Blank electrical connectors
Discussion in '2nd Gen Tundras (2007-2013)' started by ricky bobby, Jan 22, 2022.
  1. Jan 22, 2022 at 12:12 PM
    ricky bobby
    ricky bobby [OP] New Member
    Great Nation of Texas
    When replacing my radio i found several electrical connectors plugged into blank spots in my 08 SR5. I have service figured out these are for heated seats plus, glass break and the coin holder is where 4WD switch would go if my rig was 4WD. I also found some electrical connectors under the passanger seat when i replaced the amp. I assume some of these are for heated seats and maybe power seats, since my passanger seat is not power?
  2. Jan 22, 2022 at 12:16 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Sounds reasonable.
    *You have met your character limit for the week, due to the all the blank space in your pervious post.*
  3. Jan 22, 2022 at 12:28 PM
    ricky bobby
    Ya i had to switch to chrome, Samsung site wasn't playing nice.
  4. Jan 22, 2022 at 12:32 PM
    ricky bobby
    I also found these connectors near the bumpers of my truck. Are these for the bumper sensors if i had them on my bumpers?
    20211028_130252_IMG_1925.HEIC.jpg 20211028_130124_IMG_1924.HEIC.jpg 20211028_130055_001.jpg 20211028_125630_IMG_1916.HEIC.jpg
  5. Jan 25, 2022 at 3:34 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    The tundra chassis is the same for the Sequoia. They are basically blanks until they reach a point in the factory where they become a tundra or Sequoia. From there they branch off again and have trim features added.
    So you'll find a lot of dead plugs, blanks and wires leading nowhere. It's not as easy as adding the feature components. You also have to add the features to the bcm, ecu, etc....
  6. Jan 25, 2022 at 4:09 PM
    ricky bobby
    Is there a list of items which just require the adding the upgrade; heated seats bumber sensors
  7. Jan 25, 2022 at 4:17 PM
    Notarobot
    2013 CM
    Someone might have a list or a component here or there that you can add. But I highly doubt the manufacturer gave you all the hardware, space, and ease of install for a $1,200 msrp feature just so you can go buy it afterwards for $300 and it work.
    The key is the ecu,bcu,tcu.
