Rack and Pinion failure from leveling kits?
Discussion in '2nd Gen Tundras (2007-2013)' started by Drew1, Dec 29, 2021.
  1. Dec 29, 2021 at 6:26 AM
    Drew1
    Drew1 [OP] New Member
    2007 Tundra 5.7 4wd
    So I read this article that states there's a correlation between leveling & lift kits and rack and pinion failure: 2009-2012 Toyota Tundra Steering Rack Failures Related to Lift Kits | Tundra Headquarters Blog
    My 2007 4wd has a 3" leveling kit, diff drop, and 275/65/20 tires, which is how I bought it (with no idea of how long it's been like that) so the article definitely caught my attention.
    I've seen enough lifted Tundras that I can't imagine the failure rate is as high as being reported, but I would like to hear from actual Tundra owners to find out what the truth really is on this.
    What have you all experienced? Anyone actually remove their lift or leveling kit because of repeated rack failure?
  2. Dec 29, 2021 at 7:04 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    According to the article: Toyota states: “Some 2009-2012 Tundra vehicles may exhibit a condition where the Steering Rack shows evidence of leakage at the bellows (boots). This may occur on non-modified, original equipment vehicles as well as modified (lifted) vehicles.”
    I don't see where it says lift kits alone are causing the problem. The article clearly says that it occurs on non modified and modified vehicles.
  3. Dec 29, 2021 at 7:15 AM
    Drew1
    2007 Tundra 5.7 4wd
    True, but the comments section of the article seems filled with people sharing their experiences reflecting the accuracy of the claims.
  4. Dec 29, 2021 at 7:32 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    A leveling kit itself isn't going to cause any problems with your steering rack. Especially if you have a diff drop installed also.
    Your three major contributors to steering rack failures (other than a collision) are the following and in this order:
    1. Regularly holding your steering wheel at full lock when turning.
    2. Turning (steering) your wheels against a solid obstruction beside your front tires.
    3. Over-size tires.
    You could include offroading on this list if you wanted, but technically those stresses are covered in #1 and #2. If you avoid #1 and #2 then #3 isn't a serious issue.
  5. Dec 29, 2021 at 8:09 AM
    Shark Bait
    Shark Bait Not new anymore
    2019 Platinum
    Some of the coal mines (strip mine) I’ve done work for used Tundras for a while. They were all in stock form but many had issues with the rack and pinions. To the point that they mostly went away from the Tundra in their applications. They’re just not made to handling the muck and slurry I guess.
  6. Dec 29, 2021 at 9:45 AM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    Always make sure your rolling while turning the wheel. As in, get moving before you turn your steering wheel even if it’s 1 MPH! It removes a ton of stress on your rack. When I back out of my driveway and then stop to go forward I always make sure I am rolling again before I start to turn my wheels. Sitting still a turning is twice as hard on the rack
  7. Jan 12, 2022 at 1:22 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Theres a new Recall on some of the rack and pinions for selected part#s due to a flaw in design or build that causes the leak.
