Poll - New 2022 Tundra Owners Please Post Comments on Real World Mileage
Discussion in '3rd Gen Tundras (2022+)' started by borla123, Dec 22, 2021.
Gas Mileage Expectation Gen 3 Tundra ? 17-city / 22 hwy /19 cmb (Votes can be changed later)
  1. I am achieving EPA ratings
    27 vote(s)
    27.8%
  2. I am not achieving EPA ratings
    70 vote(s)
    72.2%
  1. Jan 11, 2022 at 2:21 PM
    #151
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Go blow that smoke up someone else's ass, but here it isn't working
    BecauseRacecar and 68rs75z28 like this.
  2. Jan 11, 2022 at 2:37 PM
    #152
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    He probably gets better mpg because he didn't recalibrate his speedo... and thinks the dash is correct LOL
    Mattedfred likes this.
  3. Jan 11, 2022 at 2:41 PM
    #153
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    "This isn't politics" ...but this cat is missing a good chance at being a politician with the BS he comes up with- not sure who he's trying to convince to believe his BS, us or himself- the one thing for sure it didn't work on us!!
    Totherion likes this.
  4. Jan 11, 2022 at 3:40 PM
    #154
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Well shit! I missed the good mpg boat with my old Tundra. I should get a 2022 so I can get 2 to 3 mpg better than what I get now.
    Totherion and Cock-A-Doddle-Do like this.
  5. Jan 12, 2022 at 4:15 AM
    #155
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    The difference between the Toyota Tundra with the 3.5TT and a Ford F-150 with a 3.5TT is that the Toyota weighs a LOT more. They didn't put it on a diet like Ford did. From looking at door jamb placards it appears that there could be as much as 1,000 lbs. difference in weight between the two. There is no way a Toyota with 3.5TT is ever going to see the mileage that a Ford 3.5TT sees based on that alone, and the Ford has been notoriously low compared to EPA window sticker ratings.
    I'd never buy a twin turbo engine in a pickup truck expecting to get fuel economy out of it.
    Metro14536 and KNABORES like this.
  6. Jan 12, 2022 at 5:27 AM
    #156
    borla123
    borla123 [OP] The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Yes, Weight (Curb Weight and GVWR) directly affects mileage.
    As was asked in the original post please please indicate what weight you are carrying, or towing.
    This extra information will help others the most.
    ALSO Not to take this discussion sideways...
    Curb Weight
    2,310 to 2,550 kg Tundra
    1,824 to 2,274 kg Ford F150
    GVWR
    3,191 to 3,345 kg Tundra (28% - 24% more)
    2,726 to 3,243 kg Ford F150 (33% - 30% more)
    Numbers from internet. If wrong let me know and I will update.
    FWIW
    On paper the F150 outperforms but ....IMO.... take that with a grain of salt.
    There are no standards I know of for payload ratings (correct me if I am wrong) .....this means ...manufacturers set their own numbers.
    The Detroit 3 I have found like to brag more, push the limit, and set the numbers high.
    IMO Toyota sets payload ratings conservatively, because they are the manufacturer looking for reliability durability. Goes with the philosophy.
    For this reason also, I kind of chuckle at people that are concerned with Tundra payloads. You know, the sticker on the door.
    I can only assume they have never owned a 2.5 gen or earlier Tundra, exceeded payload and saw how stable it remained driving and getting to your destination.
    rruff likes this.
  7. Jan 14, 2022 at 9:54 AM
    #157
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I’m new to a truck that calculates your fuel mileage. Curious do you need a dealer to calibrate the speedometer if you change tires size or is that automatic feature by some chance? And how accurate is the fuel mileage when you go from e10 to non ethanol gas? My scan gauge I had on my last truck needed recalibrated constantly to stay accurate.
    DesmoDoe likes this.
  8. Jan 14, 2022 at 10:03 AM
    #158
    Totherion
    Totherion New Member
    Excellent info. So we know now that there is about 5 gallons in reserve when "empty".
    Makes you wonder how much more useful range you can get out of it.
    When I get mine, I think I will willfully drive it until the tank goes dry just to see. I'll take 10 gallons in the bed with me when I try this, lol.
  9. Jan 14, 2022 at 10:11 AM
    #159
    Toyota1234
    Jack
    With how long the gas tank is I suspect if you drive under the empty mark you are in risk of starving the fuel pump. Specially if you park at the wrong incline like the previous gen.
  10. Jan 14, 2022 at 10:16 AM
    #160
    borla123
    Ontario
    My son drives at a half tank or less. I have seen it on the E many times. Drives me nuts.
    I am a fill it up at 1/2 full type of person.
    The 2.5 gen from full went a long time before the needle started moving - but once it did - watch out ! lol
    The new tank below not so sure about that anymore .
    Totherion[QUOTED] likes this.
  11. Jan 14, 2022 at 10:18 AM
    #161
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I don't even know if the dealer can do it on the 2nd gen. I just multiply the miles or mph by 1.08 (tires are 8% larger).
  12. Jan 14, 2022 at 10:31 AM
    #162
    Totherion
    I cannot stand empty tanks either. But I just need to know how far I can go before I get the sweats.
    Rwaters likes this.
  13. Jan 14, 2022 at 10:32 AM
    #163
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I generally fill up in between 1/2 and 1/4, I only took it that far because a few people were curious how many gallons it took on E. Then I became curious and here we are.
    The next tank I’m going to try will be ethanol free. My 21 Silverado performed better in every way when I used it. I didn’t use it all the time, since it was always $8-10 more to fill up.
    Henry1jg likes this.
  14. Jan 14, 2022 at 10:38 AM
    #164
    Totherion
    Same here. My 6.2 loves 100% gasoline and rewards me with great mpg.
  15. Jan 14, 2022 at 10:42 AM
    #165
    mass-hole
    mass-hole New Member
    Ethanol has a higher heat of vaporization than gasoline, nearly double. So while pure gas has slightly more energy than E10(3%), E10 has a higherHOV and has a greater cooling effect which means it should have an effect on timing. I think this is important on the small displacement boosted engine vs the slight energy bump from E0 assuming the octane rating is the same.
    On a big NA motor like the 6.2L, I would think it would be the opposite as you are not heating the intake air with two compressors spinning at 150,000 rpm
  16. Jan 14, 2022 at 10:44 AM
    #166
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    Exactly why I like to look at everything in my POV. Almost every car I’ve ever had I get 1-3 mpg lower then the epa rating. So in I get around 11 city and 15 highway in my 2014 tundra. So i can make a decent estimation that in the new one id get maybe 15 city and 20 highway. Everyone saying they get 2 mpg over the epa rating on the 5.7 tundra what makes you think you can’t do the same in the new tundra?
  17. Jan 14, 2022 at 11:00 AM
    #167
    WXman
    WXman New Member
    Kentucky
    I can't comment on the 3rd gen trucks but my 2nd gen (2016) is amazingly accurate on the dash display. I hand calculate my mileage with each fillup and then reset the dash display. At the end of the tank, my last three tanks have been DEAD ON what the dash showed me. It's crazy. Most trucks I've had from other brands were usually a few tenths to as much as 1.5 MPG off. This Toyota is spot on.
    Something else odd I noticed is that on stock size 275/65R18 tires, using GPS to verify, my speedo was about 0.5 MPH fast. Now, on 275/70R18 tires it's 0.5 MPH slow. In both cases it's REALLY hard to see any difference on the speedometer. This is at 55 MPH. Have to look really close at the needle to slightly see it. Speedo is still pretty much dead on. I thought that was strange. And the MPG display is still spot on also.
    As a side note, going to 275/70 tires obliterated my mileage. I was averaging 15 before the switch which honestly I was very happy with. After the new tires I immediately dropped to 13 and that was painful. If I could do it over again I may have reconsidered.
    hANNAbONE likes this.
  18. Jan 14, 2022 at 11:20 AM
    #168
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    To me the weird thing is TTV6's don't get much better MPG's at altitude compared to V8's. TFL compares every brand at altitude and there isn't a huge difference in MPG's or performance with TTV6 vs V8.
    Metro14536 likes this.
  19. Jan 14, 2022 at 11:24 AM
    #169
    did you switch from a lighter P rated all season type tire in the factory size to a heavier LT rated all terrain in the larger size?
  20. Jan 14, 2022 at 11:32 AM
    #170
    WXman
    WXman New Member
    Kentucky
    Yeah but if you think about it really it makes sense. Power is a product of air and fuel. An engine that makes more power is going to need more fuel and more air. At altitude when the air gets thin, that turbo is working hard to stuff as much air as it can into the engine but then the ECU says wait a minute, gotta' keep that stoichiometric ratio balanced so it tells the injectors to increase fuel supply.
    Even at low altitude the V6 twin turbo engines will see the same MPGs as a V8 when towing because the turbos stay spooled up all the time and that signals for more fuel.
    Acedude[QUOTED] likes this.
  21. Jan 14, 2022 at 11:33 AM
    #171
    WXman
    WXman New Member
    Kentucky
    Yeah, there's a bit of a weight increase per corner. Something like 20 lbs. total per corner. But I've done aftermarket wheels and tires on at least 10-15 trucks and Jeeps in the past and I've never seen a 13% hit right off the bat like this. It's very odd.
  22. Jan 14, 2022 at 11:45 AM
    #172
    rideandfly
    rideandfly New Member
    First time I filled up our 2022 SR5 Crewmax Tundra after leaving the dealership with 227 miles used 11.3 gallons getting slightly above 20 MPG around town & highway unloaded driving. I am very easy on the throttle in hilly country.
    mountaingroan likes this.
  23. Jan 14, 2022 at 12:27 PM
    #173
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Yep. Bigger tire and probably more important E load so significantly heavier. Same size I run and yes I saw a couple MPG drop too. Sure wish some decent larger than stock tires were available in 18s and C load.
    Acedude and WXman[QUOTED] like this.
  24. Jan 14, 2022 at 12:54 PM
    #174
    Brocksw
    Brocksw New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    Feel sorry for the OP. Basically 6 out of 7 pages of not answering his question which was the entire point of the thread.
    DesmoDoe, jpod, Chvman98 and 3 others like this.
  25. Jan 14, 2022 at 1:27 PM
    #175
    wired
    wired New Member
    2022 Tundra Black SR5
    Back to the original question...first week mostly rural driving, no highway, some city stop and go 19.5 mpg (beats my Jeeps usual 15 same circumstances)
    Edited to add: warm climate, just me, no cargo. Math at the pump first fill-up (dealer gave me a full tank.) 4x4 SR5
    Acedude likes this.
  26. Jan 14, 2022 at 1:34 PM
    #176
    Rwaters
    Rwaters New Member
    Crazy, best I’ve seen was mid 16 and I drive pretty mixed.
  27. Jan 14, 2022 at 3:48 PM
    #177
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
  28. Jan 14, 2022 at 5:39 PM
    #178
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    jpod, FirstGenVol, Chvman98 and 3 others like this.
  29. Jan 15, 2022 at 5:16 AM
    #179
    HBV2017
    HBV2017 New Member
    Hey everyone!
    I just traded my 2020 Tundra CrewMax Limited and picked up a 2022 Tundra CrewMax with the 6.5 ft bed. My daily commute involves 40 highway miles, cruising at 70 mph. I don’t know if it is due to the break-in period on the new engine, but in my 2020 I averaged 16 mpg during my daily commute, and on the 2022 I’m only averaging 16.1 mpg. Both Tundras had the larger fuel tank. In the 2020 a full tank had an estimated range of 470 miles, in the 2022 a full tank has an estimated range of 445 miles.
  30. Jan 15, 2022 at 6:43 AM
    #180
    Totherion
    Good info.
    How many miles logged so far?
    What is the outside temperature during these drives?
