2022 Tundra Slap-a-Patch from the factory.
Discussion in '3rd Gen Tundras (2022+)' started by Dagwood, Jan 27, 2022.
  1. Jan 27, 2022 at 2:00 PM
    Dagwood
    Dagwood [OP] New Member
    After reading up on the turbo thread someone posted a picture of some flat piece slapped on with “silicone” on the inside of the box. I thought Toyota would never do such a hack job. You can’t believe everything you read on the net - right. So tonight I decided to take a peak.
    This is the location, on the inside. Both sides.
    I’m not sure if they are marked “L” and “R”. I also could not find a part number for them.
    I have a lot of mixed feelings right now. I have been a Toyota guy for years. I just spent a lot of money on a new truck. I’m disappointed. I’m pissed. I’m shocked.
    Black@Blue19 likes this.
  2. Jan 27, 2022 at 2:07 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Second!
    Lol. Of all the things 3rd gen tundra or toyota related that could break the camel's back, you choose a piece of what i assume is vibration deadening on the inside of the box side you cant even see.
  3. Jan 27, 2022 at 2:09 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    That might be for vibration dampening/control of the bedsides. Looks slapped in place but there might’ve been a loose tolerance on its placement.
    Mountun Goat and TexAggie like this.
  4. Jan 27, 2022 at 2:10 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Appears to be part of the body, so shouldn't have a separate part #. My guess is it's for re-enforcing in that area of the body possibly to stop vibrations at high speeds.
    jgoliath likes this.
  5. Jan 27, 2022 at 2:10 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    It's plastic with adhesive showing inside the bed panel! It's shocking! Send it back! Happy Friday everyone.
  6. Jan 27, 2022 at 2:12 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why haven't you sold your truck yet?
    =JSG=, FlyingWolfe, Totherion and 3 others like this.
  7. Jan 27, 2022 at 2:12 PM
    Dagwood
    I think that’s what it is as well.
    Yet that is not applied by a robot. It’s a last minute thought and slapped in. I’m concerned the salt from the winter roads will collect behind it and I will have a nice hole in 5-7 years. One side does not look like a 100% seal.
    Warreng likes this.
  8. Jan 27, 2022 at 2:16 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    I can certainly understand the corrosion concern, I would start by taking to the dealer and have them look at it and ask if they can seal it if necessary. At least that's were I would start.
  9. Jan 27, 2022 at 2:23 PM
    yeti23
    yeti23 New Member
    gabe
    2017 SR5
    I thought the bed was an aluminum/plastic composite?
    2mchfun likes this.
  10. Jan 27, 2022 at 2:25 PM
    Dagwood
    Sorry.
    I thought I had legitimate concerns with the truck that I would let other potential 2022 owners know. Never had issues like this on the previous four trucks.
    I have said the mechanical part of the truck is great. Pulls great. Posted real mpg.
    Sorry again.
    Mattedfred likes this.
  11. Jan 27, 2022 at 2:28 PM
    Dagwood
    This is on the sheet metal (aluminium). Inside of the skin. Not on the tub.
    Those in the rust belt will know what I mean about corrosion.
    Tripleconpanna and Mattedfred like this.
  12. Jan 27, 2022 at 2:34 PM
    yeti23
    yeti23 New Member
    gabe
    2017 SR5
    OK, I'm from the southwest and no snow here. But I figured salt wouldn't corrode the aluminum compared to its steel counterparts.
  13. Jan 27, 2022 at 2:41 PM
    randomquickness
    randomquickness New Member
    As others mentioned, it’s to reduce NVH. There for a reason, and that reason sure ain’t to look pretty.
    =JSG= likes this.
  14. Jan 27, 2022 at 2:41 PM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Maybe it’s a hidden treasure map that’ll lead you to the tow hook conspiracy haha.
    PS...Idc about the hooks just couldn’t pass up an opportunity. I’ll have to look at mine when I get it out of the shop
    Mattedfred and Cpl_Punishment like this.
  15. Jan 27, 2022 at 2:44 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Interested to see if yours has it with the shortbed.
  16. Jan 27, 2022 at 3:08 PM
    Rwaters
    Rwaters New Member
    I’m really curious now and then I’ll be able to see it for myself if it’s there
  17. Jan 27, 2022 at 3:21 PM
    Retired...finally
    How would you feel if you found lead sheeting glued to fuselage panels in your Beechcraft Bonanza?
    I even added material like this in the trunk of my 124 Abarth to prevent droning at certain engine RPM.
    =JSG= and Mattedfred like this.
  18. Jan 27, 2022 at 3:43 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    It is entirely possible that the issue was found after production had begun and it was cheaper and easier to have someone at or before the finish/"qc" section put it on. They may have found that at a certain speed, there is a resonance at the front of the bedside that could potentially lead to cracking at the front edge.
    If you are very worried about it causing a problem, there is something you can do. In the summer, thoroughly wash the inside of the bedsides and allow to fully dry. Tape off the bedsides and use either an undercoating or spray on bed liner to protect it.
    A dealer will probably put a bead of silicone over it if you find any issues with the edge not being sealed. I'd do that rather than just doing it myself so there is a paper trail of the "repair".
    Dagwood[OP], Mattedfred and Rwaters like this.
  19. Jan 27, 2022 at 3:49 PM
    xc_tc
    xc_tc New Member
    Remember when Toyota came out and said they would allow blemishes, etc. on parts that aren’t visible to the customer. This is it. No one can see it and it does the its job of dampening bed side resonances.
    Rwaters and Cpl_Punishment like this.
  20. Jan 27, 2022 at 4:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Definitely pull those suckers off and let the bedside vibrate as the designer intended
  21. Jan 27, 2022 at 4:26 PM
    Dagwood
    Guys I’m being misunderstood here. There looks like a gap on the one patch. There is the possibility of road salt getting in there. I’m not happy on how it was installed. Others may have a gap open. Take a look and see. Save yourself some corrosion issues down the road.
    I might pull one off to find that treasure map.
    Mattedfred, jgoliath and Rwaters like this.
  22. Jan 27, 2022 at 4:48 PM
    Berettafan
    Berettafan New Member
    2017 CM
    Good thing they had a rainy day fund built up from all those transmission coolers they didn't install over the past few years! No doubt that.....blob....cost a few bucks that wasn't initially budgeted.
    Retired...finally and 2mchfun like this.
  23. Jan 27, 2022 at 4:55 PM
    jgoliath
    Don’t apologize! Asking questions is not only how each of us learn about our trucks, but how others learn about these trucks too!!!
  24. Jan 27, 2022 at 5:04 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    It's only a "patch" if there's a hole on the outside it's trying to seal. Unless you see a hole on the outside of the bed box...I'm sure it's just vibration control / deadening. You can't even see it unless you crawl underneath & look.
    If there's a gap that would allow road salt in there...run a bead of RTV silicon on it or point it out to a service writer the next time you're at the dealership and they'll do it for you.
    Sorry but I think this is sensationalizing a relatively tiny issue.
  25. Jan 27, 2022 at 5:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    That’s not too out of the ordinary. Hell my first gen has one kinda like that and it was put on sloppy. Before I redid it
    it’s a material designed to absorb the noise of the tinny sheet metal
  26. Jan 27, 2022 at 5:32 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    It acts as a mass damper. Lessens vibration and resonance in that body cavity, as was previously stated, so you can enjoy the ride.
  27. Jan 27, 2022 at 5:36 PM
    Rwaters
    Rwaters New Member
    :deadhorse:
    Vibration/Noise reduction, got it. At the same time, from what I read, his complaint is the quality of the install not why it’s there.
    Lovetrucks, TomC843 and Dagwood[OP] like this.
  28. Jan 27, 2022 at 5:36 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    I gotta stay out of these turd gen threads. You guys are killing me!
  29. Jan 27, 2022 at 5:56 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    That YouTube guy that bought the tundra had the same patch when he videotaped underneath his truck while at a Toyota dealership on a lift. I hope it’s this one. I do remember see it though. Just can’t remember which video
    https://youtu.be/7Si3X_PW8yI
  30. Jan 27, 2022 at 6:06 PM
    pursuit2550
    pursuit2550 New Member
    Sorry but I think this is just as important as anything else on the truck. Especially when people are paying MSRP. What happens to the next guy that’s not in the forums and years from now has a hole on the side of his bed because Toyota did a piss poor job on such a simple piece? What else still hasn’t been found that Toyota skimmed on? They skimmed on the tranny coolers on the 19-21 only to bring back a half azz radiator cooler.
