Alternator Voltage
Discussion in '2.5 Gen Tundras (2014-2021)' started by NHPig, Jan 26, 2022.
  1. Jan 26, 2022 at 2:06 PM
    NHPig
    NHPig [OP] Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    So, this condition, if you will, only was brought to my attention because I have Drone Mobile and it was warning me about a low battery. It was often 12.1 to 12.2. The battery was replaced about a year and a half ago and O'Reilly's honored their warranty and now I have a brand new battery.
    Both batteries (I suppose the alternator, really) would often never reach a voltage more than 13.9v with the truck running. Often 13.7v, with no large accessories running.
    I know from other threads ( https://www.tundras.com/threads/best-battery.101105/page-3 ) that one observation is that our stock alternator does not go much higher than 14v.
    With that said, general alternator research suggests my alternator voltage is technically low, and would be better to get above 14v.
    While some here are mechanics, I am also interested in hearing from owners.
    Question: During normal driving, where does your alternator voltage gauge hang out? Is my "14, less than 14" average for Tundras? I can tell you that I took a meter to mine, and it is consistent with the reported voltage in Drone. It is also consistent with the dash in the truck.
  2. Jan 26, 2022 at 2:10 PM
    timsp8
    NY
    Around 14 or under is normal for stock. Search for voltage booster. There’s a lot of threads about it. There’s 2 options, hkbelect makes one or get a gm diode for $5. Both replace the ALT-S fuse under the hood. I’ve been using the gm diode for a year with no issues. My truck usually starts around 14.4-14.7 then settles down to 14-14.2 after driving awhile.
    I got the gm diode off Amazon.
    https://www.hkbelect.com/products/toyota?model=tundra&year=2015
    Edit: I should’ve clarified that I have an agm battery.
    Saltyhero13 likes this.
  3. Jan 26, 2022 at 2:12 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    The voltage you're getting for your 2016 is correct for the type of battery that you have - or the type of battery it's supposed to have. If you had an AGM battery (which is not the type that came with a 2016) , then you would need it to be in the 14.5v range.
  4. Jan 26, 2022 at 2:22 PM
    NHPig
    New Hampshire
    Any risk of putting the diode in without AGM battery?
  5. Jan 26, 2022 at 2:22 PM
    Mine runs at 13.7 on my Scanguage. I'll look to see what my other indicators show.
  6. Jan 26, 2022 at 2:34 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Google says:
  7. Jan 26, 2022 at 2:36 PM
    NHPig
    New Hampshire
    Totally get the risk of overcharging. I suppose I should have asked if 14.5v is too high.
  8. Jan 26, 2022 at 2:42 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    @NHPig your alternator is in the normal range for a Tundra.
    If you are running a standard lead acid battery there is only a small advantage with taking the voltage up (to about 14.2) and only if you have accessories like a winch that deep discharge your battery. If you aren’t running any deep accessories just leave it as is.
    A GM diode with a lead acid battery takes the voltage too high and could damage the battery.
