What's the Easiest way to add a few inches for off roading
Discussion in 'Wheels & Tires' started by tedwardo, Jan 23, 2022.
  1. Jan 23, 2022 at 10:34 AM
    #61
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^ I do not know why you would want to lift the body!! When the tires and wheels are what keeps you off stuff!!! The last paragraph above in the first sentence.. lifted vehicles look nice but without a bigger tire and wheel combo you will not get any clearance Clerance!!!
    to get huge tires I reckon you have to have lift but to just get a few inches I have seen and it has been stated you can get a decent set of tires/wheels without modification. Don’t blow a gasket anyone!!!!:)
    toyofan87 and tedwardo[OP] like this.
  2. Jan 23, 2022 at 10:39 AM
    #62
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    34 inch tires will get you an inch, plus 2.5 inch from bilstein shocks. Spacers do suck especially on rough roads.
  3. Jan 23, 2022 at 10:47 AM
    #63
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I don’t understand why people keep saying that. It depends what kind of terrain you’re on. You can only put on so big a tire on a tundra. If you’re high centering often, lifting the body along with the axles help quite a bit. Especially on a long wheelbase truck like ours. I’m on 37’s and I still high center pretty often.
    2mchfun and tedwardo[OP] like this.
  4. Jan 23, 2022 at 11:07 AM
    #64
    2mchfun
    Just a thought, the entire truck is usually in motion at all kinds of angles when said gears and bearings are in rotation. So how does the diff drop cause oiling issues?
    tedwardo[OP] likes this.
  5. Jan 23, 2022 at 11:16 AM
    #65
    tedwardo
    tedwardo [OP] where we're going we don't need roads
    SW Montana
    2017 tundra SR5 double cab trd
    are the Monroe gas charged coilovers any good?
    if i do go with Bilstein 5100 at max height should i put 1"block on back
  6. Jan 23, 2022 at 11:22 AM
    #66
    2mchfun
    Might slowly relocate some rocks to the biggest holes on the trail as time permits to make it easier and cheaper to solve the fishing hole access issue.
    Black@Blue19 likes this.
  7. Jan 23, 2022 at 11:26 AM
    #67
    tedwardo
    SW Montana
    yeah, i didn't think there would be this much to do just to get a little more clearance, i have until June, deep snow right now, but i didn't even think of that, trail is just over a mile long
    2mchfun[QUOTED] likes this.
  8. Jan 23, 2022 at 12:26 PM
    #68
    Black@Blue19
    Ken
    SE Texas
    Yes and a long wheel base is not the best for off road in as far as crawling over STUFF!!:). Buy a really cheap Vega and cut the fenders off with a torch and put on tractor tires!!!!:) That’s the ticket!
    Best of luck to ya.:)
    4x4 ATV ????
  9. Jan 23, 2022 at 12:42 PM
    #69
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Eibach pro truck stage 2 and be done with it
  10. Jan 23, 2022 at 12:42 PM
    #70
    2mchfun
    I say just build a house on the lake and call it a day!
  11. Jan 23, 2022 at 1:23 PM
    #71
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Tires and what it takes to fit them. Probably best advice out there.
    A few options if you need to lift the body to clear the tires.
    But, asking your mechanic is a great idea as if he's local and off roads he probably has good advice.
    And any local 4x4 shops. Tell them up front your waiting on funds then ask away.
    And ask them to match prices in case of issues down the road you'll have somebody in your corner.
  12. Jan 23, 2022 at 1:27 PM
    #72
    tedwardo
    SW Montana
    my guy usually hooks me up pretty good and then let's me make very low payments, gonna go with 275/70 18, just got the extra inch as i need new tires anyway, then we'll talk about lifting and going oversize.
    thanks everybody for the input and advice, it was much more informative starting a thread than it was trying to read through the forums
    thanks again
    hooah
  13. Jan 23, 2022 at 1:44 PM
    #73
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You really don’t need a lift for 275/70, they will look great at stock height
  14. Jan 23, 2022 at 2:12 PM
    #74
    tedwardo
    SW Montana
  15. Jan 23, 2022 at 2:23 PM
    #75
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    With my Michael Buffer voice, " get ready for round two".....
