Qi charger, anyone's work well?
Discussion in '3rd Gen Tundras (2022+)' started by Jkeown, Jan 24, 2022.
  1. Jan 24, 2022 at 3:42 PM
    Jkeown
    Jkeown [OP] New Member
    2022 Silver Limited Crewmax
    my Qi charging is flaky at best. the screen is constantly popping up 'phone charging/phone not charging'.
    i have a google pixel 6 pro. i had a pretty beefy case on it, so I got a slimmer one. it's a little better but still doesn't work very well.
    i tried with no case for a bit, seemed to work better (didn't test for too long), but going caseless isn't an option.
    the same phone, either case, charges fine on an old samsung Qi charger that i've had for years.
    pretty disappointing. i guess the charger is 'underpowered'
    cephasiii and charlOOsi like this.
  2. Jan 24, 2022 at 3:48 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Same with my iPhone in my truck, useless option imo.
  3. Jan 24, 2022 at 3:55 PM
    Jkeown
    Thanks. I'll complain about it when I'm in for service. Maybe enough of us do they'll address it *holds breath*. ;)
  4. Jan 24, 2022 at 3:56 PM
    xc_tc
    xc_tc New Member
    Works pretty well with my iphone 12 but it can’t really charge, run Google Maps navigation, and listen to music on Spotify at the same time because the phone gets hot from charging.
    Also, the charging element inside the wireless charger should move to line up with your phone’s wireless charging coil. Maybe it’s not lining up correctly? What happens if you flip your phone 180 degrees?
  5. Jan 24, 2022 at 4:03 PM
    Jkeown
    hah, funny you should mention that. i did try to flip it upside down. initially i thought it was better, but then started to connect/disconnect.
    the silver lining is that this 1st world bitch squeal is the worst thing wrong with this truck. aside from this little issue, love this truck. they nailed it
    Tom, DesmoDoe, snivilous and 2 others like this.
  6. Jan 24, 2022 at 4:15 PM
    Laffingas
    Laffingas New Member
    '22 Tundra Limited - Army Green
    Mine works fine with my iPhone X in a slim case.
  7. Jan 24, 2022 at 4:16 PM
    iamcaseyf
    iamcaseyf New Member
    I saw someone on YouTube bought a Apple MagSafe charger and stuck it to the spot where the Qi charger should be.. worked way better fwiw.
    Jkeown[OP] likes this.
  8. Jan 24, 2022 at 4:23 PM
    xc_tc
    xc_tc New Member
    I keep a USB-C cable in the truck because it charges way faster anyway.
    Hella Krusty and Jkeown[OP] like this.
  9. Jan 24, 2022 at 7:20 PM
    EvilSteve
    EvilSteve New Member
    2022 Lunar Rock Tundra Limited
    I’ve added a USB-C and wished I’d got the QI charger but sounds like most people are nearly maintaining charge at best which is a shame. I might just install an aftermarket one but I’d like to have it work properly.
  10. Jan 24, 2022 at 7:45 PM
    R2theD2
    R2theD2 New Member
    Seattle
    2022 Tundra 1794 TRD Off-Road Lifted - Midnight Black
    TRD Lift Kit TRD Skid Plate TRD Running Boards Nitto Ridge Grapplers (35x12.5) OEM Bed Step OEM Toyota Tonneau Cover (Quad-Fold) 3M Window Tint (matched factory rear) Spray-On Bedliner
    Mine has been fine. I do think the initial Airplay connectivity when you get in is not great…but also my first Airplay vehicle- so is it Toyota or Apple?
  11. Jan 25, 2022 at 7:57 AM
    wired
    wired New Member
    2022 Tundra Black SR5
    That was me in the "What have you done to your..." thread. This one works great. I will run the wires into the console when I get a chance. Would be easy to install a second one if needed. And my Airplay is very fast to connect.
  12. Jan 25, 2022 at 8:24 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Mine worked great with my iPhone X, but it is pretty bad with my new 13. The camera housing holds the phone up a couple of millimeters, and even if it stays in perfect position, the charger eventually goes red.
  13. Jan 25, 2022 at 8:44 AM
    nodak67
    nodak67 New Member
    JR
    the problem with toyota's implementation of a wireless charger is that they only use 2 coils instead of 3. most decent wireless chargers use 3 coils.
    same issue we had in our 2015 tacoma
  14. Jan 25, 2022 at 9:58 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    I wonder how easy it is to get behind that part of the dash and add a MagSafe charger behind it? Tap into something that’s on while the truck is on. Or maybe it won’t work through the plastic dash part. It would look more clean, but I don’t think adding the MagSafe to the outside looks half bad to begin with.
    murtro likes this.
  15. Jan 26, 2022 at 7:26 AM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    Let us know how the tear down goes. Don’t forget to include step-by-step pictures. :thumbsup:
    murtro and trazerr[QUOTED] like this.
  16. Jan 26, 2022 at 8:34 AM
    EvilSteve
    I was thinking the same thing but given the charging rates for iPhone are already low, having extra distance might be a problem. Does anyone know the output of the USB-C port in the console? I was considering wiring the Qi charger up to the harness that exists rather than using the USB-C port.
  17. Jan 26, 2022 at 8:48 AM
    wired
    wired New Member
    2.5 amps from the type A and 3.0 from the type C (per the manual). My Qi charger I put in works fine using the Type c in the console. If you need more power, and have the AC outlet in the rear of the console, you could use a quick charge adapter there and get faster charging.
    EvilSteve likes this.
  18. Jan 26, 2022 at 10:31 AM
    iamcaseyf
    Ah yeah saw yours too! It's such a solid idea, I'll probably do the same.
  19. Jan 26, 2022 at 11:22 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    I have the Pro Holder and is great. And excellent customer service and support. Screenshot_20220121-081305_Amazon Shopping.jpg
  20. Jan 26, 2022 at 2:05 PM
    smtundrafarm
    smtundrafarm New Member
    Mine actually works really well. Keeps my phone charged even while playing music. I’ve been impressed with it.
  21. Jan 30, 2022 at 5:32 AM
    cemetz3
    cemetz3 New Member
    Chuck
    West Lebanon New Hampshire
    2022 Tundra SR5 4x4 with Options
    Once you mount the store purchased magnetic charger in the console area where do you want to run the wires to the center console, anyone have some photo's?
  22. Jan 30, 2022 at 8:23 AM
    Rustedfenders
    Wally
    Rosedale Md.
    Go with the Pro-Holder on Amazon, you won't regret it. Mine works great even with a cover.
  23. Jan 30, 2022 at 5:45 PM
    RoddersLV
    RoddersLV New Member
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    Dry clean and clever. I’ve looked at the aftermarket Tesla Qi chargers and they appear capable of being readily modded/fabricated into the designated space.
  24. Jan 30, 2022 at 7:29 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    I have been asking this in several threads to actual owners. The first YT review I saw the guy said he lost charge over several hours of his phone being charged in the truck. He chalked it up to running GPS the entire time, but still. That can’t happen.
  25. Jan 30, 2022 at 7:45 PM
    xc_tc
    xc_tc New Member
    It happens. The Qi chargers suck. Phone gets hot. Crashes CarPlay. I don’t even use it my in my Tundra or my 3 series.
    Hella Krusty and PNW Tundra Mike like this.
  26. Jan 31, 2022 at 6:04 AM
    MontanaEric
    MontanaEric New Member
    Eric
    Oh I had that in my 16 Tacoma, I thought it was a phone warmer....
    Hella Krusty and OnThaLake like this.
  27. Jan 31, 2022 at 6:44 AM
    Baldwin
    Baldwin New Member
    Mine worked OK today. Connection was stable. I may have lost a bit of charge on my 45 minute commute running Android Auto for GPS. Not sure if my phone was fully charged when I left the house. Got to work with 88%. Samsung S10+. Ill monitor it better on the drive home today.
  28. Jan 31, 2022 at 7:01 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Mine works pretty good. Charges iPhone without any issues
  29. Jan 31, 2022 at 8:29 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    I have a thinner Spigen case on an iphone 11Pro. Charger works perfect.
  30. Jan 31, 2022 at 1:05 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    It seems like issues begin with iPhone 12. Possibly due to the camera casing jutting out a couple of millimeters.
