Grinding noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jcarp0632, Jan 30, 2022.
  1. Jan 30, 2022 at 4:38 AM
    Jcarp0632
    Jcarp0632 [OP] New Member
    Justin
    2015 Tundra Limited
    I recently got a 15 tundra limited it only has 12000 miles and it has developed a grinding sound that is only present when I have the truck in drive and stopped or at low speeds any ideas of what it could be? Thank you!
  2. Jan 30, 2022 at 7:37 AM
    Meaning when u first put it into drive?
  3. Jan 31, 2022 at 7:34 PM
    kutzi17
    kutzi17 New Member
    I have the same problem. Mine started just a couple of weeks ago. I thought it was the front driver side wheel bearing, took it to a shop and was told that the truck is mechanically sound. I was advised to get the tires rotated, did it but the grinding noise is still present. Otherwise, it drives and brakes well. Really interested as to what the problem really is.
  4. Jan 31, 2022 at 7:41 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Is the ac on when it happens?
  5. Jan 31, 2022 at 7:43 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Can you try and get a video of the sound?
