RC 6 Inch lift Vibration with Carrier bearing drop installed
Discussion in 'Suspension' started by Valhalla76, Jan 13, 2022.
  1. Jan 13, 2022 at 6:02 PM
    Valhalla76
    Valhalla76 [OP] New Member
    2018 Toyota Tundra Limited 4x4
    RC 6 inch lift
    I have a 2018 Tundra Limited 4x4 has 32k miles on it, I've recently had a 6 inch lift installed, I've also had the carrier bearing drop kit installed using all 6 shims 3 on each side. My issues I am having is when driving and I left off the gas after 30-40mph I get an annoying vibration sound last a few seconds, when I press back on the gas I get a small split second vibration sound. I've attached a picture of the spacer on the back, does anyone know if it looks like its going the right direction? Rough Country asked that and I couldn't answer that. Besides that question from rough country they haven't been able to help me. Any other thoughts of what I can do, I'm at my wits end?
    texasrho83 likes this.
  2. Jan 13, 2022 at 6:42 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What you have pictures is a leaf spring. The carrier bearing drop is something different
  3. Jan 13, 2022 at 6:49 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    k0diak8o8 and fisherman951 like this.
  4. Jan 13, 2022 at 6:54 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    This is a carrier bearing drop kit. Probably what you need to get the vibration to go away
  5. Jan 13, 2022 at 6:57 PM
    Valhalla76
    RC 6 inch lift
  6. Jan 13, 2022 at 6:58 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Correct. I have one.
  7. Jan 13, 2022 at 6:58 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    How thick are the spacers?
  8. Jan 13, 2022 at 7:02 PM
    Valhalla76
    RC 6 inch lift
  9. Jan 13, 2022 at 7:06 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  10. Jan 13, 2022 at 7:07 PM
    Valhalla76
    RC 6 inch lift
    I have done that one shim then two shim and then three shim. the third one gives me the less Vibration.
  11. Jan 13, 2022 at 7:08 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Maybe you need one more
  12. Jan 13, 2022 at 7:09 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wonder what would happen if you added another.....
  13. Jan 13, 2022 at 7:11 PM
    Valhalla76
    RC 6 inch lift
    I might have to try, Rough Country hasn't been any help at all.
  14. Jan 13, 2022 at 7:11 PM
    timsp8
    NY
    Sure it’s the driveshaft? Maybe a tire is out of balance. Was it aligned properly after lift?
  15. Jan 13, 2022 at 7:13 PM
    Valhalla76
    RC 6 inch lift
    Yes, the alignment was professionally done, after the install. new tires were put on and alignment done at that time.
  16. Jan 13, 2022 at 7:15 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I wouldnt put bigger tires on it until you figure it out. That will just make it harder to diagnose. It sounds like the angle of the driveshaft is off slightly causing the vibration. Doesn't their lift kit come with shims? I would use the one they supplied first.
    Also the lift blocks are directional, they should be installed so the axle pinion points up towards the transmission with the fatter end of the lift block facing the rear. I cant tell from your pictures if it's correct or not.
  17. Jan 13, 2022 at 7:18 PM
    Valhalla76
    RC 6 inch lift
    It doesn't come with shims in the lift kit, you have to buy it separately.
  18. Jan 13, 2022 at 7:22 PM
    Half Assed
    Heartland Florida
    Hmm strange they dont include that. Can you take a better picture of the lift blocks from the side?
    I might have some shims from my fabtech kit laying around. I didnt need them on my regular cab. I will try to find them and measure them.
  19. Jan 13, 2022 at 7:25 PM
    Half Assed
    Heartland Florida
    The shims from my fabtech 6" lift kit measure 1" thick. Their kit uses an angled 3" lift block in the back.
  20. Jan 13, 2022 at 7:26 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Which RC lift did you go with
  21. Jan 13, 2022 at 7:31 PM
    Valhalla76
    RC 6 inch lift
    Do these pictures help?
  22. Jan 13, 2022 at 7:36 PM
    Valhalla76
    RC 6 inch lift
    I did the 6 inch Lifted Struts with the V2 Monotube shocks
  23. Jan 13, 2022 at 7:38 PM
    Half Assed
    Heartland Florida
    Yeah those are better. Still hard to tell though. The lift block in the second picture looks backwards to me, but I dont know if RC uses angled blocks or not. I assume they do.
    I would measure them to make sure. The shorter side towards the front and the slightly taller side to the rear.
    It kinda makes sense to me if they are backwards. In my experience the slower the speed associated with the vibration, the worse the driveshaft angle is.
  24. Jan 13, 2022 at 7:52 PM
    Valhalla76
    RC 6 inch lift
    Good call, I just measured the side closest to the front is taller and the side closest to the rear is like a 1/4 inch shorter.
    Thank you kind sir!
    I'll report back once I get it fixed.
    Half Assed[QUOTED] likes this.
  25. Jan 13, 2022 at 8:01 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's my old angled block.
    Here is my CB spacer dropping my carrier bearing. My lift kit didn't come with a drop.
    Valhalla76[OP] likes this.
  26. Jan 13, 2022 at 10:07 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    You need to figure out your working angles at the rear diff and carrier bearing, then try to make them the same as close as you possibly can. This will also force you to make sure the lead (shorter) drive shaft is also at the same angle as the working angle on the transmission/transfer case U-joint.
    Here’s a very good video explaining it:
    https://youtu.be/f1m-Fh5kiRU
  27. Jan 14, 2022 at 3:29 AM
    To start with, your shims may not be thick enough. Coachbuilder kits are 3/4 thick for 0-2 inch lifts, and 1.25 for 3-5 inch lifts. If yours are not 1.25 thick on each side, I would ditch those shims and get the Coachbuilders. The 1.25 comes with the longer bolts as well. The taper on the blocks will make a difference for sure, especially since they were installed backwards. On that note, do not reuse those ubolts, especially with that size block. Ubolts are designed for a one time use. And yes, RC's customer service is not the greatest.
  28. Jan 14, 2022 at 4:20 PM
    Valhalla76
    RC 6 inch lift
    That was the issue, no more vibration!!! thank you for your help greatly appreciated.
    Now time to decide on an exhaust...
    Rugerla1 and Half Assed[QUOTED] like this.
  29. Jan 14, 2022 at 8:20 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    I need to play with mine some more. Dealership installed a CB drop kit today but still has a shudder. Was hoping it was going to be that easy.
