PCV Valve maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rw429, Jan 18, 2022.
  1. Jan 18, 2022 at 3:05 PM
    Rw429
    Rw429 [OP] New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    Has anyone cleaned or changed out the PCV valve? I removed, checked and cleaned mine and reinstalled it, since the nearest dealer did not have a replacement part in stock. I routinely checked my oil dipstick and noticed it was almost down to the first notch hole. So I added some oil and researched that the PCV valve could be the culprit. Anyone else experience this and does it help or just leave it alone?
  2. Jan 18, 2022 at 5:04 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Not sure on the PCV spitting too much oil out enough to notice on the duo stick, but when boosted, it spits too much oil into intake and slows down the air and gums sensors up...I threw in a Radium catch can and dump it out every oil change...it usually only contains 1/4 to 1/3 of fluid...maybe a cup's worth...on my diesels I just routed the vent tube towards the ground and never had drips in garage floor...ICEs burn oil...some more than others...it maybe something more than a PCV if you regularly check your dip stick...I should probably do it more myself...
  3. Jan 18, 2022 at 5:57 PM
    2mchfun
    There certainly is some oil lost between oil changes via the pcv. I have a JLT catch can on my NA 5.7 and it catches more than one would expect. No catch can, then it's going to the combustion chamber and you can only maybe notice it on the dipstick depending on mileage between oil changes.
    HulkSmurf14 likes this.
  4. Jan 18, 2022 at 6:00 PM
    I did a PCV reroute. Crazy how much gunk gets built up in the intake.
  5. Jan 18, 2022 at 6:57 PM
    2mchfun
    WILLINH and TucsonTundra1794 like this.
  6. Jan 19, 2022 at 4:06 AM
    HulkSmurf14
    2014 Tundra Limited
    Dang! Are you using 0w20 oil or something thicker? I got more when I used what was recommended...5w30 now for me...
  7. Jan 19, 2022 at 4:08 AM
    2mchfun
    5w30 mobil one
    HulkSmurf14[QUOTED] likes this.
