Add a fuse for switch panel
Discussion in 'Electrical' started by Lunarrockpro, Jan 23, 2022.
  1. Jan 23, 2022 at 1:57 PM
    Lunarrockpro
    Lunarrockpro [OP] New Member
    Eugene, Oregon
    2021 lunar rock tundra pro
    Help please. I’m wiring in my auxbeam switch panel and I’m not sure which fuse under the hood fuse box I should put on the add a fuse. I am also confused if I need to up the amp of the fuse I am adding it to. I don’t want the back lights on the switch panel to be on when the ignition is off so it needs to be added to something that needs to be off when the ignition is off.
  2. Jan 23, 2022 at 4:03 PM
    Lunarrockpro
    Eugene, Oregon
  3. Jan 23, 2022 at 4:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Usually ignition
  4. Jan 23, 2022 at 5:10 PM
    Lunarrockpro
    Eugene, Oregon
    I take that’s the 10 amp fuse marked ign. Do I need to up the amp to 15 or 20 amps on that fuse?
  5. Jan 23, 2022 at 5:24 PM
    MadMaxCanon
    Nope just put the 10amp ignition fuse on the bottom and your new fuse on top.
    NewImprovedRon likes this.
