Lifted Not level, keeping the rake .
Discussion in 'Suspension' started by iceburg, Jan 27, 2022.
  1. Jan 27, 2022 at 8:51 AM
    iceburg
    iceburg [OP] New Member
    2018 CM 5.7
    none yet
    Anyone lift there truck and kept it higher in the back instead of level.. keeping the rake. ? Can I see some pictures?
  2. Jan 27, 2022 at 8:54 AM
    AggiePhil
    College Station, TX
    Absolutely. Or many will at least keep some rake. I believe the factory difference between front and rear is 2". I plan on doing my lift such that I'm left with a 1" difference, keeping about half as much rake as the factory setup.
    iceburg[OP] and WILLINH like this.
  3. Jan 27, 2022 at 9:42 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    iceburg[OP] likes this.
  4. Jan 27, 2022 at 9:50 AM
    2mchfun
    Sits about level if I load about 1k in it.
    Not a great picture to see the difference. Pretty beefy rear susp. too.
    TOYOTRD8 and iceburg[OP] like this.
  5. Jan 27, 2022 at 10:21 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I measured on my 21 SR5 4x4 to be exactly 2.5" higher in the back than the front. I plan to add 2" in the front and 1.75" in the back with CB +3's. I like the rake as well.
    iceburg[OP] and nlaroy like this.
  6. Jan 27, 2022 at 12:05 PM
    iceburg
    2018 CM 5.7
    none yet
    Thank you fellas.
    2mchfun likes this.
  7. Jan 27, 2022 at 12:32 PM
    juice77
    juice77 New Member
    Sacramento, Ca
    2019 SR5 CM TRD 4x4
    3” front, 3” rear
    Toytec Aluma series 2.5 front coilovers with SPC UCA’s
    Toyotec aluma 2.0 rear shock with Toytec progressive AAL and Toytec shackles
  8. Jan 27, 2022 at 6:30 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Rake rocks.:headbang:
  9. Jan 28, 2022 at 12:23 PM
    iceburg
    2018 CM 5.7
    none yet
    Thanks for your feedback fellas , sits much better. 4/3 . Wheels and tires next. 20220128_113542.jpg
    Tundratoofun, 2mchfun and AggiePhil like this.
  10. Jan 28, 2022 at 12:34 PM
    2mchfun
    35's or 37's? Rear gears too?
  11. Jan 28, 2022 at 12:37 PM
    2mchfun
    BTW prepare for sticker shock on the shoes!
  12. Jan 28, 2022 at 12:43 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
  13. Jan 28, 2022 at 12:52 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
  14. Jan 28, 2022 at 4:02 PM
    iceburg
    2018 CM 5.7
    none yet
    Maybe 35s , don't want to fill up to much of the well. I want to have some travel.
    2mchfun[QUOTED] likes this.
  15. Jan 28, 2022 at 4:27 PM
    DSLKSL
    DSLKSL New Member
    Don
  16. Jan 28, 2022 at 5:59 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
