Changing spark plugs
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stumpjumper, Jan 24, 2022.
  1. Jan 24, 2022 at 11:06 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I looked at the owners manual and the first change I saw was at 120k. Does anyone actually wait that long? I was thinking about changing at 80k. I changed the plugs in my daughters Rav4 at well over 100k and they looked good so maybe 80k is wasted time and money.
  2. Jan 24, 2022 at 11:11 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I changed around 70k, plugs still looked good.
  3. Jan 24, 2022 at 11:53 AM
    Retired...finally
    It's not a bad idea to make sure they aren't stuck way before the recommended change interval. I usually do this and if gappable, snug them up a tad.
    TucsonTundra1794 likes this.
  4. Jan 24, 2022 at 12:00 PM
    Retired...finally
    Isn't it odd that when spark plug change intervals increase, so do the cost of spark plugs.:confused::annoyed:
    2mchfun likes this.
  5. Jan 24, 2022 at 12:09 PM
    CTundraForMe
    CTundraForMe New Member
    I was taught to let the shop do it. That way if something is stuck or gets broken in the process, it's on them.
  6. Jan 24, 2022 at 12:32 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Nothing should be stuck or broken when changing your spark plugs (given that your anti-seize hasn't dried out)... unless if you're using an impact wrench to install your spark plugs (which you never should, I hope...).
    Unless if you have a truly trusted mechanic who you trust with all your vehicles, doing it yourself, I'm sure you should be extremely careful to take care of your vehicle...
  7. Jan 24, 2022 at 12:41 PM
    Retired...finally
    In all my years of wrench twisting I've only had one reluctant plug. That was on a used, well abused and muddy water cooled Honda Trx300fw. Simply spraying PB Blaster and a few heating/cooling cycles was all it took to allow it to be removed normally. I guess hearing of the Ford Triton plug fiasco has me aware.
  8. Jan 24, 2022 at 1:34 PM
    2mchfun
    Been a 60-80kish guy myself for about the last 20 years or so. Never had thread problems, but have broke a couple on the way out due to some tight hard to reach places.
  9. Jan 24, 2022 at 2:15 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I have never had a problem with a Toyota. In addition to my daughter's Rav4 I changed them on son's car, several times on Tacomas, and several Fords that were not 5.4s. I had one of the famous 5.4 Tritons. After watching my neighbor tear down half the top of his Triton and spending 8 hours on it I took mine to a shop. Good thing too. Intake was leaking above number 6. I had enough of that truck when it spit number 6 on a cold rainy Xmas eve.
  10. Jan 24, 2022 at 2:18 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I do 100k, give or take a nice Saturday on all my Toyota's
    WILLINH likes this.
  11. Jan 24, 2022 at 2:59 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I grew up and started driving in the 1970's. Started wrenching in the 1980's. 30,000 miles then was considered full plug life.
    I looked in the Tundra manual and said to myself "that just can't be right. Over a hundred thousand miles on the plugs?" So what did I do? I changed them at just under 70k miles. And they looked greeeeeeat. I would tell ya that after the change there did seem to be a bit of an increased pep in her step.Plugs1.jpg Plugs2.jpg Plugs3.jpg
  12. Jan 24, 2022 at 3:16 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Yeah the iridium that adds the extra cost but also the longer interval. Copper plugs actually have the best performance of any plugs but obviously have very short life span.
    Zebruaj likes this.
  13. Jan 25, 2022 at 5:32 AM
    DoublePro
    DoublePro New Member
    I did mimes at 120k along with the water pump, belts, tensioner etc
    hANNAbONE likes this.
  14. Sep 9, 2022 at 6:15 AM
    devinaschultz
    devinaschultz New Member
    Devin
    2022 SR5 TRD 5.5
    <Quote> I was taught to let the shop do it. That way if something is stuck or gets broken in the process, it's on them.
    Not at my shop... if it breaks because of a known problem, its still on the owner. Shop can't do anything about stuff the manufacturer does not make accommodations for. If they know there is a chance of breaking after 60k miles, they should make the interval 60k, not 120!
    F0X672 likes this.
  15. Sep 9, 2022 at 6:17 AM
    devinaschultz
    Devin
    2022 SR5 TRD 5.5
    ??? Did you go back with the original model plugs or upgrade to something different? Plugs that look that good would not seem you'd get a noticeable boost from changing. ? lol!
  16. Sep 9, 2022 at 6:24 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Spec'd NGK's from an authorized reseller.
  17. Sep 11, 2022 at 6:26 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Did my plugs at 70,000. Belt now at 80,000..
  18. Sep 11, 2022 at 7:12 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am wondering how you get to the rear passenger side plug to change it out?
  19. Sep 11, 2022 at 12:57 PM
    pursuit2550
    pursuit2550 New Member
    I have always had a better sounding engine after a spark plug change. It could just be butt dyno though. I personally feel like 120k is pushing it. Call it cheap maintenance insurance. Kinda like brake fluid, it’s cheap and should be done more often than most do it. Some don’t do it at all.
  20. Sep 12, 2022 at 12:23 PM
    agrestic1
    2016 CrewMax
    Don't recall having a problem removing the coil or sparkplug on that one..
    snivilous and Joe333x like this.
  21. Sep 12, 2022 at 1:35 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I did my plugs last week and that was one of the easier ones. Picture of your issue?
    HulkSmurf14 likes this.
  22. Sep 12, 2022 at 2:18 PM
    IowaGuy
    IowaGuy New Member
    In Process
    Getting to this plug is tight and there is a lot of stuff in the way?maxresdefault.jpg
  23. Sep 12, 2022 at 3:13 PM
    snivilous
    SW UT
    Yours looks maybe different than mine but hard to tell. With the intake removed I just disconnected the harness from the firewall bracket so I could move the harness and then had easy access to the bolt and everything.
  24. Sep 12, 2022 at 3:51 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    OK to (grudgingly) admit I wasted more time and obscenities on the coil pack clips than the plugs?
  25. Sep 12, 2022 at 4:16 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    THIS ^^^ is what you want to do. Makes it easy-peasy.
  26. Jun 7, 2024 at 3:51 PM
    Hambone01
    Hambone01 New Member
    Going to change spark plugs. Has anyone cleaned the electrical connections to the coil packs. What did you clean them with.
