  1. Jan 31, 2022 at 6:21 AM
    sabet
    sabet New Member
    Took the tundra for first time thru sam houston national forest, what a blast!
    GarTX526, Steve18, GAknight and 14 others like this.
  2. Jan 31, 2022 at 7:45 AM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    montez25[QUOTED] likes this.
  3. Jan 31, 2022 at 7:47 AM
    :eek:
  4. Jan 31, 2022 at 8:27 AM
    tgrave1
    tgrave1 New Member
    Huntington Beach, CA
    2020 SR5 TRD 4X4 Sport
    Eibach Pro Kit. Camburg UCA's. Coachbuilder bumper shims. Cab mount chop. N-Fab side steps. 18 inch Method 308 Roost wheels. Falken Wildpeak AT/3 tires (295-70-18). Gator EFX bed cover.
    Finally took a couple pictures and installed a Gator EFX bed cover.
  5. Jan 31, 2022 at 8:44 AM
    Rocko9999
    Rocko9999 New Member
  6. Jan 31, 2022 at 8:47 AM
    Ranger2005
    Ranger2005 New Member
    Dean
    2021 1794 Crewmax
    Running boards, ceramic coating, sound system
    And I thought I was a little OCD about cleaning my truck.... LMAO
    jclem65 and Rocko9999[QUOTED] like this.
  7. Jan 31, 2022 at 8:53 AM
    Rocko9999
    Ha. Been meaning to pull carpet and do thorough cleaning since I bought the truck used a little while ago-just never had the time. Was a concrete construction foremans truck so it was in need.
    AggiePhil and Ranger2005[QUOTED] like this.
  8. Jan 31, 2022 at 9:02 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    might as well put some sound deadening in while it’s apart!
    GarTX526, jclem65, YotaBro and 4 others like this.
  9. Jan 31, 2022 at 9:03 AM
    Ranger2005
    Dean
    2021 1794 Crewmax
    Nice thing about doing what you're doing, it's going to be as close to new as it can when you finish
    I've been known to pull the wheels and clean up the suspension and stuff.. my Camaro was immaculate inside and out and under.. but it was a garage kept show car. (2002 35th anniversary edition)
    Rocko9999[QUOTED] likes this.
  10. Jan 31, 2022 at 9:20 AM
    Rocko9999
    I thought about it but didn't know if I have to remove the stock deadening/coating that's already there.
  11. Jan 31, 2022 at 9:33 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    Nah you can install over it. The area that the factory “deadening” covers is pretty small if memory serves, just a couple of areas in the front footwells and some along and in front of the back wall.
    Ranger2005 likes this.
  12. Jan 31, 2022 at 9:48 AM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    Sneak preview of a little project I have in the works :cool:
    TNTundra16 likes this.
  13. Jan 31, 2022 at 9:59 AM
    Bed rails?
  14. Jan 31, 2022 at 10:13 AM
    AZBoatHauler
    So.Arizona
    I have Dirty Deeds 10” system with resonator. I called and checked with Keith (owner and designer of the DD exhaust system) and he suggested running an extended resonator (32” instead of 26”) to eliminate any drone from shortening the pipe which I installed when I cut it.
    It sounds almost the same to me - I think it comes off a tiny bit quieter than before but I think that is just due to not being able to stand right next to the pipe.
  15. Jan 31, 2022 at 10:24 AM
    HamHands
    Those are my factory stainless running boards, powder coated black :D
    1794TX likes this.
  16. Jan 31, 2022 at 11:28 AM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    Wish I had the balls to do this... My truck could be so much better. So many mods...
  17. Jan 31, 2022 at 11:39 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Put some cotton balls soaked in peppermint oil under the hood. I decided to do this because my neighbor found a rats nest and chewed wires under the hood of his ‘20 Tundra limited last week.
    On startup, I get a faint whiff of peppermint. Kinda nice actually!
    welshmike, Pangaea and RainMan_PNW like this.
  18. Jan 31, 2022 at 11:47 AM
    Rocko9999
    Not as hard as it looks-just tedious. Took about 2.5h to stip it down to this. That's not rushing, drinking coffee while doing it.
    Long Duck Dink likes this.
  19. Jan 31, 2022 at 11:51 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    I wouldn't be worried about the tear down, I'd be worried about putting it back together...correctly.
    jclem65, Ranger2005, romad86 and 2 others like this.
  20. Jan 31, 2022 at 12:14 PM
    Rocko9999
    It's pretty self explanatory. All seat bolts except 2-that keep rear seats together-are the same. Seatbelt bolts are same. Panels all snap back-no screws. Front seat-3 electrical connectors, middle -1, passenger 3. Amp for stereo 2 plugs.
  21. Jan 31, 2022 at 12:29 PM
    Rolling Biome
    Rolling Biome New Member
    Denver, CO
    2019 Tundra CM Limited TRD Off Road
    Swapped out my Camburg UCAs for Total Chaos to back off the caster.
    The Camburgs will show up for sale soon. Only had them on for about 4k miles of mostly pavement use so they're in great shape.
  22. Jan 31, 2022 at 1:10 PM
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    As DCB500 said, just install it over the top of existing soundproofing. It took me 2 days to soundproof the floor of my old F-150. I highly recommend this mod.
    Rolling Biome, GarTX526, C.I. and 8 others like this.
  23. Jan 31, 2022 at 1:32 PM
    Rocko9999
    Very nice. What did that cost you and was there any residual smell after?
  24. Jan 31, 2022 at 2:08 PM
    Fergie
    Fergie New Member
    Installed a FRAC...but no F, so...just the RAC:
    And also installed the tow mirrors:
  25. Jan 31, 2022 at 2:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    Ordered some new Denso Power Iridium IKH22 spark plugs from URD.
  26. Jan 31, 2022 at 2:30 PM
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    Roll-N-Lock series A (aluminum) is on:
    GarTX526, nhw544, SMTundra and 10 others like this.
  27. Jan 31, 2022 at 2:32 PM
    RobertD
    Robert
    DFW, Texas
    Looks good!
  28. Jan 31, 2022 at 3:41 PM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    So is there a video somewhere on how to screen the hole off or where the hole is located on the firewall? Now I'm paranoid after reading this!
  29. Jan 31, 2022 at 3:42 PM
    There is a thread with some good pics on it. Just search rodent and you will find it.
  30. Jan 31, 2022 at 4:48 PM
    JC21Tundra
    JC21Tundra If I'm not here, I'm somewhere else...
    Jeff
    St L Missouri
    2021 MGM Tundra Crew Cab TRD Sport 4x4
    Do you have any more pictures of this installed, really interested in how it fits at the sides? (edges of the cover)
    It looks good and the install looks by far the easiest.
    Been driving for a year with a towel covering the chrome waiting.
    I used Meso stuff on my old Tacoma been waiting for him to have his parts ready for sale but I am about to give up.
    I do not like the bolt heads on the AJT, just anther place for crud to collect.
