Are the square-U bed tie downs universal?
Discussion in '1st Gen Tundras (2000-2006)' started by jnqpublic, Jan 27, 2022.
  1. Jan 27, 2022 at 1:10 PM
    jnqpublic
    jnqpublic [OP] New Member
    SW WA
    04 Tundra, access cab, SR5, 4.7, 4X4, automatic, with TRD.
    Are the square-U tie downs found in the front and rear of Toyota pickup beds universal?
    ie. Can I salvage a couple square-U tie downs from most any Toy pickup bed, including the mounting bolts, and expect them to fit my '04 Tundra bed?
    I'm missing my 2 front tie downs in my '04, access, 4.7, 4X. Truck came that way a few months ago when I bought it used.
    My former 1/2 size '94 Toy (no model name) pickup which had the same, in my memory, tie downs, sold before I got my Tundra, so didn't have the option of switching out from it if they had fit.
    Anyone have a couple of these square-U tie downs with attachment bolts for sale or give away?
    Me, SW WA.
  2. Jan 27, 2022 at 6:25 PM
    daveeasa
    The Tacoma ones are just a tiny bit different. I wanted to swap mine out with Charvonia ones. If someone can mill my fancy ones, I’ll gladly give away the oem set.
    5N0W808 likes this.
  3. Jan 27, 2022 at 6:50 PM
    daveeasa
    Yeah just like 1mm too tight.
    E5BA71B1-59E8-4367-9D21-49304770DA55.jpg 9469CE59-7387-4C3C-AEEE-CD74B6FC0AB9.jpg
  4. Jan 27, 2022 at 6:56 PM
    daveeasa
    Neighbor does have a press, it's on the list but hasn't bubbled up yet. I think some precision milling would be better than a hand drill.
    5N0W808[QUOTED] likes this.
  5. Jan 27, 2022 at 6:58 PM
    You just need a step bit ("unibit")
    Riverdale21 and 5N0W808 like this.
  6. Jan 27, 2022 at 7:01 PM
    daveeasa
    I think you of all people would understand my desire for perfection here :)
  7. Jan 27, 2022 at 7:29 PM
    I get it, but it's still a truck, and it's just a tiedown ;)
  8. Jan 28, 2022 at 12:27 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Is it just the base hole that needs to be opened up, or does the pocket area as well (where the bolt or allen head is)?
  9. Jan 28, 2022 at 1:54 AM
    jnqpublic
    SW WA
    Me thinks if I had those square-U tie downs, I'd attempt to spread the U open that 1 mm, rather than remove any metal.
  10. Jan 28, 2022 at 5:22 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Wedge those screws in crooked and ugga dugga that beast home.
  11. Jan 28, 2022 at 6:04 AM
    Oh wait. I just realized, the rusty ones aren't the ones @daveeasa is wanting to install. I just noticed the black ones from the pic are under the rusty ones and are what he's referencing being off.
    Context is everything.
    Anyway, the hole in the bottom looks waaaay girthier than the one in the base. Still think a stepbit from behind would do the task invisibly.
    daveeasa likes this.
  12. Jan 28, 2022 at 6:45 AM
    daveeasa
    Yeah I want go replace the rusty trombonists hooks with the fancy aluminum ones.
    Clear and coherent I am not. Sorry.
    I might need to remove material for the Allen socket head as well as the threaded portion to get it to fit.
    I did a reasonable ugga dugga at first and I’m quite confident that will result in cross threading at best if not actual sheering on the bed sheet metal. The hooks are beefy.
    I think one drill bit size bigger or (better still) an oval hole by precision mill is the best plan.
    I figured I’d take them to my brother in law’s machine shop this summer, seems like a reasonable project to accomplish without massive effort.
  13. Jan 28, 2022 at 6:46 AM
    daveeasa
    Blasphemy!
    coldcanuk likes this.
  14. Jan 28, 2022 at 7:05 AM
    I think you just need a specialty fastener to make it work. Pretty sure it'll be the 2nd one in the top row here.
    daveeasa[QUOTED] likes this.
  15. Jan 28, 2022 at 7:15 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    The last shop i worked in had one of these on the wall. I’d like to find one to hang on my wall someday, but havent really started looking yet.
    flyfisher, shifty` and daveeasa like this.
