What it sounds like when drive belt tensioner needs to be replaced
Discussion in '2nd Gen Tundras (2007-2013)' started by Flood9192, Jan 19, 2022.
  1. Jan 19, 2022 at 4:11 PM
    Flood9192
    Flood9192 [OP] New Member
    2010 Grey Tundra Platinum
    Stock
    So I had my drive belt changed 2 months ago. The tensioner needed to be replaced after a quick evaluation from a local repair shop. I was slightly worried due to the knocking sound but low and behold that was what wrong. It started knocking right after an oil change last week.
    I also had the fuel induction service done and replaced the spark plugs. This truck has never run so well at 181,818 miles! Just replaced the brakes all around (rotors, pads, shims) and this truck drives like brand new.
    https://youtu.be/gtirj0rqtS0
  2. Jan 19, 2022 at 4:18 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    yup that sound would freak me out for sure
    Flood9192[OP] likes this.
  3. Jan 19, 2022 at 4:52 PM
    2mchfun
    Welcome from OKC! So the knocking was caused by the tensioner, interesting.
  4. Jan 19, 2022 at 5:15 PM
    Flood9192
    Stock
    Correct, I noticed it being in sync with the belt revolution but still had no idea until I had it looked at.
    2mchfun likes this.
  5. Jan 21, 2022 at 3:51 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Good info to know. Thanks OP.
  6. Jan 23, 2022 at 5:30 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Last car i had that was knocking from this area was the water pump.
    (unfortunately i wasn't sure that was it so i paid the shop to replace the alternator first, at $600 bucks then Toyota to replace the water pump ($60 part) for another $600.
    Was very disappointed the first shop gave the car back to my wife making the same noise we dropped it off for after taking our money. (i was outta town).
    squealing from belts and idler pulley bearings.
    Thanks for posting though, also good to have noise that match symptoms and solutions.
  7. Jan 23, 2022 at 6:17 AM
    triharder
    Jake
    Southern, Maine
    2010 RWB Black
    You have good friends if 1) they are helping you and 2) they know exactly how to push your buttoms.
    Flood9192[OP] and Tundratoofun like this.
