Trimming stock OR package (not TRD Pro) skid plate
Discussion in 'Suspension' started by frichco228, Jan 20, 2022.
  1. Jan 20, 2022 at 10:07 AM
    frichco228
    frichco228 [OP] Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Prepping for lifted coilovers install. Does anyone have some pics or template of where they trimmed the factory off road package skid plate for larger tires? Did you remove and trim or can it be done with skid installed?
    Thought I would take care of that and removal of the front spats before installing the lift to avoid rubbing in those areas.
  2. Jan 20, 2022 at 10:09 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    pretty sure you can just use an angle grinder while its on if you really wanted to. Just trim the wings off if your model year has them.
  3. Jan 20, 2022 at 10:18 AM
    AZBoatHauler
    So.Arizona
    I used a jigsaw. Here is a pic of where I cut before I got my RCI.1CA5681B-20E7-491B-9A32-31E31696B48E.jpg
    I removed to trim. Probably took just over an inch then used a hammer to roll the edge up.
  4. Jan 20, 2022 at 10:31 AM
    frichco228
    Frank
    Virginia
    excellent, very helpful!
    Ive heard they can be a PITA to remove, any tips? I read something about some hooks that are interesting to figure out the first time.
  5. Jan 20, 2022 at 10:39 AM
    AZBoatHauler
    So.Arizona
    People make it seem way harder than I ever found it to be. I do this -
    Remove the three 10mm bolts and front two 12mm bolts. Then take out the outer 12mm bolts leaving just the rear center bolt. When you undo the final bolt, give the plate a gentle press up, forward and towards the driver’s side to free the hooks. It will all drop down at that point. Install using reverse method - hook the plate put in the rear center bolt and the rest is easy.
