coats of glossifier after. 20-30 minutes between each coat.
  7. Feb 1, 2022 at 8:08 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Thanks for the info Tim!!
    tgrave1[QUOTED] likes this.
  8. Feb 1, 2022 at 8:14 AM
    Tow / Haul also changes the throttle response making it much more sensitive to input. I use it when driving in the hills to help with throttle response going up, and engine braking coming down. I use it when I Tow, I also use it when I want to Haul ass.
    3xYOTA likes this.
  9. Feb 1, 2022 at 8:15 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Man that's so cool! Thank you for sharing :thumbsup:
  10. Feb 1, 2022 at 8:39 AM
    Turn the PC off and use tow/haul.
    Cl8NL[QUOTED] likes this.
  11. Feb 1, 2022 at 10:38 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Nice! My Dad also had one around the same time frame. He was stationed in SD USAF and still talks about taking it up in the Black Hills trout fishing and wheeling. Says the same thing too 'never should have sold it'.
  12. Feb 1, 2022 at 10:54 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Anyone else have to glue the diodes to the housing for the Meso dome lite? As soon as I pushed the a selector button it would pop off. Had it clipped in there good but it wouldn’t stay.
  13. Feb 1, 2022 at 11:14 AM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    Just got home from the Dealership. My Tundra is all fixed. If you didn't see my last post, the Main Harness had to be replaced due to a damn squirrel chewing on the Harness on the passenger side firewall. WARNING to all. Make sure your insurance covers rodent damage. The total price was...$9876.24:eek2: The break down is Labor $5984 Parts $3530.38 Tax $361.86. That was crazy expensive and luckily, I only had to pay my $500 deductible. I hope I never have to have this done again. Once again, make sure you are covered.
    mr0351, Superbsdad, 1794TX and 8 others like this.
  14. Feb 1, 2022 at 11:34 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Could you please send a link for the Rad rubber fender liners? I just took my right front liner out because it was torn and just hanging loose.
  15. Feb 1, 2022 at 11:37 AM
    2mchfun
    Check into a 0 ded. On comp., doesn't raise premiums much at all. Great for hail, deer, etc.
    Otaku4life69[QUOTED] likes this.
  16. Feb 1, 2022 at 11:43 AM
    jhamby
    jhamby New Member
    West Texas
    yeah, I posted the measurements awhile back here in the thread
  17. Feb 1, 2022 at 11:58 AM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Tundrastruck91 likes this.
  18. Feb 1, 2022 at 12:41 PM
    WBW
    WBW Resident lurker
    Bruce
  19. Feb 1, 2022 at 1:12 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    looks fantastic.
    DirtyMike5[QUOTED] likes this.
  20. Feb 1, 2022 at 1:17 PM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    You may also want to check out Ark liners, they had a group buy here a year or so ago, I love mine, and so much more coverage:
    https://arksplashguards.com/
  21. Feb 1, 2022 at 1:31 PM
    WBW
    WBW Resident lurker
    Bruce
    Thank you! I'll look at them for sure.
  22. Feb 1, 2022 at 1:32 PM
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    Baja Designs SAE fogs . Side by side with the stock ones.
    TunsofFon, mgm16trdpro, D3VA and 4 others like this.
  23. Feb 1, 2022 at 1:32 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    They're local in Phoenix, too.
    WBW[QUOTED] likes this.
  24. Feb 1, 2022 at 2:03 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
  25. Feb 1, 2022 at 2:06 PM
    MadMaxCanon
    :eek2:
    Otaku4life69 likes this.
  26. Feb 1, 2022 at 2:08 PM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
  27. Feb 1, 2022 at 2:16 PM
    I hope that's not real. :eek:
  28. Feb 1, 2022 at 2:20 PM
    Flying Gorilla
    Flying Gorilla New Member
    Austin, TX
    2018 SR5 TSS Blazing Blue Pearl
    Factory Lift 35” Tires Black Rims
    So, I wanted to take off the SR-5 logo on my wireless charger. As you’ve probably figured out, my callsign is Gorilla. Thus, I give you my new logo….
  29. Feb 1, 2022 at 2:30 PM
    WBW
    WBW Resident lurker
    Bruce
    Really? I like keeping it local whenever possible.
  30. Feb 1, 2022 at 2:30 PM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    That would make it all the better...
