Front Bumper Gap Not Even On Both Sides
Discussion in 'Suspension' started by cementsharktrd, Jan 14, 2022.
  1. Jan 14, 2022 at 8:31 AM
    cementsharktrd
    cementsharktrd [OP] New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    Does anyone know how to fix that gap between the bottom of the grille and the top of the front bumper not being even on both sides? Anyone else have this problem? You can visibly tell the unevenness in the photo.
  2. Jan 14, 2022 at 9:24 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    The body likes to move around because it’s sitting on the rubber body mounts. The most noticeable spot to see this movement is at the gap you mentioned.
    Black Wolf likes this.
  3. Jan 14, 2022 at 9:27 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Also, to note, the bumper is attached to the frame, so when the body rolls (during a turn for example) the frame doesn’t, as much, so you want that gap there otherwise it’ll make contact with each other and start rubbing the paint off.
  4. Jan 14, 2022 at 10:34 AM
    cementsharktrd
    Demetrio
    I'm just talking about how the gap on the left is way bigger than the other side. It seems to me that one side needs to be bolted in more? Its slanting to one side.
  5. Jan 14, 2022 at 10:47 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I fixed mine when I upgraded my headlights. I had my grille and the pieces below the headlights off. It was several years ago so all I can tell you is there are some bolts that are exposed on each side when you get those parts off.
  6. Jan 14, 2022 at 12:22 PM
    timsp8
    NY
    You might be able to unbolt the bumper on the drivers side (it’s only 4 bolts if I remember right) and lower it a little, but then the gap on the outside under the headlight would be bigger. Not really a way to adjust the grille. Might have to live with it.
  7. Jan 14, 2022 at 12:25 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Did you hit something by any chance?
  8. Jan 14, 2022 at 1:11 PM
    ThisGuy03
    ThisGuy03 New Member
    Las Vegas, NV
    ‘17 CM LTD TRD 4x4 MGM
    King 2.5s..TC UCA..35x12.50-18 M/T..AMP Steps
    Mine is the same way. Doesn’t bother me, really.
  9. Jan 14, 2022 at 1:19 PM
    2mchfun
    Start it up, engage beast mode, launch and enjoy! Life is too short for you to allow such nonsense to consume your time.
  10. Jan 16, 2022 at 6:28 PM
    cementsharktrd
    Demetrio
    no
  11. Jan 16, 2022 at 6:28 PM
    cementsharktrd
    Demetrio
    Amen brother
  12. Jan 16, 2022 at 6:34 PM
  13. Jan 16, 2022 at 6:35 PM
    Retired...finally
    Get rid of the no fat chicks sticker?
    2mchfun likes this.
