08 Tundra 4x4 P2128 code
Discussion in '2nd Gen Tundras (2007-2013)' started by Swchevy85, Jan 14, 2022.
  1. Jan 14, 2022 at 5:09 PM
    Swchevy85
    Swchevy85 [OP] New Member
    2008 white Tundra 4x4
    Hey guys I'm new here and have done a small search on here for the P2128 code with little luck. So I was going around a curve in my 08 Tundra 4x4 and the VSC light the CEL the 4lo and the stability control light all came on and when I put my code reader on it it has the P2128 code (Throttle pedal position sensor/Switch E circut input high). I've changed the throttle position sensor out and I changed the ECM out but still have all the lights and still in limp mode. Any ideas on what to do next any advice would be greatly appreciated.
  2. Jan 14, 2022 at 5:17 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Did you change the pedal? Or another sensor? Sounds like it’s the sensor in the pedal.
  3. Jan 14, 2022 at 5:19 PM
    Swchevy85
    Dalandshark yes sir I changed the pedal out.
  4. Jan 14, 2022 at 5:19 PM
    Dalandshark
    Northwest
    Eibach Level LIft
  5. Jan 14, 2022 at 5:26 PM
    Swchevy85
    I came across that same link and tried testing the APP but I could never get the code to clear to be able to test the APP so I just replaced it with no luck. So I just replaced the ECM with hopes that it would fix it cuz that's the other option but that didn't work either.
  6. Jan 14, 2022 at 5:55 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    this might help ;)
  7. Jan 14, 2022 at 6:31 PM
    Swchevy85
    NueveTundra thank you sir, this is the same thing Dalandshark sent me but without being able to clear the DTC I just went ahead and changed the pedal and the ECM with no luck on fixing it.
  8. Jan 14, 2022 at 6:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Time to test the wiring circuits, especially the EPA2 circuit between pins 2 (pedal connector) and 60 (ECU connector)
    Swchevy85[OP] likes this.
  9. Jan 14, 2022 at 6:51 PM
    Swchevy85
    Yes sir I think you're rite
  10. Jan 28, 2025 at 6:22 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Was this figured out? Did you replace the harness wire and remedy the tps failure?
    Mdl likes this.
