2011 5.7L. New alternator, but Red Battery warning light is on.
Discussion in '2nd Gen Tundras (2007-2013)' started by tbean100, Jan 27, 2022.
  1. Jan 27, 2022 at 5:44 PM
    tbean100
    tbean100 [OP] New Member
    My Mech put in three alternators thinking that the problem was the alternators. Last, but in an OEM 150A alternator, but the red warning battery light still wil not go off. Had it diag. at Toyota dealer and found no faults but the light is still on. WTF here. Can someone help out?
  2. Jan 27, 2022 at 5:57 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Try disconnecting the battery for 15min? Let it reset? No codes?
  3. Jan 27, 2022 at 6:43 PM
    tbean100
    Disconnected for an hour. Let it reset. Then plugged in and no codes. Still red.
  4. Jan 28, 2022 at 6:30 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Shot in the dark...could it be grounding issues? look at the grounding wires.. I dont know where they are located in the truck but I am sure others here can guide you on that..
    B.Ross and Sean492 like this.
  5. Jan 28, 2022 at 6:47 AM
    tbean100
    Well I had the pinion, power steering pump, serpentine belt and alternator changed. - did the alternator as PM as the old one had 150K on it was was soon to go. I took this to Toyota dealer and they hooked it up to their computer. It showed no fault, no grounding issues and everything was A-OK. Is there an alternator solenoid in the fuse box? I am checking this out. If the battery and or truck was not grounded I am not sure this would effect the battery warning light. It is strange that this light is on and everything has checked out ok at the dealership, they could not explain it. I have checked the grounding wires and I see nothing is disconnected. Thing is this happened after two good alternators where put in it, my old one did not fault it was replaced before any warning light was on. It came on after two new alternators where put in. The battery is getting charge. everything is as it should be, biut there is a fault light.
  6. Jan 28, 2022 at 8:50 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I don’t have a wire diagram for this year but usually the warning light is a separate circuit from the charging circuit. I would guess a fuse or disconnected (broken?) wire on the indicator circuit if it is charging. Maybe a pin in the connector got bent.
    Looking at the wire diagram for my 2008 I would check the indicator fuse first. Then check the connector. Then the circuit itself.
  7. Jan 28, 2022 at 11:16 AM
    baraynavab
    Atlanta
  8. Jan 28, 2022 at 2:16 PM
    tbean100
    There is a wiredia on this blog. Issue is I cannot find the Charing Warning light in the 450+ pages on the document...
  9. Jan 28, 2022 at 2:26 PM
    tbean100
  10. Jan 28, 2022 at 2:41 PM
    huntertn
    huntertn New Member
    Tennessee
    2AAA31F9-C04D-4E6C-92F4-13E195724C05.jpg Page 130. Same as the 2008.
    baraynavab likes this.
