2nd gen door trigger wire
Discussion in 'Electrical' started by trevorstuart24, Jan 17, 2022.
  1. Jan 17, 2022 at 5:27 PM
    trevorstuart24
    trevorstuart24 [OP] New Member
    Anyone know where I can tap into a wire triggered by the doors opening? Searching leads me to possible wires that will switch when doors open as well as the key fob being used but I’d prefer a wire switched solely by the doors being open since that would work best with my alarm system I’m creating. I also see a dome circuit wire on searching but I usually just keep my dome light off at all times.
  2. Jan 17, 2022 at 5:53 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Remove the dome light bulb and still use it as a trigger.
  3. Jan 17, 2022 at 7:32 PM
    trevorstuart24
    True I could do that.
    Anyone know of a wire that gets switched regardless of having the dome light switched door open or if that wire is under the driver side paneling?
  4. Jan 18, 2022 at 1:24 PM
    trevorstuart24
    thinking my best solution is tapping into the footwell light. seems like it is triggered by a ground switch rather than +12v
