What are these on the bottom of my side view mirrors?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Jan 22, 2022.
  1. Jan 22, 2022 at 4:51 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Are these LED flood lights? It’s a 2018 Tundra 1794. I have no owners manual, and they don’t seem to turn on.
    Maybe burned out? Or something else? If they are flood lights, when are they supposed to turn on?
  2. Jan 22, 2022 at 5:09 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    They’re puddle lights. Should turn on when you unlock your truck.
  3. Jan 23, 2022 at 8:05 AM
    Shadowfax1
    Thank you. I looked closely in the dark after you posted this; mine do turn on but are very, very dim which is why I didn’t see it before. I’ll replace them.
  4. Jan 23, 2022 at 8:14 AM
    BoysandHisToys
    Central Virginia
    Morimoto and a few other aftermarket ones are available.
    I got these off Amazon for cheap and they are bright!
    MbuyDIY LED Side Mirror Puddle Lights Lamp Compatible with 2007-2020 Tundra 2008-2020 Sequoia 6000K White, Pack of 2 https://www.amazon.com/dp/B08CSFJYC9?_encoding=UTF8
  5. Jan 23, 2022 at 8:19 AM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Here is a how-to vid. for your ref.. https://youtu.be/RxnEgHIACHs
  6. Jan 23, 2022 at 8:22 AM
    Taco-Spike, Jego and BoysandHisToys like this.
  7. Jan 23, 2022 at 8:31 AM
    Shadowfax1
    I just bought replacements on VLEDs, for all interior + cargo + mirror puddles. I didn’t spring for the footwell lighting strips, though I’ll probably get those in a couple months.
  8. Feb 20, 2022 at 1:31 PM
    Shadowfax1
    Ok, so I removed the factory puddle light. Used a flat tool to poke the tab behind the mirror, and then pulled out the casing from the bottom. Disconnected it. Connected the new VLED puddles to the red connector, and they work great.
    But how do I get them to stay in place? They have a notch but no tab or anything I can see to get them to stay put.
  9. Feb 20, 2022 at 1:35 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    They should have come with 3m tape on the backside to help with them staying in. Mine did at least. Alcohol wipe the bottom of the mirror and let it dry before sticking.
  10. Feb 20, 2022 at 1:36 PM
    BoysandHisToys
    Central Virginia
    Looks like the tape is there, just need to remove the red plastic?
    I used a cheaper Amazon version that works great. But mine clipped in place just like OEM.
    20GR8 Super[QUOTED] likes this.
  11. Feb 20, 2022 at 1:45 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Yup! Exactly it. Looked at the pic a bit closer after I posted. Just remove the red plastic and stick.
  12. Feb 20, 2022 at 7:08 PM
    Shadowfax1
    Awesome. Thanks everyone. The red strip wasn’t labeled 3M or anything so I didn’t even notice it was a sticky tape. Problem solved and the new puddles are installed. Amazing difference!
  13. Feb 23, 2022 at 12:09 PM
    Shadowfax1
    Hmm. So the 3M tape on these are crap. Keeps falling off on one side.
    any suggestions for making it stick better? Some kind of glue that will make it strong but not so strong I can’t ever remove it (like Krazy Glue would be)?
  14. Feb 23, 2022 at 12:16 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    If you didnt use rubbing alcohol before sticking them they will fall down. I would get some more 3M double siding tape and make sure you prep the area it sticks to appropriately. With their design I dont think there is much more you can do as they do not come with clips to secure like the OEM ones do.
  15. Feb 23, 2022 at 12:20 PM
    Shadowfax1
    I did.
    there’s got to be some kind of glue I can add to their sticky surface to make it secure without being impossible to break off should they need to be replaced…?
  16. Feb 23, 2022 at 12:23 PM
    Rocko9999
    Rocko9999 New Member
    The LEDs don't do well with dimming-they step dim instead of a steady dim like incandescent.
  17. Feb 23, 2022 at 12:25 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I've never had that problem with mine and they have been in for a year and a half. I would just buy some more 3M tape and try it again. They make 3M tape in different strengths too. Make sure it is prepped and do it on a warm/dry day.
  18. Feb 23, 2022 at 12:35 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    Dang, usually 3M works pretty well. I would either try fresh double sided tape just put a couple daps of super glue, you should still be able to break it off
  19. Feb 23, 2022 at 12:50 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Same here, I have VLED universal puddle lights since I wired them.
    I stuck them on years ago and they have never come out.
    Never had an issue with them fading on and off either.
    Looks pretty smooth to me.
    @Shadowfax1 it's odd they came loose even after you cleaned it.
    I used this to put the letters back on my TRD Pro grille after I had them painted.
    Never had a problem in 6 years..
    Also used on my aluminum light bars for my amp steps.
    Amazon.com: 3M Super Strength Molding Tape, 03614, 1/2 in x 15 ft : Automotive
    3652BC2C-14AA-47E2-A359-B78F35C21A21_zps_b497a1eafaf469b58517c2d9d33e0564dcd1208d.jpg A777550B-739C-4F6B-9562-0CE0A6933192_zps_17c1c6b8240cc8edfd92a4e99bfbb7c3d14bfa6a.jpg cn1kwhbh_33a1cc89f379f63fdd4854b512b276b6027ccad0.jpg spbkoxaa_be1303eea5c4b92eed40308d7aa3c92731b98373.jpg
