1st gen transmission longevity
Discussion in '1st Gen Tundras (2000-2006)' started by UtahManAmI, Jan 19, 2022.
  1. Jan 19, 2022 at 6:11 PM
    UtahManAmI
    UtahManAmI [OP] New Member
    Josh
    St.George Utah
    2000 supercharged tundra limited 4x4
    4 inch lift, 33 inch BFG AT tires, the factory super charger
    I’m looking into buying a first gen tundra and my only real worry about them is related to the transmission, I’m currently looking at one with 192k miles for 10k but it hasn’t had to transmission rebuilt yet and has no service history related to the transmission. My question is should the transmission still be fine on an automatic at this mileage or should I keep holding out till I find a lower mileage truck.
  2. Jan 19, 2022 at 6:14 PM
    The 1st gens are solid trucks. Can you look under the truck to see if the pan bolts have ever been removed?
    Pull the dip stick? Fluid smell burnt or dark brown?
    Jack McCarthy likes this.
  3. Jan 19, 2022 at 6:15 PM
    UtahManAmI
    Josh
    St.George Utah
    I live 4 hours away from the seller and can’t really find that out easily.
  4. Jan 19, 2022 at 6:16 PM
    There are dozens of guys on here at 300k+ miles on the original transmission. These trucks aren't made by General Motors, the transmissions are typically good for several 100k miles.
    If you're looking at an earlier model, do what @ColoradoTJ suggests because it'll have a dipstick. The later models like my '06 use a sealed transmission.
  5. Jan 19, 2022 at 6:17 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    The later model first gens have a sealed trans (04+ I believe) so maintenance history would be good to know. My tundra 120 and sequoia 220 both are going strong, smooth shifts, no issues. Changed tundra trans oil at 100k, Sequoia was changed at least once so far, probably due for another. Solid vehicles!
    NWPirate and ColoradoTJ like this.
  6. Jan 19, 2022 at 6:21 PM
    Learned something new today about 1st gens. Thanks gents!
    bmf4069, NWPirate and shifty`[QUOTED] like this.
  7. Jan 19, 2022 at 6:33 PM
    UtahManAmI
    Josh
    St.George Utah
    So I asked the guy and he actually had the transmission serviced 4 years ago and had new fluid put in. He also claims it’s all good currently. When test driving it what should I look out for for any signs it might not be in great shape
  8. Jan 19, 2022 at 6:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What year is the truck you're looking at?
    The early first gens shifted "hard" between first and second if you were really on the pedal. I've read a lot about it here. That's normal for the most part
    If you're just cruising through town driving miss daisy style driving it shouldn't shift hard.
  9. Jan 19, 2022 at 7:34 PM
    Aerindel
    Aerindel New Member
    Montana
    320K plus on my truck and transmission with no issues. I'd jump on the chance to get one with low of milage.
    Filthyphil, NWPirate and 5N0W808 like this.
  10. Jan 19, 2022 at 7:42 PM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    My 2004 DC has a dipstick. As far as I know all the '04's do. 2005-2006 got the new trans with the 5 speed and are sealed.
  11. Jan 19, 2022 at 7:45 PM
    NWPirate
    Zach
    WA
    My 04 Sequoia isn't sealed, 04 Tundra should be the same? :monocle:
    What year is the truck? If it's not sealed maybe he would take a pic of the dip stick on a white towel so you can see the fluid color.
    Make sure the other big 1st gen items are checked out too; frame rust, exhaust leak, timing belt etc..
    dinosaur likes this.
  12. Jan 19, 2022 at 7:50 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Yeah my bad, 05-06 (+07 sequoia) is the 5 speed and sealed.
  13. Jan 19, 2022 at 8:54 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    These things are gtg for double the miles, engine and transmission both. At less than 200k miles if someone posted about their transmission going, my first thought would be its still good and has been misdiagnosed.
    NWPirate likes this.
  14. Jan 19, 2022 at 8:58 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    What year is it? The 00-02 A340 transmission had a weak planetary gear as that trans was taken from the tacoma and the V8 was a little to much for it. This problem was addressed in the 03-04 and they moved to the 5-speed A750 in 05-06. It didn't fail in my 02 sequoia until 250k which is still good for a trans, but obviously not what we expect from Toyota. I could feel it beginning to go around 225k with a delayed hard shift (mentioned above) from 1st to 2nd gear when stopped.
    dinosaur and des2mtn like this.
  15. Jan 19, 2022 at 9:13 PM
    UtahManAmI
    Josh
    St.George Utah
    It’s a 2001 SR5 4x4
  16. Jan 19, 2022 at 10:13 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Be sure to get good frame pictures and check it in person if you take the drive to look at/get it. It being an 01 it should still be covered for frame recall if it fits under the proper conditions.
  17. Jan 20, 2022 at 4:23 AM
    00BlackTundra
    00BlackTundra New Member
    2000 Tundra 4x4
    Hard to say with a truck that old and with that many miles. My 2000 Tundra just went bad at 200k. No warning signs whatsoever. Still shifted perfectly until I pulled it out. It just had a horrible vibration from 50mph and up. Saw a lot of metal when I pulled the transmission pan and I changed the trans fluid about every 50k miles.
  18. Jan 20, 2022 at 4:35 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd tow package
    2000 4wd. 260k no problems. That said, I don't tow anything and no heavy loads. How a truck is used can e ais a significant factor beyond maintenance.
    Since new my truck has had a noticeable shudder for a brief moment when moving from stop. It has also always had a noticeable bump from 1st to 2nd. Nothing has changed since new.
  19. Jan 21, 2022 at 4:09 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    These aren't Dodge trucks. A 200k mile Tundra that has had a transmission rebuild would be rare.
    Honestly, the transmissions are pretty solid on these trucks. The transmission is down the list a ways on things to look out for. IMHO, the first would be rust (on the frame and body), second would be timing belt/water pump, third - radiator, then transmission.
    shifty` and txagg like this.
  20. Jan 21, 2022 at 6:07 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Transmission problems would be waaaaaaaaay down on the list of concerns for me too. Obviously frame rust issues is paramount, timing belt replacement, front suspension, 4X4 actuators, rubber seals/gaskets then maybe transmission...
    shifty` and tvpierce like this.
  21. Jan 21, 2022 at 6:19 AM
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    Definitely agree with comments on other items to inquire on. In terms of transmission, I would ask the owner what if anything he towed, and hopefully you get a straight answer. I do see some folks on the road pulling fairly large travel trailers with 1st gen Tundras. My '05 with 282k miles has had zero transmission issues. It's only towed a 4x8 utility trailer with light loads to the dump or a dirt bike.
  22. Jan 21, 2022 at 3:09 PM
    03tundrasr5
    03tundrasr5 New Member
    I have 358,437 miles on mine without any transmission issues. It is RWD and I’m the original owner. The only towing I’ve done is a flats boat. Hope this helps.
    Double DC and N84434 like this.
  23. Jan 23, 2022 at 7:34 AM
    human
    human New Member
    Bentonville
    My 02 has 333k miles and is the original trans from what I can tell. Shifts pretty good but could probably use a new trans filter(afaik its never been changed). I drained and filled it after I bought it and that really smoothed it out. It was a little firm shifting into 2nd. My dad thought it was fine but I'm picky. Mine had either 5th wheel mounting brackets or a camper in the bed too
    If you like it, buy it. If you buy something afraid of what COULD happen you'll never fully in enjoy it. Every vehicle has its warts
