3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Jan 12, 2022 at 9:57 AM
    #211
    PJzblueprint
    PJzblueprint New Member
    PJ
    2022 Tundra Limited Crewmax 4X4
    Just finished installing Toyota Tonneau cover. Moved rails down and added rails for tonneau. All came in the kit from Sparks. Will put on Toyota running boards tomorrow.
  2. Jan 12, 2022 at 10:01 AM
    #212
    PJzblueprint
    PJ
    Got these flat oval running boards and bolts from Sparks. Install was simple once I figured out that the bolts were already on the truck. Just loosen top bolt on each end and slide the bracket on and tighten and then put in rest of bolts. 84395D1B-B6CF-465F-BF74-A8E7C8F30B27.jpg84395D1B-B6CF-465F-BF74-A8E7C8F30B27.jpg
    BigArt, rideandfly, MTRock and 3 others like this.
  3. Jan 12, 2022 at 10:29 AM
    #213
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    You've got the 5.5' bed so your part number was PT954-34220-02, correct?
    I cannot wait to get mine installed. The dealership called this morning, and the tonneau cover is in. He mentioned the box is super heavy and asked me to call them before I came so they could schedule pickup. I won't be able to pick it up until Friday afternoon, so this is going to be my Saturday morning project. I'm pretty excited!
  4. Jan 12, 2022 at 10:38 AM
    #214
    jimfish98
    jimfish98 [OP] Shorty
    I have MS and a heart condition and picked up the tonneau box and put it in my bed myself. The rails are a bit heavier, but still not too bad. Your dealership is full of babies lol.
    EvilSteve likes this.
  5. Jan 12, 2022 at 10:39 AM
    #215
    jimfish98
    Any reason for the diagonal drain run? I just went straight down on my install to shorten the runs and keep them tucked in the corner.
  6. Jan 12, 2022 at 10:57 AM
    #216
    Tundrariat
    Tundrariat New Member
    How much is the cover?
  7. Jan 12, 2022 at 11:01 AM
    #217
    KroppDuster
    Bilstein 5100s
    MSRP is $1195, I believe. Though if you can snag it via parts.toyota.com, lots of dealers are offering between 10% - 15% off right now. Even at my local dealer (they don't participate in parts.toyota.com BTW) they gave me 10% discount off MSRP.
    It's about $200-$250 more than almost the exact same tri-fold cover in the aftermarket which is the BakFlip MX4. The problem is the OEM bed cover is available now. BakFlip won't release theirs for another month or so.
  8. Jan 12, 2022 at 11:20 AM
    #218
    theguz
    theguz New Member
    2022 White Tundra SR5 4x4
    Hoping to keep my TRD wheels and just get new 35s
  9. Jan 12, 2022 at 2:03 PM
    #219
    PJzblueprint
    PJ
    I just followed instructions on where to put drains. Straight down would be cleaner. There were holes already present and Toyota said to be careful not to drill into gas tank if you drill other holes. I am an basically learning as I go.
  10. Jan 12, 2022 at 2:06 PM
    #220
    PJzblueprint
    PJ
    Sparks had it, $972.63 plus shipping. I talked to them prior to them putting online. I see now it is priced higher on the website, maybe demand. Be sure to ask for ship discount too!
  11. Jan 12, 2022 at 2:11 PM
    #221
    PJzblueprint
    PJ
    Yes. 5.5’. I put it in myself. Heavy part is the cover itself, lifting onto rails. I got instruction off this site. Very Helpful!!
  12. Jan 12, 2022 at 8:20 PM
    #222
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    should work, have seen it done, but cannot guarantee it
  13. Jan 13, 2022 at 1:43 AM
    #223
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I am running 295/70/18s on stock OR wheels and bo leveling with no rub. Works out to 34.3 around and 11.6 across.
    Tires are Atturo Trailblade.
    From my understanding you may need at lease that 2” level in front to avoid rubbing.
    TN Tundra2 and Bradanglin22 like this.
  14. Jan 13, 2022 at 3:50 AM
    #224
    nodak67
    nodak67 New Member
    JR
    from what i watch in the tear down video, the lugs are 21mm now instead of 22mm in the old gen tundra.
  15. Jan 13, 2022 at 8:02 AM
    #225
    rideandfly
    rideandfly New Member
    Who-V, Henry1jg, Jkeown and 6 others like this.
  16. Jan 13, 2022 at 8:09 AM
    #226
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    1st 3rd gen stormtrooper?
  17. Jan 13, 2022 at 8:21 AM
    #227
    rideandfly
    Didn't think about that, but you're right! :alien:
  18. Jan 13, 2022 at 8:27 AM
    #228
    Tundrariat
    rideandfly[QUOTED] likes this.
  19. Jan 13, 2022 at 8:42 AM
    #229
    rideandfly
    How do ya'll think flat finish white or color matching paint or chrome insert decals would look on the front bumper? Not aware of any being available, yet.
    docfnky likes this.
  20. Jan 13, 2022 at 8:47 AM
    #230
    KroppDuster
    Bilstein 5100s
    I think you mentioned that you have an SR5. Is it a Sport model or something? Just curious because I've only seen that black trim at the top of the tailgate on the SR models.
    Also...in looking at your bumper...it looks like it has OEM plastic trim pieces ("caps" maybe?) over the 2 areas where the chrome peaks out on the other models. I wonder if those body pieces will eventually be able to order from Toyota to cover the chrome? If so, I might try & order them in the future to see if I can cover the chrome. It would be interesting to try.
    If you ever get adventurous...see if you can pop those off and take a look at what is underneath. :D I wonder if you'll find the chrome just covered up or just a steel bumper. :monocle:
  21. Jan 13, 2022 at 8:52 AM
    #231
    MadMaxCanon
    I would keep it as is honestly. It actually looks pretty good, the right amount of break in color in the right areas. long live the imperium!
    bigjuice likes this.
  22. Jan 13, 2022 at 8:54 AM
    #232
    DexterL
    DexterL New Member
    thats just for the lug nuts though right, shouldn't matter on the wheels
  23. Jan 13, 2022 at 8:55 AM
    #233
    DexterL
    DexterL New Member
    I would just do the Tundra lower trim piece to make the grill framed in
    jpod and rideandfly[QUOTED] like this.
  24. Jan 13, 2022 at 9:09 AM
    #234
    rideandfly
    It's a base SR5 trim, painted white painted plastic bumper corners, where the chrome is on some bumpers. They're not covering other bumper parts. Have not looked in person at chrome bumper parts, only in photos, but the white parts are replaceable:
  25. Jan 13, 2022 at 9:13 AM
    #235
    KroppDuster
    Bilstein 5100s
    Sorry. I should've have been clearer. The bumper ends are all paint matched on all models. I'm referring to the chrome on the upper trim SR5s which is in the middle of the bumper. Your truck seems to have black trim pieces that cover that chrome. See my pic below.
    Rwaters likes this.
  26. Jan 13, 2022 at 9:29 AM
    #236
    rideandfly
    Here's close up shots with one from underneath with tow hitch on right. Mine are black plastic:
    Here's the window sticker with standard & optional equipment, very basic 2WD SR5 Crewmax 5.5' bed, except for optional equipment on right side of page:
    Hope this helps
    Tundrastruck91 likes this.
  27. Jan 13, 2022 at 9:37 AM
    #237
    bigjuice
    WA State
    2024 Terra TRD Pro
    I’d keep it just like this also (as was previously suggested)
  28. Jan 13, 2022 at 9:39 AM
    #238
    KroppDuster
    Bilstein 5100s
    Very interesting. Thanks for going above & beyond with the up close pics. I'll to keep this on my "Explore this topic later" list when I get access to the technical manual and see. I'm not in love with chrome on the bumper & mustache, but I also don't despise it like others do.
  29. Jan 13, 2022 at 9:41 AM
    #239
    rideandfly
    DexterL & bigjuice, some of my ideas look good, but some don't!
    Thanks!
    bigjuice[QUOTED] likes this.
  30. Jan 13, 2022 at 4:59 PM
    #240
    Laffingas
    Laffingas New Member
    '22 Tundra Limited - Army Green
    My predator steps arrived at my dealer today, picking them up tomorrow afternoon. Is there a torque value for the bolts underneath, or just as tight as my ratchet will go? Should I use thread locker?
