Tundra tranny trouble
Discussion in '2nd Gen Tundras (2007-2013)' started by jim prahl, Jan 11, 2022.
  1. Jan 11, 2022 at 7:43 AM
    jim prahl
    jim prahl [OP] New Member
    jim
    08 tundra sr5
    the question i have is I parked my Tundra08 in the driveway Tuesday nite, didn't drive it on Wednesday then when i got in it Thursday afternoon. I started it but then it wouldn't go in reverse or forward. runs but won't move forward or backwards. why all of a sudden would this happen. Any ideas what the hell happen just sitting there?
  2. Jan 11, 2022 at 12:48 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Does the shift lever move or is it stuck? You have to be way, way, way more specific about your exact issue.
    If the shift lever doesn't move, that's unlikely to be a transmission problem.
    If the shift lever moves but the transmission doesn't respond at all, that's a whole different problem.
    If the shift lever moves and the transmission barely responds, that's normally what you'd expect from an actual transmission problem.
  3. Jan 11, 2022 at 5:43 PM
    jim prahl
    jim
    08 tundra sr5
    The shifter lever moves just fine but the transmission doesn't acknowledge it was put i gear. Motor runs just fine as well
  4. Jan 11, 2022 at 6:22 PM
    audiowize
    Paul B.
    This could be something simple like a linkage issue.
    If your transmission was OK one day and did this the next, I'd be looking for stuff external to the transmission not allowing it to work properly.
  5. Jan 11, 2022 at 6:25 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sounds electrical.
    landphil likes this.
  6. Jan 11, 2022 at 6:30 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Do the indicators lights changes as you shift?
    Does it make any difference if you are in D or S?
  7. Jan 11, 2022 at 6:35 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    This. And do the reverse lights work?
