Payload Stickers?
Discussion in '3rd Gen Tundras (2022+)' started by AnalysisParalysis, Dec 10, 2021.
  1. Jan 16, 2022 at 1:44 PM
    #301
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Looks like a lot of the same old back and forth since the last time I checked in here but no new payload stickers, which was the point of the thread. I'd bet the vast majority don't ever look at them once. I've yet to meet a truck salesman that could even find the payload on a truck.
    JamesAZ, Archive, MTRock and 2 others like this.
  2. Jan 19, 2022 at 3:32 PM
    #302
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Per the Toyota service manager I spoke with when I first embarked on Toyota/truck campers odyssey: it's all about the axle ratings, the (front) brakes and the shocks. Obviously a trans cooler is mandatory for a typical automatic.
  3. Jan 19, 2022 at 4:12 PM
    #303
    Keeferton
    Keeferton New Member
    Keith
    Bend, OR
    22 Tundra TRD Off-road DC
    Glad to see some folks on here with pop ups. I got my tundra to haul a fwc that will be built in may. The camper dry is supposed to be 1500 pounds which is the payload rating on my DC. With proper suspension upgrades and a little common sense I’m not worried.
  4. Jan 19, 2022 at 5:39 PM
    #304
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Ya, if stay under the axles ratings you'll be fine, so long as you beef up the suspension and tires. The new ones have wimpier rear axles than the 2nd gen. It would probably not be good to have a camper that hangs off past the bed, as this amplifies the rear load.
    Brakes are fine... you can activate the ABS, so bigger ones won't stop you faster. Bigger brakes can be used more without overheating but a little common sense on long descents (gear down and slow down) will make that a non issue.
    mountaingroan[QUOTED] likes this.
  5. Jan 21, 2022 at 8:00 AM
    #305
    Blackrifle76
    Blackrifle76 New Member
    2022 platinum 4x4 blueprint
    20220121_085547.jpg Do I win anything for posting the lowest payload sticker to date? Platinum 4x4 with 6.5 bed
  6. Jan 21, 2022 at 8:12 AM
    #306
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Thanks for posting. A couple questions:
    • That yellow sticker says your payload has been reduced by ___ lbs. What’s the number there?
    • If you look at the white sticker above the tire and loading information sticker, it will show your GVWR and your axle ratings (FF and RR). What are those numbers?
    Cpl_Punishment and Mattedfred like this.
  7. Jan 21, 2022 at 8:28 AM
    #307
    rruff
    rruff New Member
    If this was a thread about low payload stickers, I doubt you'd be the lowest!
    OnThaLake likes this.
  8. Jan 21, 2022 at 8:36 AM
    #308
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Still higher than my SR5!
    Melikeymy beer likes this.
  9. Jan 21, 2022 at 8:43 AM
    #309
    Retired...finally
    Got me beat by 50 pounds even before the yellow sticker. 1253 is my final port adjusted payload.
  10. Jan 21, 2022 at 8:58 AM
    #310
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I think I have 1275 per the sticker but that doesn't include the canopy and bed liner I added.
  11. Jan 21, 2022 at 9:01 AM
    #311
    Retired...finally
    I'm considering making a green sticker adding 114 pounds for the rear seats I removed.:)
  12. Jan 21, 2022 at 9:09 AM
    #312
    mass-hole
    mass-hole New Member
    You win the prize because your truck's payload sticker says exactly the same number as the manual does for a 4x4 Crewmax standard bed.
    In fact, everyone wins.
    Now go bring it to a cat scale with nothing inside the truck and a full tank of fuel and let us know what it weighs.
    Terndrerrr and Cpl_Punishment like this.
  13. Jan 21, 2022 at 2:23 PM
    #313
    mass-hole
    Because I think they’re sandbagging the numbers. The GVWR of a two-wheel-drive SR double cab is like 7000 pounds that truck can’t weigh more than 5000 pounds
  14. Jan 24, 2022 at 7:58 PM
    #314
    mass-hole
    ~5100 lbs according to Toyota:
    So if the GVWR is around 7000 lbs then it should have the 1900 lbs of payload.
    here is the sticker from the SR5 double cab 2x4 and it has the 7035 lb gvwr:
    thats suggesting that truck weighs 5500 lbs which seems extremely heavy. Even Ford’s 2014 steel body supercab 2x4 3.5L was only 5203 lbs.
  15. Jan 28, 2022 at 11:44 AM
    #315
    Archive
    Archive New Member Vendor
    Eric
    '22 Tundra CM 6.5' TRDOR
    Archive Garage Suspension
    Toyota is populating the Build & Price details with 2wd "Maximum payload" numbers, despite the fact the details update to saying 4x4 when you select it.
    Apparently the 4x4 option cuts ~400lbs. Toyota should be adjusting the details for 4x4 selection, but they are not. Here is snip from a Build & Price of an SR5 CrewMax 5.5' 4x4, but the Demo SR5 at my local dealer has 1395lb Payload sticker (32.2 gal tank, spray in bed liner). See docs attached below
  16. Jan 28, 2022 at 11:47 AM
    #316
    18" TRD Off Road Wheels
    That is generic info. It says Maximum Payload and Maximum Towing capacity, and that applies to the Tundra Model in general. Not a specific truck. The only way to get the specific number is to open the door and check the sticker. Marketing is always about lying as legally as possible, and EVERY manufacturer does it.
    Cpl_Punishment likes this.
  17. Jan 28, 2022 at 11:49 AM
    #317
    Archive
    Eric
    Well just a member explaining what to expect when your Tundra shows up.
    Mattedfred likes this.
  18. Jan 28, 2022 at 12:15 PM
    #318
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If you get a chance, please weigh your truck and let us know if it actually weighs 5845 lbs with nothing in it.
  19. Jan 28, 2022 at 12:23 PM
    #319
    Archive
    Eric
    I will weigh mine when it comes in (CrewMax 6.5' TRD OR). This one I posted is the dealer demo vehicle
  20. Jan 28, 2022 at 12:37 PM
    #320
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    I think Toyota is guilty of fuzzy math. The classic definition of curb weight is the weight of the truck as built plus a full tank of fuel. They have published a range of curb weights by model and a range of GVWR by model. Simple math says their payload stickers are based on some other measurement scheme. My 2012 Tundra payload sticker matches exactly the GVWR minus the published curb weight. It seems math has changed over the last 10 years. At this point, I am using the payload sticker on the 2022 as a guide and will base loading and towing on a measured curb weight and keep the Cat Scale printout in the glovebox if somebody asks. In another thread on this site, someone actually weighed their 2022 2WD on a Cat Scale and the payload appeared to be about 170 lbs more than the sticker based on the way that truck was equipped. Weigh the truck to get the real answer.
    Ray D, Mattedfred and Cpl_Punishment like this.
  21. Jan 28, 2022 at 2:41 PM
    #321
    Paco_the_Priest
    Paco_the_Priest New Member
    2020 Super White 1794
    I have been reading through this payload thread and I completely agree that the actual Toyota Tundra payload numbers are generally disappointing. I have a 2020 1794 4x4 and the payload sticker states a capacity of 1185 lbs. The additional yellow sticker says to reduce it by 100 lbs. (ball mount, bed liner, bed lights, and running boards). So technically, I have 1085 lbs of payload; truly a half ton. Now to make matters even worse, my dear wife’s Honda minivan, circa 2008, has a sticker stating a payload rating of 1322 lbs! A minivan with more payload than a full size truck! Heaven help us all…
  22. Jan 28, 2022 at 5:33 PM
    #322
    mass-hole
    Oh look, same as the manual!
    The thing that makes me extremely suspect here is that something like an XLT F150 could range from 1900 lbs to 1650 lbs of payload depending on options. I've seen Lariats as high as 1700 lbs and as low as 1500. Literally a moonroof and tailgate step on an F150 will cost you 100 lbs of payload.
    Assigning a single payload to all trucks of a particular configuration is ridiculous. I really think Toyota is undercutting their payload numbers and assigning a conservative number to all trucks. I highly suggest people weigh their trucks before they buy(or right after if you don't care)
    Cpl_Punishment, Ray D and Mattedfred like this.
  23. Jan 28, 2022 at 6:13 PM
    #323
    Archive
    Eric
    Can you link to the manual please?
    I think it is either a mistake or low of Toyota to be advertising max payload for whatever cab size 2wd on a build and price for a 4x4, when it literally says 4x4. A lot of RV people really care about payload and it is misleading to them.
    The other point people are making is, no one has seen the mythical 1940lbs on door sticker yet, have they, or even close to it? Correct me if I am wrong.
    Toyota gave these wrong numbers to Expedition Portal/Overland Journal for their article on the new Tundra which is overstating the payload by 400 lbs to people who also really care about payload for Overland builds, weight adds up real fast. It certainly affects a $60,000 decision to me. I've come to accept it
  24. Jan 28, 2022 at 6:42 PM
    #324
    mass-hole
    you have to google search the manual. I cant link it because its usually an embedded pdf.
    that said, you are correct about not seeing a 1940 lb payload. But I believe that is because they are putting the worst possible payload on the door sticker for a particular config. Until we get people weighing trucks on scales, we wont know.
  25. Jan 29, 2022 at 7:44 AM
    #325
    xc_tc
    xc_tc New Member
    I think any truck guy should weigh their truck with a full tank and figure out their payload from the difference in GVWR. It seems like Toyota is giving payload for a fully optioned vehicle to play it safe but most vehicles may have higher payload than the door jamb sticker denotes.
    For example:
    Double Cab Long Bed 4x4
    GVWR = 7375 lbs
    Curb Weight = 5565 lbs (Toyota site)
    Sticker Payload = 1515 lbs
    Actual Payload = 1810 lbs (7375-5565 lbs)
    Mattedfred, Cpl_Punishment and Ray D like this.
  26. Jan 29, 2022 at 9:00 AM
    #326
    Archive
    Eric
    We'll have to see as owners start weighing their '22 Tundras.
    I've been weighing my trucks for a while. My 2005 Tacoma DCSB 4x4 4.0 V6 6-spd has GVWR of 5350 lbs and a payload sticker of 1,100lbs, so curb weight should be around 4,250.
    It weighed out to 4,360 with about 100 lbs of accessories (tonneau cover and Archive Hammer hangers and Fox 2.5 shocks). Dead nuts on Toyotas stickers.
  27. Jan 30, 2022 at 5:22 AM
    #327
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Hi Guys have a question (or confirmation)
    see the attached pic which shows GAWR weight ratings for two Tundras.
    Both CrewMax Short bed.
    Refer to the numbers in the red circles for the Rear Axle. RR
    Tundra A - Top label has a 1880 kgs /4144 lbs rating.
    Tundra B - Bottom label has a 1750 kgs - 3860 lbs rating
    The Question
    Does this mean that if someone is carrying weight in the bed, assuming everything else is the same,
    that Tundra A is rated to carry in the bed over the rear axle, almost 300 lbs more than Tundra B ?
    If not correct, what does it mean for someone loading a lot of weight in the bed.
    Thanks.
  28. Jan 30, 2022 at 5:28 AM
    #328
    Archive
    Eric
    That is correct, for the rear axle weight rating. It doesn't mean that Tundra A has more payload, just that more weight can be transferred to the rear axle during situations like towing.
    Tundra A might actually need more RAWR due to say a CrewMax cab and a shorter wheelbase.
  29. Jan 30, 2022 at 5:30 AM
    #329
    Simple answer is: No.
    Axle ratings are only one portion of payload ratings. If you throw an axle rated for 5000 lbs under there that doesn't do anything to change the strength of the bed, the tie down points, or any supports. It also doesn't take into consideration any of the other components that make up payload ratings. The axle rating tells you how much weight the axle is rated for; not what the vehicle is rated for. Same concept for wheels. You can get wheels that are rated for 2500 lbs each, but that doesn't make the truck or it's bed capable of holding 10000 lbs. The payload rating in the door jamb is what you need to look at, not the axle ratings.
  30. Jan 30, 2022 at 5:39 AM
    #330
    borla123
    borla123 The Pits
    Ontario
    Ok ...So Total Payload ratings aside. Is it fair to say then that.
    The Rear Axle on Tundra A is rating for more weight, so it is built more heavy duty, stronger, it is more Stout ...... than Tundra B ?
