Hybrid mpg
Discussion in '3rd Gen Tundras (2022+)' started by Dstrahan, Dec 5, 2021.
  1. Jan 26, 2022 at 5:08 AM
    #121
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Those BEV batteries are lithium but I am not sure about the Prius hybrid. Although the Prius plug in version almost certainly is Li and much bigger than the plain hybrid model. I'd really like to see a plug-in hybrid Tacoma.
    As for the Tundra... As a baseline I'd go do the math to see how long its 1.9KWh battery will run the ~50 HP electric motor at full power. But no need. The answer is simply "not very long".
    Saltyhero13 likes this.
  2. Jan 26, 2022 at 5:17 AM
    #122
    raylo
    Frederick, MD
    I had a Prius rental once on a business trip and was thoroughly impressed. Unbelievable MPG. And the driving experience was fine.
    Mattedfred[QUOTED] likes this.
  3. Jan 26, 2022 at 6:22 AM
    #123
    raylo
    Frederick, MD
    I have friends that own a pair of his and hers Prii, as they call them. They also love them. One of these days I'll probably sell my Vette... I love it but it is really just a toy... and get something electrified. Not sure yet if it will be battery or hybrid but needs AWD. Maybe even something like the Mustang Mach E? I dunno.
    Meanwhile I just saw on Car and Driver that the 2023 Sequoia is being dropped soon and of course since it is on the same platform as Tundra it will essentially be a Tundra with a full body. The one interesting point is that it will only come with the hybrid iForce Max powertrain. They also say that MPG is not yet available.
    2023 Toyota Sequoia Arrives with a Standard Hybrid Powertrain (caranddriver.com)
  4. Jan 26, 2022 at 6:36 AM
    #124
    Jonross227
    Jonross227 New Member
    While I don't expect the hybrid to get much over the motor only trucks, I do wonder if we'll see big improvement in mpg with lifts, bigger tires, and towing.
    Say motor only ends up being 16 mpg on 35's. With the way the system adds power it's possible the hybrid could be 18-19. Same when towing.
    DexterL likes this.
  5. Jan 26, 2022 at 8:49 AM
    #125
    xc_tc
    xc_tc New Member
    Let’s assume it takes full power to drive 35 mph, 1.9 kWh will get you 1.8 miles.
    math is (1.9 kWh /36 kW)*35mi/h = 1.85 mi.
    Definitely can drive the Tundra iforce max more than 18 mph in EV mode. The system is completely different than the Prius. The newest Prius drivetrain was redesigned to allow EV mode in higher speeds. The EV mode max speed is a function of the motor speed and power available from the motor. The CVT forces the motor to spin at high speeds and low torque. Whereas the Tundra electric motor will spin at low rpm and keep high torque to maintain speed.
  6. Jan 26, 2022 at 9:30 AM
    #126
    raylo
    Frederick, MD
    Sounds reasonable. But you'd never get that in the real world. Battery capacities are calculated to totally empty, a state which the BMS or other firmware will prevent you from reaching to avoid damaging the battery. So about 20% less is a good starting assumption. There is also the matter of max current, say accelerating or going up a hill before the ICE kicks in. Again the truck's systems are going to limit that, especially considering this is a NiMH battery.
  7. Jan 26, 2022 at 9:39 AM
    #127
    xc_tc
    xc_tc New Member
    Yeah that’s for sure. Let’s assume you can use ~40% before the engine turns on to charge the battery, then range is only 3/4 mile. In my experience with F150 Powerboost I found it hard to accelerate with just electric motor. But it was easy to back off and cruise at 40 mph in electric. I expect Tundra to be the same. But after battery is drained, the engine stays on for awhile. Still, electric motor is adding power when it is needed based on what’s shown on the power flow screen.
    Pattington22 likes this.
  8. Jan 26, 2022 at 1:46 PM
    #128
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    This is my hope as well- erases 35's, lift, topper, rack and gets stock numbers.
  9. Jan 26, 2022 at 3:54 PM
    #129
    Blitz79
    Blitz79 New Member
    Yes I meant 0-18 mph. It is not wrong, the Sequoia release has the same information about the iForce Max.
  10. Jan 26, 2022 at 4:20 PM
    #130
    xc_tc
    xc_tc New Member
    Yeah, I know what the Toyota information says. I don’t think it’s right, but we’ll have to wait until someone actually tests this out in a Tundra hybrid. My reasoning is this:
    • F150 hybrid can hold 50 mph in electric only on flat road
    • F150 hybrid electric motor spec is identical to the Tundra hybrid motor spec (both 36 kW)
    • Tundra is heavier but not by much so will require similar driving torque to keep a constant speed on flat road
    I don’t see any reason why the electric only cruising speed can’t be 30 or 40 mph.
    In this video at 5:00 we can see the speed is ~23 mph and the tach is at ~1200 rpm. A few seconds later the tach needle disappears and goes to 0 rpm, meaning electric only driving, and he keeps cruising around 23 mph. https://youtu.be/QjztMrF3mUs
    =JSG= likes this.
  11. Jan 26, 2022 at 4:27 PM
    #131
    xc_tc
    xc_tc New Member
  12. Jan 28, 2022 at 8:53 AM
    #132
    Blitz79
    Blitz79 New Member
    I don't know what to tell you other than that is what Toyota is saying. They can lock it down to 0-18 on the computer even if the motor is capable of doing more. Also, the video is a pre-production Tundra. In any case, 3 more days and we will know for sure :thumbsup:
  13. Jan 28, 2022 at 9:02 AM
    #133
    raylo
    Frederick, MD
    In 3 days we'll have the EPA numbers... finally!... then another typical wait for "real world" MPG data to trickle in as testers and eventually customers get their hands on. More data is good but it'll be awhile for the final answer.
    Mattedfred likes this.
  14. Jan 28, 2022 at 2:04 PM
    #134
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    FWIW….Spoke to My Salesman today. He just returned from Tundra Training. Wouldn’t say Hybrid MPG, but grinned and hinted EPA will be 25-27? Also Hybrids will be out sooner than expected..“Early March”
    Bob_Loblaw and skynyrd87 like this.
  15. Jan 28, 2022 at 2:13 PM
    #135
    skynyrd87
    skynyrd87 New Member
    Flagstaff, AZ
    We will also get pricing on Monday, right?
  16. Jan 28, 2022 at 2:16 PM
    #136
    MTRock
    MTRock 1889
    Montana
    He wouldn’t say when pricing and EPA numbers would be available.. And said the Hybrid option was “Less $” than he expected? Again wouldn’t say $$$.
  17. Jan 28, 2022 at 3:32 PM
    #137
    WPTundra1794
    WPTundra1794 New Member
    Scott
    2022 Tundra 1794
    i called two dealerships in Orlando and spoke with two different salesman. Both were total guesses but one said 25 combined and one said 28 combined. Also told me hybrid availability not until late spring- early summer.
    MTRock likes this.
  18. Jan 28, 2022 at 6:32 PM
    #138
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Well, apparently every salesman went to a different training session…
  19. Jan 28, 2022 at 6:35 PM
    #139
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    None of those dumb asses knows.
    basian99, 9OH1, Pattington22 and 3 others like this.
  20. Jan 28, 2022 at 6:54 PM
    #140
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    How do you like a comment more than once?
  21. Jan 28, 2022 at 7:03 PM
    #141
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Quote it more than once.
  22. Jan 29, 2022 at 3:27 AM
    #142
    raylo
    Frederick, MD
    LOL... These salesmen aren't the brightest crayons in the desk... and probably didn't even pay attention to the training.
    trazerr[QUOTED] likes this.
  23. Jan 29, 2022 at 4:41 AM
    #143
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Also, anyone who believes a salesman…I have some wonderful beachfront property in Kansas for sale. Call me.
    Henry1jg and 9OH1 like this.
  24. Jan 29, 2022 at 4:42 AM
    #144
    raylo
    Frederick, MD
    LOL... or maybe some nice beachfront on Grand Island Nebraska.
  25. Jan 29, 2022 at 8:04 AM
    #145
    xc_tc
    xc_tc New Member
    If Toyota had released a Tundra with the V6 hybrid system that was in the Highlander, maaaaybe 30 mpg was possible but the truck would be shit to drive.
  26. Jan 29, 2022 at 8:16 AM
    #146
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Don't know if anyone's seen this yet but...
  27. Jan 29, 2022 at 8:24 AM
    #147
    trazerr
    trazerr New Member
    Oregon
    I-Force = gas only
    I-Force MAX = Hybrid
  28. Jan 29, 2022 at 9:50 AM
    #148
    raylo
    Frederick, MD
    Highlander hybrid ICE part is a 4 banger. It doesn't share the V-6 with the rest of the Highlander lineup.
  29. Jan 29, 2022 at 10:11 AM
    #149
    xc_tc
    xc_tc New Member
    The previous gen highlander hybrid, changed to a 4 cylinder in 2020.
  30. Jan 29, 2022 at 1:58 PM
    #150
    Blitz79
    Blitz79 New Member
    Not sure what's the heart burn of comparing the Tundra with the highlander numbers. The fact that the Hybrid Highlander has a smaller 4 cylinder engine gives me even more hope that the tundra numbers will be better than the 21MPG rumored here. It means the electric motor that size is even more capable than I expected.
