2018- click, No crank over, Maybe Starter? CLICK only-
Discussion in '2.5 Gen Tundras (2014-2021)' started by GeorgeORH, Jan 20, 2022.
  1. Jan 20, 2022 at 9:56 AM
    GeorgeORH
    GeorgeORH [OP] New Member
    2018 DC 2WD SR5
    Wheels,Grill,
    Hello everyone and thanks for any advice on this.
    I have a 2018 SR5 2WD with 43k miles on it.
    I have had the truck about 2 years.
    I have had an intermediate issue for about a year where-
    I turn the key and only get a loud click from under the hood-
    Engine does not turn over- Just a click -
    I can cycle the key several times and sometimes it will crank/start right up,
    Others just a CLICK.
    Recently the issue has went from doing this once every few months to doing it
    almost every time. I was almost stranded the other day due to this issue.
    What have I done so far?
    Brand new Interstate Battery- No change
    checked and rechecked battery connections and ground connections - Nothing loose
    voltage shows 12.2 volts when not running
    Voltage shows 14.0 +/- .2 when running
    A day ago it was acting this way so I had someone pull beside me and I
    put on jumper cables from their vehicle to mine- I did this while their vehicle
    was running- NO change
    I turned off their vehicle and voltage on mine showed the same 12.xx volts,
    I cranked their vehicle and voltage on mine showed 14.xx volts
    I rearranged jumper cables and retried my tundra- CLICK- NO change
    Put Tundra in Neutral, No change
    Put the Tundra back in Park- No change - Just a loud click-
    I returned to my truck later in the day and turned the key to try and start- Started right
    up with NO hesitation-
    Temps in my area varied from 50-65 for all testing- Alabama weather here-
    All connections are CLEAN- Truck is extremely clean- NO Corrosion on anything-
    Barely any dust on anything under my hood.
    It's a grocery getter truck- So it rarely even seens rain-
    All fuses are good, All relays accessible in fuse box under hood are good-
    I tried this morning and the truck started right up- 7 full times, (turned off, cranked/started, turned off, cranked/started, NO issues).
    Once again 2018, 43k miles,
    I got up under the truck and can barely seen a glimmer of the starter up in the abyss -
    No way I can test anything on that starter without taking it out of it's hole it is buried in.
    I am thinking starter, Any other thoughts out there?
    If it is starter- WHAT brand starter do I replace it with as I don't want to every do it again-??
    I appreciate any help or advice on this-
    A special thanks to the engineer who thought hiding the starter on this truck was a good idea-
  2. Jan 20, 2022 at 10:47 AM
    Fergie
    Fergie New Member
    GeorgeORH[OP] likes this.
