2019 Tundra hard start.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Deno, Jan 30, 2022.
  1. Jan 30, 2022 at 9:30 AM
    Deno
    Deno [OP] New Member
    Deno
    2019 Tundra hard start in morning. Exhaust heavy with fuel smell. Also, burning oil. Down 1 quart in 5k .
    no
    Early morning cold starts my Tundra chugs when it tries to start. (Remote start) The smell of excess fuel barrels out the pipe. Also, I noticed it's down 1 quart of oil @ 5k. Engine only has 10k on it. Could it be a stuck fuel injector?
  2. Jan 30, 2022 at 10:00 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Alcohol density sensor. There is a tsb for hard starts on flex fuel motors. It’s a simple update to the ecu.
    As far as the oil, how are you determining you’re a quart low? The dipstick isn’t all too accurate. Unless you see blue smoke or have drips under the motor, Ide say nothings wrong and it’s most likely not burning or leaking oil.
  3. Jan 30, 2022 at 11:10 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    ^Echo TSB for FFV fuel pump/alcohol density for starting issue
    Using 1 qt every 5k is within allowable limit by most manufacturers specifications. Check for leaks just to be sure. Let truck sit for a few minutes before checking level. Did you change it last? If not, are you sure whoever did put the correct amount in?
