2021 Crewmax TRD Sport
Discussion in 'General Tundra Discussion' started by johnjeffg, Jan 16, 2022.
  1. Jan 16, 2022 at 7:51 PM
    johnjeffg
    johnjeffg [OP] New Member
    I need help identifying the holes under the doors of my 2021 Tundra. Each hole has a rubber cap. These are not the 6 threaded holes used for mounting running boards. These are just holes that run along the bottom edge under both front and back doors.
  2. Jan 16, 2022 at 8:40 PM
    Welcome from NY.
    Pictures would help for clarification.
  3. Jan 16, 2022 at 8:52 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Pretty sure they use these holes to pump in some waxy anti-rust fluid.
  4. Jan 17, 2022 at 9:26 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Don't think you would be mounting running boards directly to your door. Maybe they're drain holes?
  5. Jan 17, 2022 at 12:46 PM
    johnjeffg
    Here are two images of the plugs. If they are drain holes, I wonder why the plugs were not removed by the dealer.
  6. Jan 17, 2022 at 12:46 PM
    johnjeffg
  7. Jan 17, 2022 at 3:15 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    I don't know. My 2018 does not have...whatever that is.
  8. Jan 19, 2022 at 8:21 PM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    My 2018 sport 4x4 has it.
