Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Dec 21, 2021 at 2:38 PM
    #481
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I actually think someone’s mentioned that this is needed to match up the rear to the front since the front hubs sit out further from the LT.
  2. Dec 21, 2021 at 2:39 PM
    #482
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Turned out great!
  3. Dec 21, 2021 at 2:41 PM
    #483
    twintundra31719
    twintundra31719 New Member
    NV
    Looks great!
  4. Dec 21, 2021 at 2:50 PM
    #484
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    This makes sense
  5. Dec 21, 2021 at 2:50 PM
    #485
    BlueRibbon4x4
    Geno
    Thanks fellas!
    TRDFerguson[QUOTED] likes this.
  6. Dec 21, 2021 at 3:30 PM
    #486
    BlueRibbon4x4
    Geno
    Some better pics with the Mammoth Guards up. 54B263A9-BA0C-491E-A2E8-7B54AAB176B7.jpgCC0D71CA-9204-48DC-A271-D290348F7C7C.jpg
  7. Dec 21, 2021 at 3:33 PM
    #487
    RobertD
    Robert
    DFW, Texas
  8. Dec 21, 2021 at 3:46 PM
    #488
    BlueRibbon4x4
    Geno
    :hattip:
  9. Dec 21, 2021 at 3:52 PM
    #489
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  10. Dec 21, 2021 at 5:53 PM
    #490
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Notice any improvement on driving with those bada$$ looking UCAs?!
    Why haven't you painted your frame yet?! Looks great!!
  11. Dec 21, 2021 at 5:57 PM
    #491
    RobertD
    Robert
    DFW, Texas
    I second this! Let's make it happen.
  12. Dec 21, 2021 at 6:00 PM
    #492
    BlueRibbon4x4
    Geno
    Didn’t notice any improvement yet. I drove all highway miles home. Maybe I’ll take her out to hit some dirt in the morning.
  13. Dec 22, 2021 at 12:45 PM
    #493
    BlueRibbon4x4
    Geno
    Just took her for a quick run off-road in a spot I’m very familiar with. There’s a huge difference in the way the truck handles. I really didn’t expect much in the handling, and there’s barely a difference on the road, but a huge difference on the dirt. I’ve read lots of people saying they feel the truck is more “planted”. It really does, with much less roll over whups and valleys. I was able to travel faster over areas I had to slow down before.
  14. Dec 22, 2021 at 12:52 PM
    #494
    RobertD
    Robert
    DFW, Texas
  15. Dec 22, 2021 at 12:53 PM
    #495
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That's great to know. And now it sounds like I'll be adding UCAs in the spring...
  16. Dec 22, 2021 at 12:56 PM
    #496
    BlueRibbon4x4
    Geno
    You won’t regret it. I put them on mostly beca Of alignment and little hope that there would be a slight difference in handling. But they’re amazing. 100% worth it.
  17. Dec 22, 2021 at 12:58 PM
    #497
    twintundra31719
    NV
    :burnrubber::bikewhoops:
  18. Dec 27, 2021 at 9:32 AM
    #498
    BlueRibbon4x4
    Geno
    Just a tiny one today, getting some little mods ready to go. I wanted to be able to see the amber spots behind the grille more visible, and got some strip lights for the bed. I have small lights installed there already, they have the same clip harness so these will plug right in.
    I’m putting a bunch of coats of the 3-in-1 wax on the lenses so hopefully they’re easier to wash off without taking the grille off. 77F02184-A3B0-486E-A1D4-E75EBF0B09B4.jpgAB9BDA43-766F-4075-815F-9F0397360E30.jpg94C2C8D0-0AE6-4338-978C-17E20194D6D9.jpg8C258A9C-E9F1-440F-9550-E42C584C6683.jpg
    GAknight, TRDFerguson and RobertD like this.
  19. Dec 28, 2021 at 11:40 AM
    #499
    BlueRibbon4x4
    Geno
    Finished up the spots. Gotta wait on the bedlights. Frickin freezing here. 80F92774-5CA1-474A-88A3-27B42826C034.jpgBA2B07B0-7BBF-4ECA-A7F0-D1CCDA0D0B8D.jpg6D1F1C8D-1BFD-4498-948E-C58308017AFE.jpgA2182968-692A-4AB5-94BA-0F888263DB74.jpg
  20. Jan 16, 2022 at 6:55 PM
    #500
    BlueRibbon4x4
    Geno
    Well, I’ve been running LEDs in my headlights the least few months. They aren’t as bright as the HIDs, but they don’t use ballasts or igniters. It makes the installation nice and clean, but they just aren’t bright enough. So today I switched them over to my old HIDs. Everything went fine, but there’s a power leak coming from the HID bulbs. It took me forever to find the issue. The ballasts give power to the igniter, which ignites the HID. The ballast gives a ton of power to the HID, enough to shock you, and enough to hear a power arc from the wires if there’s a leak. It’s coming from the base of the bulb, which zapped me when I touched it. Normally you can handle the bulb as long as you grab the base and don’t touch the lava-hot bulb. So the LEDs went back in, until I can order more damn HID bulbs.
    I also cleaned up all the DRL and signal wires by replacing all the t-taps with solder and shrink tube. I may go with a whole new Morimoto HID setup for these, but we’ll see. These headlights have cost me quite a bit, so it’s hard to know when to call it quits on these retrofits. They sure are different than everyone else’s though. I’d like to keep them. E3619E86-4097-4000-BBB0-8AD56B7FD571.jpg
    GAknight, kuokoa, TRDFerguson and 2 others like this.
  21. Jan 16, 2022 at 6:58 PM
    #501
    RobertD
    Robert
    DFW, Texas
    Dang.... sucks you are having issues. Hope you get it resolved! Those lights are so sick and unique
    :headbang:
  22. Jan 16, 2022 at 7:02 PM
    #502
    BlueRibbon4x4
    Geno
    Thanks Robert! After writing everything out, I think I’m leaning to grabbing a new HID kit.
    RobertD[QUOTED] and HulkSmurf14 like this.
  23. Jan 18, 2022 at 6:07 PM
    #503
    BlueRibbon4x4
    Geno
    Never posted these up to the build page. Bedlights installed under the deck rails. These have the same riny harness clip as my old little ones, so I thought the install would be a breeze. But I had to reverse the polarity, which is stupid. From all the wiring I’ve done, I noticed that this happens from time to time. I accidentally bought the 60” ones instead of the 48” ones. So I had to trim them down and put a little black silicone in the end to seal them back up. They are connected to the cargo light. Pretty bright!35A46051-CA3A-4010-A451-EB5D4FA78F4A.jpgF7B5C37E-ACE4-4ADD-9DF6-33099B4225C4.jpg
  24. Jan 18, 2022 at 6:30 PM
    #504
    Which strips are those? I put some Nilights in mine...bright as hell for $26.00
  25. Jan 18, 2022 at 6:35 PM
    #505
    BlueRibbon4x4
    Geno
    Nilights also. These were $27.50. Ya beat me by $1.50. Nilight - TR-05 2PCS 60 Inch 180 LEDs Bed Strip Kit with Waterproof on/Off Switch Blade Fuse 2-Way Splitter Extension Cable for Cargo, Pickup Truck, SUV, RV, Boat , 2 Years Warranty https://www.amazon.com/dp/B07KXR799K?_encoding=UTF8
    HulkSmurf14 likes this.
  26. Jan 18, 2022 at 6:56 PM
    #506
    Yep same kit. I changed to a better switch though. I wired mine to the tag light circuit.
  27. Jan 18, 2022 at 6:59 PM
    #507
    BlueRibbon4x4
    Geno
    Yeah I didn’t use that little switch either. They’re on the cargo light circuit, but I was thinking of hardwiring them and putting in a ground switch when the tailgate goes down.
    2mchfun likes this.
  28. Jan 22, 2022 at 2:43 PM
    #508
    BlueRibbon4x4
    Geno
    Took her off-road this morning. Haven’t been on this trail before. Pretty sweet trail, 15 minutes from home. Love it. 336DB3D3-D362-4044-A834-962A750B914B.jpgFBA3DE1B-DE21-4924-8395-62BAD735C252.jpg73540CD6-8C84-499D-BCAB-728AA11C3C5B.jpg5C343F51-CE65-4454-A63A-FD078A65CD9C.jpg037E7F4A-C4E9-4F6F-B052-82FF2CC9EB8F.jpgB0795FE2-6D54-454A-91DF-9437D374F3D9.jpg
  29. Jan 25, 2022 at 12:30 PM
    #509
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    how do you get the power line from bed to cab?
  30. Jan 25, 2022 at 12:51 PM
    #510
    2mchfun
    You can go under the rear left door sill and tap the cargolight wire right there.
    BlueRibbon4x4[OP] likes this.
