Toyota oil requirements...
Discussion in 'General Tundra Discussion' started by Eric32444, May 14, 2019.
  1. May 15, 2019 at 8:33 AM
    Right?
    Where you reside, I would definitely consider the ambient temperature and towing you do.
    jeremyd[QUOTED] likes this.
  2. May 15, 2019 at 8:35 AM
  3. May 15, 2019 at 8:51 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    True story
    My buddy stopped by approx a month ago. He pulls into my driveway and says what ya doing ? I replied just finished changing the oil. He asks what kind of oil. I replied just some cheap 5w-30 shit from Walmart. He says, oh ok I use 5w-30 also with whatever is on sale. I said, you know the cap says 0w-20 right ? He replied “bullshit” . He then popped the hood to look and was surprised. He currently has 210k on a 2008 Tundra with the 5.7...
    ColoradoTJ likes this.
  4. May 15, 2019 at 8:59 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I don't think anyone here is going to suggest that using 5w30 over 0w20 is going to cause issues with your engine. The point is that if Toyota engineers specify using a certain weight because of all the benefits they see for their engine (some they tell us about and others they may not) then why not follow those recommendations? Also, I like the comfort of following those directions and having a record of doing so in case an engine warranty situation were to arise. Would they deny the warranty because I was not using the spec oil? Probably not, but they could if they wanted to. I'd rather not take that chance. It is that simple, really.
  5. May 15, 2019 at 9:06 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I agree that you should use what’s recommended by Toyota. But me ? I’ve been following rules and regulations my whole life. Now that I’m retired I don’t want to. And I really don’t give a shit what weight goes in this bitch.
  6. May 15, 2019 at 9:15 AM
    Ronin73
    Ronin73 New Member
    Good for you.
    Y0TA PR0 likes this.
  7. May 15, 2019 at 9:20 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I heard if you put 20w-50 in, you won’t have the camshaft tower leak ! Lol
  8. May 15, 2019 at 9:24 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Said the 3ufe. I’ll have to look more closely
  9. May 15, 2019 at 9:25 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Smoke and mirror Mike swears has been caught in more lies about Toyota trucks trying to make them seem like Toyota is giving them more then they actually are. Colorado tj is most likely correct on tuning maps changing, if they increased bearing tolerances then crankshaft, rods, bearings, camshaft's etc would have to be changed for that. I just cannot see Toyota making that investment during the engines life cycle. I could be wrong but I just think its highly doubtful.
    17inferno, JohnLakeman and ColoradoTJ like this.
  10. May 15, 2019 at 9:37 AM
    Retooling is usually a huge investment, on a platform that will generally go 10-15 years of production.
    JohnLakeman, 10TundraSR5 and jeremyd like this.
  11. May 15, 2019 at 9:51 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    There is a new spec oil here in the US (been used for years in Japan), Ilsac gf-6, a 0-16w oil. The newest camry uses it.
    I will trust those who engineer the vehicle and the oil rather than think my old school way is right.
    lewi3069, Ronin73, ColoradoTJ and 2 others like this.
  12. May 15, 2019 at 11:55 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Or the 1VD-FTV Diesel? They have that over there don't they?
  13. May 15, 2019 at 11:57 AM
    I believe so. That motor I can see using 20W-50
    Wynnded[QUOTED] likes this.
  14. May 15, 2019 at 12:17 PM
    Ronin73
    Ronin73 New Member
    Care to post proof of this? I'd love to read it.
    Wynnded likes this.
  15. May 15, 2019 at 6:19 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Most of what I saw was over the 3rd gen taco when it first came out, he was caught as to saying every part was changed except something like a seatbelt bracket I think it was. I mean I don't blame the guy, he cant go out and say hey this all new Tacoma really isn't all new, its his job to perk up the product for Toyota. Same with the efficiency thing for the Tundra, they may have made changes but they were falling behind and still are to the other manufactures in that aspect so they have to say they have done something to keep interest. I still say more so with tuning vs retooling for tighter clearances. My bet is the 5.7 tolerances were already tight enough to allow the use of 0w20...but without concrete proof were just shooting in the dark here.
  16. Jan 4, 2022 at 5:07 PM
    augatundra
    augatundra New Member
    2021 Toyota Tundra Limited 4X2 Double Cab
    I live in Georgia as a reference. After using 0w20 since new to 12000 Miles , I decided to use 5w30 to stave off the engine noises. 5w30 significantly reduced typical Tundra valve train noises but the fuel economy took a nose dive. With 0w20 i was getting 15-16mpg in city and 18-19mpg highway which reduced to 13-14mpg city/ 17hwy. Engine works harder to operate in thicker viscosity oil.
    I then went to 5w20 and I feel I found the sweet spot. a quieter engine and as good as 0w20 fuel economy numbers. If you don't tow or beat up on your truck, I think 5w20 is the way to go. If you don't care about the fuel economy or operate in demanding environments go with 5w30
  17. Jan 4, 2022 at 5:23 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Old thread from May/2019.....Oil threads never gets old..xoNR61O.jpg
  18. Jan 19, 2022 at 1:53 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    if something fails in the engine and Toyota doesn't have service history of your vehicle they will point the finger else where same as any other manufacture. which will lead to you having to provide the service history and if all you oil change services says 0w40 or any thing other than 0w-20 5w-20 the will say its that companies fault for putting in the wrong oil , and when you go there dispute with them, they will provide you with what you asked to be put in it and have 0 responsibility for it leaving you to foot the bill.
  19. Jan 20, 2022 at 4:17 AM
    blanchard7684
    blanchard7684 New Member
    yeah old thread and everything....there is very little difference in viscosity between 0w20 and 5w30. The change in viscosity is definitely not enough to wreck and engine short or long term and doesn't justify the mental gymnastics.
    The manual even gives a range of climates where each oil is recommended.
    I can believe that 5w30 quiets the valve train a bit so if that is a thing for you then switch.
    If I was in Bullhead City Az year round I'd run 5w30 year round.
  20. Jan 20, 2022 at 5:15 AM
    #50
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    At that pointe you must summon all of your mana and cast... help me out, somebody. What spell should we cast?
    Sumo91 and WILLINH like this.
  21. Jan 20, 2022 at 8:41 AM
    #51
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Damn, I'm not a high enough level to cast any advanced spells like that. I got an elixir though, maybe I can just pour that in the tank?
    I heard once you reach level 24, you learn the spell "oil perfection" and supposedly it turns the oil inside of you truck into the perfect grade for the engine. But at level 32 you learn "snake oil" which you can cast on your opponents trucks. I didn't read what it does exactly though.
    Hbjeff and hagrid[QUOTED] like this.
