Headlight sockets
Discussion in '1st Gen Tundras (2000-2006)' started by REESE77, Jan 26, 2022.
  1. Jan 26, 2022 at 7:14 AM
    REESE77
    REESE77 [OP] New Member
    Reese
    03' 4x4 v8
    the Previous owner of my truck did some work in the front end, including replacing the headlight sockets. he used basic auto parts store replacements and they are put in with wire nuts. :facepalm:no bueno. id like to solder in some OEM-quality connectors, but i need a few pieces of intel. I need to know what type of sockets the headlights are as well as the corner lights. also where can i find good quality replacements? Thanks for all your help.
  2. Jan 26, 2022 at 7:38 AM
    REESE77
    Reese
    03' 4x4 v8
    I tracked down this piece of info from about 3 years ago.
    there are (2) 9003 sockets
    also (2) 3157a sockets.
    got it.
    now, where can I find quality replacements? everything I can find seems kind of cheap.
  3. Jan 26, 2022 at 7:39 AM
    Try sparksparts
  4. Jan 26, 2022 at 7:44 AM
    REESE77
    Reese
    03' 4x4 v8
    I looked around here and also McGeorge. nothing. I'm looking for a "pigtail"
    something like this:
  5. Jan 26, 2022 at 7:46 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Jan 26, 2022 at 7:51 AM
    REESE77
    Reese
    03' 4x4 v8
    Impressive. thank you! ill add that to my list of options.
    I will see if he has any input. thanks!
    I was thinking maybe @daveeasa or @empty_lord might have some intel as well.
  7. Jan 26, 2022 at 7:55 AM
    +1 maybe @iHacker could help with sourcing connectors.
  8. Jan 26, 2022 at 7:56 AM
    daveeasa
    I can make you pigtails. Photos of what you have right now could help though. I’d be impressed if someone hacked up the corner light connector (3 position straight grey).
    I can also send you my OEM connectors for free, I’m going to chop them off and go with sealed versions to connect to my harness because I don’t anticipate even running without the harness.
    so, post photos and dm me a shipping address? If you are close enough to San Diego I can crimp it for you but chances seem low.
    1lowlife and Taco-Spike like this.
  9. Jan 26, 2022 at 8:01 AM
    REESE77
    Reese
    03' 4x4 v8
    I never expect to make a post online and someone volunteers to start chopping parts off their truck and shipping them to me:rofl:
    You are the man! I am way out in wyoming so the crimp is a no-go. I will get pictures for you tonight.
    shifty` likes this.
  10. Jan 26, 2022 at 8:04 AM
    daveeasa
    If you want to order yourself, the H4’s I like best so far are these from CE auto electric.
  11. Jan 26, 2022 at 8:07 AM
    daveeasa
    So, your call. My H4's are yucky looking and feeling but they would be free to a good home. I haven't yet chopped them and it'll be a short while before I get to it but I like the incentive to get it done.
  12. Jan 26, 2022 at 8:24 AM
    REESE77
    Reese
    03' 4x4 v8
    Interesting, ill give it some thought. Ill post pictures tonight and we can go from there. Thanks again!
  13. Jan 26, 2022 at 8:36 AM
    daveeasa
    What I would do if it were my truck is buy a quality harness and either solder it in or butt connector or amp/weatherpack crimp it. You only need one side for the harness relay triggers. Then cut and heat shrink over the passenger side and zip tie it out of the way.
    Corner light connector trouble i can help you with, I have all the oem connectors for that stuff.
  14. Jan 26, 2022 at 7:26 PM
    REESE77
    Reese
    03' 4x4 v8
    Here’s what I’ve got going on. The turn signals are the same on each side and as I was pulling out the drivers side, a wire pulled out of a connector. I got it crimped back “good enough” but the turn signals are real bad. The drivers side headlight socket is pictured and the passenger side is the stock plug
  15. Jan 26, 2022 at 7:47 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  16. Jan 26, 2022 at 7:48 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I ran one of the cheaper Amazon harnesses. This harness is triggered by your factory headlight circuit but is thicker gauge wire and hooks right to the battery. Works fine for me. From what I understand it's pretty much the same thing @daveeasa is going to make himself with his higher dollar components and fantastic electrical and wiring skills. May have issues with fog lights due to very low load on factory circuit but that would happen with any harness at any price.
    https://www.amazon.com/gp/aw/d/B089M4DC45?ref=ppx_pop_mob_b_asin_title
  17. Jan 26, 2022 at 8:49 PM
    daveeasa
    I’m actually currently running an el cheapo harness myself because I spend all my time crimping for others :).
    I’d go with any harness over no harness and then if it’s cheap just cut and splice but you’ll need to probe to know which color is what on the driver side. Or you could cut and extend to trigger off the good passenger side and just heat shrink over the driver side and ignore it.
    I can do pigtails for the corners but I neglected to document which side is parking light (dim) and which is turn (bright). I believe ground is in the middle, at least on my truck. I’d also prefer to color match so maybe it’s possible to get closeup photos of each of those showing the wire colors and where they go and which is which? If one pulls out that makes it easy and we can assume both sides are the same.
    I’d refer to my truck but it’s 30 minutes away waiting on the leaf pack swap.
    I’m also game for sending my oem H4’s next time I have a moment to harvest them.
  18. Jan 26, 2022 at 8:53 PM
    daveeasa
    I think the empty lord trick for fog light anytime would solve for the harness too. Though I think my useless fog lights still work. I am planning to just use a switch pros circuit once I get that in, unless or until I swap in a new stalk. No way I’m wasting one of those two switch spots on fog lights.
  19. Jan 26, 2022 at 9:31 PM
    REESE77
    Reese
    03' 4x4 v8
    I will probe around with my multimeter and let you know how those turn signals are pinned. I will also do my best to note the colors, though the wires are in a bad spot to examine. I will definitely have you build pigtails for these. I haven’t decided if I’m gonna go with your old h4 pigtails or the new ones.
  20. Jan 26, 2022 at 9:35 PM
    daveeasa
    @Tundra2 if you have a spare moment, would you mind grabbing a halfway decent photo for OP and I so I can be super OCD and try to color-match? I don't think I did that for your OG T harnesses.
  21. Jan 26, 2022 at 10:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  22. Jan 26, 2022 at 10:13 PM
    daveeasa
    Tundra2[QUOTED] likes this.
  23. Jan 26, 2022 at 10:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  24. Jan 27, 2022 at 12:15 AM
    daveeasa
  25. Jan 27, 2022 at 12:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sorry it wasn't easier to find, but atleast that video was short...
  26. Jan 27, 2022 at 12:33 AM
    daveeasa
  27. Jan 27, 2022 at 5:32 AM
    REESE77
    Reese
    03' 4x4 v8
    beautiful! I’ll shoot you a PM when I’m at my desk:yes:
    dbittle likes this.
  28. Jan 27, 2022 at 8:01 PM
    daveeasa
    Hey, checking out my connectors and it's possible I sent you a slightly wrong setup? Not super sure, they are close, but the ones I sent I think are Tacoma SR and I think maybe you need these other ones. I can make a new set, no sweat on that, any chance someone can open one up and verify?
    Sorry if I goofed here (seems like I did)
  29. Jan 27, 2022 at 10:50 PM
    NickB_01TRD
    KY
    You just need a picture of the harness that plugs into the front turn signal housing? If so I can get one when I get off work in the morning if no one beats me to it.
    daveeasa[QUOTED] likes this.
  30. Jan 28, 2022 at 7:07 AM
    REESE77
    Reese
    03' 4x4 v8
    I can also grab one at lunch in 4 hours. those are so similar:rofl:
