  1. Jan 28, 2022 at 5:54 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    You preheat the cab, do as much as you can do inside and rethink anything that involves open door, lol. Takes 5 x longer but hey, argent we all hooked to make our rides better? I got my tow mirrors in but I'm waiting for warmer temps before I even think of touching them.
    joseph_womack, B.Ross and 20GR8 Super like this.
  2. Jan 28, 2022 at 6:23 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Seeing that oil door on the TRD skid plate is making me strongly think about adding that. My next mod when I get time, alternatively, is to cut open a slot where I can access the oil filter. Cheaper, but doesn't look as nice.
  3. Jan 28, 2022 at 6:47 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I'd like to personally thank the idiot at Toyota who decided it was a good idea to make us drop the entire skid plate every time we need to change the oil. Its obvious that Toyota already had the engineering to make the access hatch but chose to just frustrate everyone. :censored:
  4. Jan 28, 2022 at 6:49 AM
    chrisf111
    chrisf111 New Member
    Got my check engine light fixed. Had been throwing lean codes on both banks since I got it 2 months ago. Looks like the previous owner was a bad DIY mechanic. Shop replaced the fuel pump and said the pump that was in there was either some unknown brand or just the wrong model for the truck. They said I was getting some fuel pressure, but not nearly where I was supposed to be.
    $800 later I'm back on the road.
  5. Jan 28, 2022 at 10:33 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Did you do this yourself? I've had one rear window I need to check...rolls down slowly, and then kind of gets a little lopsided and then stops higher than the other side. I figured the slow roll-down for the other windows was because it was -14 and crudded up from the winter...but maybe it's worth looking at replacing them?
  6. Jan 28, 2022 at 10:41 AM
    CultusRanger
    CultusRanger New Member
    Zack
    2011 double cab TRD off road
    What kind of tow mirrors did you go with? I’ve been looking at some for my 2011 double cab
  7. Jan 28, 2022 at 2:15 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    Replaced my tailgate latch handle. The old one had a broken fastener receptacle and the remaining ne gave out last week. Good as new now. Went with the dealer part. Spent 40.00 more than online alternatives but I know it's not a knock-off passing as oem . Plus I got it same day.
  8. Jan 28, 2022 at 4:53 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Deck seals installed on roof. Tomorrow, I'll start running wires through them. Have them up there now to keep the dust out when I drive up to do my checks of the logging site tonight.
    I also did some sound deadener. Tomorrow, I'll finish it up with the foil backed foam. Used Siless 120mil foil backed butyl and Siless 157mil foil backed foam liner.
  9. Jan 29, 2022 at 7:12 AM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    I didn’t think Garmin’s still existed. You must do a lot of driving in the middle of nowhere.
  10. Jan 29, 2022 at 11:48 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Replaced the battery in my Tundra today. It's been real sluggish on cold morning starts for a month or so, and had to be jumped a handful of times. Date code on the old battery was August 2009. :eek2:
  11. Jan 29, 2022 at 1:34 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I like those ScanStrut seals (had to google them). What are you wiring up?
    joseph_womack likes this.
  12. Jan 29, 2022 at 2:39 PM
    Retroboy1989
    Northern Utah
    Wow. Most on here complain about the OE battery.
  13. Jan 29, 2022 at 7:56 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Put on Desert Eagle Cat Shield and 1/8" diamond mesh for rear , I was told some trans are heating up from solid covers in both areas. Mesh laid right up nicely. Got plate in 3 days. IMG-1626.jpg IMG-1627.jpg
  14. Jan 29, 2022 at 8:03 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    What kind of area do you live in where you need to put protective shields on your cats? Or is this protection for off road purposes?
  15. Jan 29, 2022 at 8:08 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Northern IL, but have been hearing alot on news and nearby cities random thefts, just other day they stole all the cats off the buses at a school of hope ministry. For the price I just don't want to chance it, and am going to do alot of traveling this spring and summer.
  16. Jan 29, 2022 at 8:28 PM
    Retroboy1989
    Northern Utah
    Finally snuck out to the garage to install a pair of sumo springs I picked up used from a fellow tundra owner.
    First impression is no noticeable change in ride quality, possibly because the springs are already worn in. The top of the sumo lightly contacts the frame with an empty bed. I do have a snugtop cap on 6.5ft bed, so that is a couple hundred lbs.
    And for you warm climate folks, no comments on the rust, that's just life for us. My truck is very light on rust for being 10 yrs old in Utah.
    Re-used original U bolts and set them to 80ft lbs. Thoughts on that?
  17. Jan 29, 2022 at 8:39 PM
    TundraCarter
    TundraCarter New Member
    Finally changed the diff fluid and did the breather mod, word of the wise, get more hosing than you think you need, I was barely able to make it work with 6 feet
  18. Jan 30, 2022 at 5:26 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    It's starting to become more common around here in WI. I can't even imagine what it's like in bigger cities.
    The up side is we don't have any sort of emission testing around here, so if it happens, a straight pipe would be in my future.
  19. Jan 30, 2022 at 5:32 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    "HATE", "HATE", "HATE"!
    Two thinks I HATE more than anything are LIARS and THIEFS!!!
    :oldglory:
    O.
    S.T.
  20. Jan 30, 2022 at 6:55 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Seems to be a Nationwide problem with cat thefts.
  21. Jan 30, 2022 at 7:11 AM
    nags
    nags New Member
    Swapped the headlights. But this was yesterday, so maybe I'm cheating.
  22. Jan 30, 2022 at 7:53 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    I can’t believe there is a catalytic converter black market.
    beautiful truck @nags BTW!!!
    joseph_womack and 20GR8 Super like this.
  23. Jan 30, 2022 at 8:04 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    What kinda lights are the old ones you swapped out? Alpharex?
  24. Jan 30, 2022 at 8:07 AM
    nags
    nags New Member
    Yep. Alpharex. The previous owner installed them right before I bought the truck from him and I was just never a big fan of them.
  25. Jan 30, 2022 at 9:02 AM
    Retroboy1989
    Northern Utah
    It's the valuable metals they contain. There is a lot of money in stolen cats.
  26. Jan 30, 2022 at 12:42 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    but are they being sold to people who need a catalytic converter for their car, or are they taking them to a salvage/recycling yard? I’m so confused.
    I wonder if the people buying these catalytic converters know that they are stolen
    i live near Tampa and haven’t heard of this locally thank God
  27. Jan 30, 2022 at 12:46 PM
    omgboost
    East Coast
    The scrap yards well know what's happening and they don't care. If they don't buy it, they not able to resell it, make any money, and the thieves just go to another scrap yard. It's sad but that's the reality of things nowadays. Can't ever have nice things.
    Ohannon7[QUOTED] likes this.
  28. Jan 30, 2022 at 1:00 PM
    SilverSkySurfer
    SilverSkySurfer DIY till ya die
    Augusta, Georgia
    2012 Silver Sky DC SR5 4.6L 2WD
    Method Con6 Wheels, LED Swap, LED taillights, BAM 8” exhaust, Eibach Spro sport leveling front shocks, AJT Shift knob and AC controls, Cover king seat covers, husky floor liners, color matched mirror caps and door handles, retrax bed cover, shorty antenna, D ring tow Shackles, rear TRD sway bar, JVC KW-Z1000w head unit, Morimoto Fogs, Alpharex Headlights
    decided to switch up the wheels to something different
  29. Jan 30, 2022 at 1:12 PM
    PayItOff428
    Jake
    Just about every major liberal city! Have you been under a rock bro! Voting has consequences.
    Trooper2, joseph_womack and Ohannon7 like this.
  30. Jan 30, 2022 at 1:46 PM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    Titanium in those cats is what I heard, or some type of metal.
    Correct me if I'm wrong.
    O.S.T.
