  1. Jan 12, 2022 at 11:09 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    theres bound to be a way to run some bellcrank or push rod linkage, maybe recessed and run with the tire iron.
  2. Jan 12, 2022 at 11:09 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Now it's all making sense, ditch the stud that can affect free spool and beat up syn line. Attach line with wraps and no stud.
    Thanks @FrenchToasty !
  3. Jan 12, 2022 at 11:12 AM
    I tried to find videos or more info from when I ordered mine, I think you still need to use the stud, but this prevents the stress on the stud and on the line at the stud, again it helps keep minimal wraps on your drum without risk of the line coming all the way off
  4. Jan 12, 2022 at 11:14 AM
    alb1k
    Left Coast
    It's good
    I found a couple of videos, I'll look at it some more, but I'm pretty sure you can ditch the stud.
  5. Jan 12, 2022 at 11:19 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Wouldnt the stud be useful holding tension while you bust out the shovels? I thought that was the static limit (maybe moreso on small winches.)
    RUSTYNUTS likes this.
  6. Jan 12, 2022 at 11:29 AM
    alb1k
    Left Coast
    It's good
    The stud on mine is a screw to be used as a line end keeper, no load bearing at all. the initial 8-10 wraps on the drum are what can have a load. But these set up the wraps so you can't unspool past them. The Red Winch Plasma lock is the same but longer to lock down more initial wraps
  7. Jan 12, 2022 at 11:36 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My bad, i was thinking locks. I know when i shop winches i want a spool lock.
    alb1k likes this.
  8. Jan 12, 2022 at 11:36 AM
    alb1k
    Left Coast
    It's good
    This illustration shows how the wraps to the left holds the webbing loop on the right in place preventing spooling past the minimum wrap.
    You don't turn the drum to get the initial wraps on, you feed the line around the stationary drum. That allow you to create a stop point.
    I didn't even know what this was an hour ago, lol.
    CodyP and oscardog86 like this.
  9. Jan 12, 2022 at 12:03 PM
    Yep
    alb1k[QUOTED] likes this.
  10. Jan 13, 2022 at 4:09 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Got my Xmas present to myself in today. It’s gonna feel good being able to see at night.
    Also got my sliders bent… finally! Now to prep and bug a friend with welding it up. Planning on bolt on sliders.
  11. Jan 13, 2022 at 4:14 PM
    So hot!
    We really need to get a AZ-CA meet up/trail-a-thon going!!!
  12. Jan 13, 2022 at 4:50 PM
    Voss
    2003 AC TRD 4x4
    Sounds good to me! Almost have my portable office set so I can go baby go! And I may just be in AZ within the next couple of months to visit a buddy. He wants to get out on the trails too, he just wasn’t sure if his Taco with rear diff locker was capable lol.
    Darkness likes this.
  13. Jan 13, 2022 at 5:56 PM
    He clearly needs a v8 4wd tundra!
    bmf4069 and Voss[QUOTED] like this.
  14. Jan 13, 2022 at 6:19 PM
    daveeasa
    Ok, guys, some quick advice please. Looks like my dust shields are rubbing post lift install. Jason said it’ll be fine but I’m thinking I can at least try to fix it. Should I remove one wheel at a time and whack it with a hammer or take it to a shop or is it something I can do with the right technique with the wheels on?
  15. Jan 13, 2022 at 6:42 PM
    Voss
    2003 AC TRD 4x4
    Lol. He’s a fan of the best gen but man, he literally thought his truck wasn’t good enough because of all the mods he’s seen on other Tacos and 4Runners.
  16. Jan 13, 2022 at 6:44 PM
    Is he in P town or T town? Let me know and maybe we can find a moderate trail for him to pop his confidence cherry
    Voss[QUOTED] likes this.
  17. Jan 13, 2022 at 7:25 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    I like the look of this very much!
    What vendor did the headlights come from, is a new housing included in the price? Ballpark the cost, if you don't mind!
    This is exactly the route that I want to go, my current lights are pathetic at best!
    I really need way better color temp & many more Lumins!
    Looking for an upgrade, help me spend some bucks!
  18. Jan 13, 2022 at 8:02 PM
    alb1k
    Left Coast
    It's good
    Don't forget the light bar :)
    Voss likes this.
  19. Jan 13, 2022 at 8:14 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Not today, but last night I borrowed my old neighbors mill to finally mod my 14wa calipers.
    0h6SR5, oscardog86, bmf4069 and 6 others like this.
  20. Jan 13, 2022 at 8:19 PM
    I thought for a sec you broke off a drill bit in your press.
  21. Jan 13, 2022 at 8:25 PM
    KK6PD
    ROAD
    Hey that looks like a Bridgeport, I have one of those, what a great tool!
    This is exactly the reason I bought mine, getting metal worked so it works for your project!
    chrisb likes this.
  22. Jan 13, 2022 at 8:29 PM
    KK6PD
    ROAD
    That looks like a 3/4", maybe 7.8" 4 flute end mill, you snap one of these, you are reading the "Speeds & Feeds" chart wrong!!
    bmf4069, shifty`[QUOTED] and chrisb like this.
  23. Jan 13, 2022 at 8:54 PM
    Voss
    2003 AC TRD 4x4
    He’s in Peoria part of Phoenix. We’ll show him just what he has alright.
    Says Sedona is only about an hour n a half away… I missed T2S, wouldn’t mind going there…
  24. Jan 13, 2022 at 9:00 PM
    Voss
    2003 AC TRD 4x4
    Thanks but I spent more than I prob had to for light. I like driving to far off destinations in the middle of the night and tired of driving blind, that’s why I treated myself to the Morimoto 2.0.
    KK6PD[QUOTED] likes this.
  25. Jan 13, 2022 at 10:07 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Hahaha. It does a bit.
    It is.
    1/2" actually. Low speed, low feed and cutting fluid.
    Granted its completely manual so no worries about inputting the wrong settings and letting it go.
    chrisb and KK6PD[QUOTED] like this.
  26. Jan 13, 2022 at 10:07 PM
    Voss
    2003 AC TRD 4x4
    You noticed it huh. Looks even better in person cause the amber portion stands out more. That light bar was one of the first mods I did on my own(maybe why I like it so much). Nothing fancy, think it was $180 no name brand but uses bulbs from the same manufacturer as top name brands(Cree if I remember correctly). Sealed it up with silicone and knock on wood, it’s held up fairly well through multiple river crossings.
    I know it’s nothing special but one of my fav parts of my truck.
    chrisb and KK6PD like this.
  27. Jan 13, 2022 at 10:31 PM
    alb1k
    Left Coast
    It's good
    Looks pretty awesome. I've often thought that is a great spot for a bar. Not sure how many people have done it, great job IMO.
    oscardog86 and Voss[QUOTED] like this.
  28. Jan 14, 2022 at 12:48 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    176k oil change and tire Rotation
    oscardog86, bmf4069, chrisb and 3 others like this.
  29. Jan 14, 2022 at 5:50 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    T2S 2022 was announced for April 26 - May 1.
    I'm probably going to try to take two weeks off for it, maybe bring the mobile office again.
    @FrenchToasty Let's get planning
    Voss[QUOTED] and FrenchToasty like this.
  30. Jan 14, 2022 at 5:54 AM
    I’ll probably be there Wednesday thru Saturday, trails and stuff Thursday and Friday
    Voss likes this.
