Wheel size
Discussion in '3rd Gen Tundras (2022+)' started by damnfingers, Jan 31, 2022.
  1. Jan 31, 2022 at 7:09 AM
    damnfingers
    damnfingers [OP] New Member
    Gene
    Can someone tell me why there are two wheel sizes offered for the Tundra, 18’s and 20’s? It seems like the larger the wheel, the fuller the wheel well looks. Why would you want a smaller wheel?
    Thanks!
  2. Jan 31, 2022 at 7:28 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Do the 20s not have a smaller sidewall and thus the same overall diameter of the tire?
  3. Jan 31, 2022 at 7:34 AM
    Outbound
    Aaron
    Northern Alberta
    Big wheel = less rubber = rougher ride. Plus big wheels look stupid too. I hate big wheels as much as I hate chrome. 18" is as big as need, 17" is better.
  4. Jan 31, 2022 at 7:39 AM
    damnfingers
    Gene
    I hate “BIG” wheels also but 20’s aren’t “BIG”. My Venza and my Tacoma both have 20’s and they look fine…plus the ride is great.
  5. Jan 31, 2022 at 8:07 AM
    wired
    wired New Member
    2022 Tundra Black SR5
    If you are going to off-road more than just 'dirt-road' or 'muddy-road' more sidewall on the tire (smaller wheel size) enables you to air down more and increase traction. So traditionally off-roaders want 17 or 18". The Capstone trim has 22" wheels. Screams "pavement princess" to me.
  6. Jan 31, 2022 at 9:27 AM
    xc_tc
    xc_tc New Member
    Yep, all the tires are the same overall diameter despite the wheel diameter.
  7. Jan 31, 2022 at 10:04 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    as usual with this topic, it is a lot over-exaggerated when considering 17-20" wheels.
    if you're the type that is going to air-down on the trail then by all means buy smaller wheels and big rubber. If you're like the 99.999% majority of us that only occasionally leave the asphalt, get whatever floats your boat.
    to be honest, tire and wheel availability are the most relevant considerations when choosing wheels size. the bigger you go, the less options you find so just be sure your tires are available in the size of wheel you pick.
  8. Jan 31, 2022 at 10:30 AM
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    Also expense comes into play the larger diameter the more expensive everything gets
  9. Jan 31, 2022 at 2:42 PM
    damnfingers
    Gene
    Thanks, excellent answer…
  10. Jan 31, 2022 at 8:05 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    This.. and ride quality. Same size same brand different rim size= rougher ride with large wheel size- less sidewall flex
