Mudguards
Discussion in '3rd Gen Tundras (2022+)' started by Tony Bee, Dec 27, 2021.
  1. Dec 27, 2021 at 2:02 PM
    Tony Bee
    Tony Bee [OP] New Member
    Anthony
    2018 Toyota Tundra Platium
    Backflip Tonnau Cover
    Does anyone know if the 2022 Platinum and 1794 come standard with Mudguards?
  2. Dec 27, 2021 at 2:21 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    NO mudguards are shown in any of the official toyota.com photos. So we'll have to assume: there is a worldwide mudguard shortage.
    reese3303, kstateskier, WBW and 7 others like this.
  3. Dec 27, 2021 at 7:25 PM
    Tony Bee
    Anthony
    I went back to the Tundra site and noticed on the TRD Off Road Package ($2,140) Mudguards are listed with that option. I hope that is not the only option I have for Mudguards. If that is the case that is a thumbs down for the 2022 Tundra.
  4. Dec 28, 2021 at 7:50 AM
    David-T
    David-T New Member
    2022 Tundra Platinum
    I have the 2022 Platinum and it does not have mudguard. I went to the dealership to see if I could order them and they were around $60 a piece without the hardware. He suggested I wait and see if the will be available as an accessory next year.
  5. Dec 28, 2021 at 8:04 AM
    Tony Bee
    Anthony
    Congratulations and Thank You for the response. I'll wait to order my 1794 until next year. Although I am now undecided whether to get the Platinum or 1794. I like the dark wheels with the Blueprint
  6. Dec 28, 2021 at 11:23 AM
    David-T
    David-T New Member
    Just got this from Sparks parts, probably going to order them.
    Part Number Part Name Price Quantity Total
    76621-0C080 Mudguard Front Body R $43.69 1 $43.69
    76622-0C080 Mudguard Front Body L $43.69 1 $43.69
    76625-0C090 Mudguard Rear Body R $43.69 1 $43.69
    76626-0C090 Mudguard Rear Body L $43.69 1 $43.69
    90159-A0053 Fender Liner Screw $0.77 16 $12.32
    90189-06236 Wheel Opening Molding Grommet $0.62 14 $8.68
    90189-06237 Rocker Molding Grommet $0.71 2 $1.42
    Subtotal: $197.18
    Total: $197.18 + Shipping
    Beastmode1, WBW, jhoward000 and 3 others like this.
  7. Dec 28, 2021 at 5:29 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    WBW and Rodtheviking like this.
  8. Dec 28, 2021 at 5:34 PM
    2mchfun
    Make the deal with a salesman and the other clown then agree to sign after they add an IOU a full set of (4) mud flaps plus installation. They say no, you walk. They will call you before you get home.
    kstateskier and Tundratoofun like this.
  9. Dec 29, 2021 at 8:34 AM
    nodak67
    nodak67 New Member
    JR
    platinum is the only trim that you cannot get mud guards as factory or pio. every other trim you can get it part of a pkg
  10. Dec 29, 2021 at 12:35 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    I fell that for the top level trim, the Platinum sure didn’t get a lot of things/get options for. Here in Canada, neither the platinum nor 1794 has the option of an off road version meaning that we can’t a locking rear diff/crawl control/upgraded shocks. Not having a mud guards is not a huge issue, but just starting to get this feeling.
  11. Jan 21, 2022 at 4:19 AM
    jhoward000
    jhoward000 New Member
    2022 Toyota Tundra 1794 4x4
    Did you order these? If so, did everything fit correctly? About to pull the trigger on these for my 22 1794.
    mountaingroan likes this.
  12. Jan 21, 2022 at 8:01 AM
    David-T
    David-T New Member
    Ordered them on 12/28/2021 and had a eta of 1/18/2022. Guess it's still on back order, just asked for update.
  13. Jan 21, 2022 at 9:16 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  14. Jan 22, 2022 at 5:09 AM
    jhoward000
    I tried to order them yesterday and was told that none were in stock in any warehouse. Therefore, they couldn't give me an ETA and it would likely be multiple months. Back to the drawing board.
  15. Jan 22, 2022 at 3:30 PM
    rideandfly
    rideandfly New Member
    Had OEM front & rear mudguards on order for about 3 weeks from local dealer. The LH & RH front mudguards came in yesterday and parts department said rear mudguards should be in next Friday. Used existing 4 screws per front mudguard making an easy and fast installation.
  16. Jan 22, 2022 at 5:46 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    In Canada, there's a "stop sale" on mudlflaps due to a number of trucks being shipped from the factory without them, and supply sounds limited. Not sure who or why CDN trucks with the TRD OR pkg were designated flapless, but it's also holding up deliveries.
    KraftDinr likes this.
  17. Jan 22, 2022 at 6:00 PM
    cemetz3
    cemetz3 New Member
    Chuck
    West Lebanon New Hampshire
    2022 Tundra SR5 4x4 with Options
    So if you have a 2022 crewmax and order 76622-0c080 Front LH / 76621-0c080 Front RH / 76625-0c090 Rear RH / 76626-0c090 Rear LH they should bolt right up with the existing hardware on the truck correct? Thanks!
  18. Jan 22, 2022 at 6:54 PM
    rideandfly
    I have the above LH & RH rear mudguards on order and assume they will work fine like the above front mudguards installed today. Also ordered & received mounting hardware that was not needed for front mudguards installed today, assume will not need mounting hardware for the rear mudguards, too.
    Hope rear mudguards come in next week, will post when received and installed.
  19. Jan 22, 2022 at 7:01 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    I did similar with my 2020 except it was for aftermarket step bars, I picked what I wanted and they cut me a check
    2mchfun[QUOTED] likes this.
  20. Jan 22, 2022 at 7:17 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have a full set of new flaps for the 2.5 gen if anyone wants them :notsure:
  21. Jan 29, 2022 at 10:40 AM
    Grant73
    Grant73 New Member
    Grant
    2022 Tundra Limited TRD
    Mudguards are listed on site but I have a Limited TRD that came without them, I asked dealer and was told the website is wrong. So no mud guards
  22. Jan 29, 2022 at 1:07 PM
    cemetz3
    cemetz3 New Member
    Chuck
    Just order mud guards from sparks, front and rear for my 2022 SR5 4x4 Crew Max. I DID NOT order hardware and was reported here at Tundras that can use existing hardware.Is this CORRECT? Thanks!
  23. Jan 29, 2022 at 3:27 PM
    Baldwin
    Baldwin New Member
    Canadian models seem to come standard with mudguards. Just got my limited today and it came with them. Saw a SR5 TRD OR in the showroom and it had them on.
    Mattedfred likes this.
  24. Feb 1, 2022 at 3:03 PM
    rideandfly
    Both rear mudguards came in today at the local Toyota dealer. I used existing screws, but needed one more screw per side that can be purchased from Toyota or purchased at a local Lowes or Home Depot. The screw insert for the screw to thread into was already in the wheel well.
    Two total screws needed:
    Beastmode1 likes this.
  25. Feb 1, 2022 at 4:02 PM
    BluFoxx82
    BluFoxx82 New Member
    2017 Blazing Blue Tundra
    7" BDS
    Rek Gen has nice aftermarket universal ones also. I'm happy with mines!
  26. Feb 1, 2022 at 4:03 PM
    cemetz3
    cemetz3 New Member
    Chuck
    Thanks, so will need 2 screws w/washer part # 90159-A0053 for the rear, same with the front?
  27. Feb 1, 2022 at 5:32 PM
    rideandfly
    Only used existing screws for the front, no extra screws needed for the front. Only needed 2 extra screws total for both rear mudguards.
  28. Feb 1, 2022 at 5:36 PM
    cemetz3
    cemetz3 New Member
    Chuck
    Great thanks, I have them ordered from sparks parts and currently backordered. Gives me time to a get a couple bolts with washers. Thanks again!
  29. Apr 7, 2023 at 10:48 AM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I have a full set of OEM Toyota mud guards if anyone is interested- PM me.
  30. Apr 7, 2023 at 6:31 PM
    tedinblack
    tedinblack New Member
    2023 Magnetic Grey Platinum Edition
    Did you ever get them? I bought my Platinum 2/2 and bought a set of mudflaps with the hardware from Sparks a few days later...
