Rear diff fluid after 58k miles w/pics
Discussion in 'General Tundra Discussion' started by Sumo91, Jan 30, 2022.
  1. Jan 30, 2022 at 4:24 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Just changed my rear diff fluid, I was running Schaeffers 75w90 full synthetic. 58k miles on fluid, 234k on truck. I did tons of towing during this interval, and I'm pretty hard on my truck. Lots of offroading too. The fluid smelled just like it did whenever I poured it in, and didn't seem to change color much, the Schaeffers has a slight green tint to it from the bottle, which I can still distinguish. The magnet had fine particals on it, zero chunks. I took a sample to send to Blackstone, but after seeing how good the fluid looked and smelled, I'm certain it will be a waste of money.
    I switched to High Performance Lubricants 75w90 for this interval.20220130_172407.jpg 20220130_172436.jpg 20220130_180306.jpg 20220130_180418.jpg
  2. Jan 30, 2022 at 4:28 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    nice
    Sumo91[OP] likes this.
  3. Jan 30, 2022 at 4:30 PM
    Retired...finally
    Is 58K about your normal change interval?
    Metro14536, 2mchfun and Sumo91[OP] like this.
  4. Jan 30, 2022 at 4:56 PM
    Sumo91
    TN
    I got the truck with 172k on it, changed the fluid at 175k. I think the previous owner may have had it changed once or twice. I'd have to go through the service records.
    I'll probably go 75k+ on this fill.
    Metro14536, 2mchfun and ColoradoTJ like this.
  5. Jan 30, 2022 at 5:08 PM
    Once you use some good quality gear lube, hard to go back when you get great results like this.
  6. Jan 30, 2022 at 6:13 PM
    Sumo91
    TN
    They have some really great lubricants, they also make the best grease I've ever used, and many other will attest to that.
    What the hell, ill send the sample in this week, just for fun.
    I switched to HPL because their oils are even better than Schaeffers ( and Amsoil) :crapstorm:, and they have the best damn customer service, the owner is more than happy to talk oil with you. They made a special batch of 75w for my transfer case, tested it, made a special label, and just charged me gear oil price. You can't beat that with a stick.
  7. Jan 30, 2022 at 6:20 PM
    I will have to check them out.
    With all that money you make….surprised an oil sample doesn’t go out monthly. ;)
  8. Jan 30, 2022 at 6:39 PM
    I checked out HPL. I may have to look into some lube.
  9. Jan 30, 2022 at 6:41 PM
    Sumo91
    TN
    My oils are good enough that I don't need to send them out often :D
  10. Jan 30, 2022 at 6:58 PM
    Well with the mileage you have on the Tundra, hard to argue with that.
    Sumo91[QUOTED][OP] likes this.
  11. Feb 1, 2022 at 6:58 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    What's this sending out of oil? I've got a 2015 with 83k... is there something special I need to do?
  12. Feb 1, 2022 at 7:07 PM
    Dan, Blackstone will send you a kit, take oil sample, return and they will test the oil and give you a report.
    AnonVet[QUOTED] and Sumo91[OP] like this.
  13. Feb 1, 2022 at 7:08 PM
    Sumo91
    TN
    Sending it to Blackstone labs or another lab of your choice to get the oil analyzed, they test for wear metals, additive, and TAN and TBN if you want it, which tells you the acidity and how much additive your oil has left
  14. Feb 1, 2022 at 7:09 PM
    Sumo91
    TN
    Beat me to it by a minute!
    AnonVet and ColoradoTJ[QUOTED] like this.
  15. Feb 1, 2022 at 8:10 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Damn I had no clue!!!! I'll have to do that just for my own 2 cents! Good to hear from ya also brotha! Been a while.
  16. Feb 1, 2022 at 8:12 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Is there a sure fire interval to change out the diff fluids? Or is it more of a function of the 4x4 use?
  17. Feb 1, 2022 at 9:00 PM
    Sumo91
    TN
    The front diff isn't under load unless in 4x4, so the fluid doesn't really get much wear from normal driving since there isn't any pressure between gears, but most people change both at the same time because it's easier to document. I didn't change my front diff fluid yet because I'm restoring a drill press and don't have the shop space.
    If you want to get a good idea of how long your diff fluid will last, take a sample from the fill plug and send it to Blackstone, just refill whatever you take out. They'll tell you if it's still good to run or not, and give you a mileage at which to send another sample for testing. I'll post one of my random UOAs so you can get an idea.Screenshot_20210809-090229_Acrobat for Samsung.jpg
  18. Feb 1, 2022 at 9:29 PM
    Jesus it has been a long time shipmate! Hoping TX is treating you and the family well.
    Anything new?
  19. Feb 2, 2022 at 2:14 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Special batch??
    Tell us some about the special needs.
  20. Feb 2, 2022 at 8:20 AM
    Sumo91
    TN
    The 14-21 tundras require 75w for the transfer case
  21. Feb 2, 2022 at 9:17 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Job is still kicking my ass and baby number 3 is on the way... I'll try not to hijack this dudes post lol
  22. Feb 2, 2022 at 9:22 PM
    Ah, DJ don't mind. He is a really good guy. Met him and his GF out on a trip to CO.:thumbsup:
    You have been busy. Amazing how not being gone all the time can increase the chances of a bigger family!
    Are you thinking about getting a test done for your Tundra?
  23. Feb 7, 2022 at 11:02 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    You're telling me. Life is awesome though!
    I think testing it wouldn't hurt. I've had it since it had 3 miles on it so anything that could be wrong with it would be my own damn fault. I didn't even know the testing was available... this site helps with odds and ends with stuff like that.
  24. Feb 7, 2022 at 12:35 PM
    This site rocks for information. Not one day goes by that I don’t learn something new.
    Check out High Performance Fluids as well. The next time my truck comes due for axle/transfer case fluids, I’m going that route. That says something since I run AMSOIL. Some tests to Blackstone will be sent out for analysis as well. That should be at 100K miles. I’m at 74,500 miles now.
    Been looking at the new Hybrid Tundra in Limited trim (at least) pretty hard. Retire in a couple years and could use a good reliable tow rig for traveling North America with a 18’ “something” in tow.
  25. May 21, 2022 at 6:26 AM
    Sumo91
    TN
  26. May 21, 2022 at 6:34 AM
    Sounds like a good report!
  27. May 21, 2022 at 6:41 AM
    Sumo91
    TN
    I'm gonna be curious about the next report. I might sample it at 50k, so gimme a couple years lol
  28. May 21, 2022 at 10:15 AM
    Blue Thunder
    Washington
    Interesting. Guess the additive pack held up and the wear is about double the average. Which makes sense given the average sample is half as many miles.
