  1. Jan 31, 2022 at 4:52 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Finally got a few hours break from the deep cold so I was just able to install my B&W hideaway hitch. This hitch is a work of art. Only thing is, I bought a lockable hitch pin and it might get hard to hook my trailer chains on now. lol
  2. Jan 31, 2022 at 4:54 PM
    SEM Trim black is an option.
  3. Jan 31, 2022 at 5:02 PM
    AZTundra
    Paul
    Phoenix, AZ
    Nice choice! I have the same one. I also picked up a couple extra pins and clips from B&W. I was worried that someone might think they need them more than I do and I didn't want to be stuck without them when needed. I keep the spares in the glove box just in case. They can't steal the receiver, but can take your pins/clips if they really wanted to.
    ATV25 likes this.
  4. Jan 31, 2022 at 5:36 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Is there a thread describing where/how to screen? My truck lives outside.
  5. Jan 31, 2022 at 5:45 PM
    There is...I would have to find it.
  6. Jan 31, 2022 at 5:50 PM
    AZTundra
    Paul
    Phoenix, AZ
    Anomalos7 and Tundrastruck91 like this.
  7. Jan 31, 2022 at 5:53 PM
    2mchfun
    There are a few threads. Pretty easy really, under the windshield/hood cowling on pass side there is a port about 2" tall and 8" wide. I screened mine with two layers of 1/4" hardware cloth and some self drilling sheet metal screws with washers. Engine compartment I put a few bars of pink Dove soap in a couple of spots, a couple pine sol soaked pieces of fabric in a couple others, and peppermint oil soaked fabric too. Then about 8 chlorine pool tabs on the driveway under the truck and perimeter just cuz it can't hurt and may help. Don't really have big rodent problems here, but don't want to start either. Good luck!
    Anomalos7 likes this.
  8. Jan 31, 2022 at 6:06 PM
    Mobeyk
    Mobeyk New Member
    As contractor I have always extra pins and clips, these are the finest though.
    AZTundra[QUOTED] likes this.
  9. Jan 31, 2022 at 6:10 PM
    montez25
    montez25 New Member
    2020 toyota tundra platinum 4x4
  10. Jan 31, 2022 at 6:14 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    After watching this guy struggle to get the wiper arms off, I have found a trick to do this easily. After marking the blade position and removing the nut, lift the wiper arm off the glass and give the arm a bump downward (toward windshield) with the base of your hand or the side of your fist. A firm bump near the joint where the arm bends between the joint and the mounting bolt will usually easily break the friction bond between the arm and the mounting post. Then you can the just lift the arm off.
    Anomalos7 and AZTundra[QUOTED] like this.
  11. Jan 31, 2022 at 6:16 PM
    montez25
    montez25 New Member
    Nice. Thank you sir.
  12. Jan 31, 2022 at 6:21 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    yes
  13. Jan 31, 2022 at 6:25 PM
    Ranger2005
    Ranger2005 New Member
    Dean
    2021 1794 Crewmax
    Running boards, ceramic coating, sound system
    Make it in yet! I'm curious about the depth..
  14. Jan 31, 2022 at 6:33 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    Anomalos7 and THORYOTA like this.
  15. Jan 31, 2022 at 6:39 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I want to know more about this...
  16. Jan 31, 2022 at 7:59 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    ^ me too
    Barrett50 likes this.
  17. Jan 31, 2022 at 8:00 PM
    blrroman27
    blrroman27 New Member
    2021 Toyota Tundra SR5 Trail Edition
    n/a
    GoRhino running boards and got the 5th wheel OE ordered online and got the last tire to match the stock wheel and tires. Happy Monday ya'll!
    nhw544, Tundra805, TNTundra16 and 8 others like this.
  18. Jan 31, 2022 at 9:07 PM
    Evodadi
    Evodadi New Member
    Aptos,cali
    2020 SW Tundra SR5
    Waiting for the rest of the parts so i can start dechroming,debadging,color matching,and rebadging
  19. Jan 31, 2022 at 9:11 PM
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    Looking back at my Amazon orders:
    $60 Kilmat
    $15 Rollers
    There's no odor with the Kilmat. The results were well worth the effort. I only did the floor of my supercab, and I used up the 36 sq ft package. You will need more to do the back wall and doors. Wear gloves and cut with a sharp utility knife on a scrap of wood. Use a scratch awl to probe for bolt holes. There are good how-to youtube videos. Show us pictures when you're done. :thumbsup:
    Rocko9999[QUOTED] likes this.
  20. Jan 31, 2022 at 10:05 PM
    MattJakobs
    MattJakobs New Member
    Matthew
    NorCal
    Where’s everyone getting their TRD pro grills and headlights?
  21. Jan 31, 2022 at 10:06 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Me Too!!!!
  22. Jan 31, 2022 at 11:41 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Rad Rubber front liners
    Total Chaos bed stiffeners/trimmed bed mat
    Replaced 10mm rusty wheel well bolts w/ Amazon specials
    And missed the 90k birthday party by a scoshe.
    Cl8NL, Velocity72, Terndrerrr and 7 others like this.
  23. Feb 1, 2022 at 4:18 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Nice did you check to see if you get water in the bed?
  24. Feb 1, 2022 at 4:29 AM
    RusPro21
    Don
    Pa.
    Which GORhino running boards are these. They seem to have a nice gap between the body of the truck and the step? How far do these stick out? Thanks.
  25. Feb 1, 2022 at 6:26 AM
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
    Painted my chrome grill surround. Not an exact match but close enough to make me happy. I'll do the front and rear bumpers whenever I can get enough time and warm weather.
  26. Feb 1, 2022 at 6:39 AM
    Taco-Spike
    Two Trucks
    I use OEM part source, a lot of people use Sparks, or OEM dealer that will free ship to a dealer close to you if applicable. Really just put the part number in google and price check, continue to shipping with each company and see what is cheapest. Some parts might be more expensive and have cheaper shipping and some parts might be less expensive and higher shipping.
  27. Feb 1, 2022 at 6:47 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    That looks great to me! how did you do it?
    AZBoatHauler and Taco-Spike like this.
  28. Feb 1, 2022 at 6:50 AM
    DirtyMike5
    Baton Rouge
    White plastidip and the plasti glossifier, it looks better than i thought it would.
    mikesTundra77 and Rocko9999 like this.
  29. Feb 1, 2022 at 6:50 AM
    Fergie
    Fergie New Member
    That is Tina the Turd; C. diff green to my colorblind eyes, and w a poorly tuned carb, runs rich and always smells.
    1976 Fj40; 3rd owner; bought from a former ski/river guide about 1.5 years ago; paid a pittance for what the market is for them since he was happy the vehicle was going to another Cruiser head. OME suspension; 33s, full cage; Celica seats. Replaced the ignition w a DUI unit and replaced the clutch cylinders and she is a daily.
    Was on the search for an FJ40 for years; my old man had a 67 after he got back from Vietnam and that was the one vehicle he said he never should have sold.
    It'll be a teaching vehicle for my kids to learn the basics on and cut their teeth, so to speak.
  30. Feb 1, 2022 at 6:52 AM
    MadMaxCanon
    So did you take the center of the grill off or just tape it off?
