New member + old truck + dead cylinder
Discussion in '1st Gen Tundras (2000-2006)' started by kirbotc, Oct 10, 2021.
  1. Nov 21, 2021 at 4:55 PM
    #121
    kirbotc
    kirbotc [OP] New Member
    2001 tundra
    Any chance this looks familiar to anybody?
    There’s a little bit of hack job looking wiring under the dash, and I’m starting to wonder if the problem isn’t down there….
    I’ve search around, and I don’t see anywhere for that big 24 pin connector to plug in.
  2. Nov 21, 2021 at 4:56 PM
    #122
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Oh boy the mess of an aftermarket alarm. Have you tried leaving the key on on and disconnecting the battery then reconnecting? Usually with aftermarket alarms this will prevent ignition cut from the box
  3. Nov 21, 2021 at 4:58 PM
    #123
    kirbotc
    2001 tundra
    Trying it right now
  4. Nov 21, 2021 at 5:01 PM
    #124
    kirbotc
    2001 tundra
    Didn’t seem to make a difference. Although I have so much of the harness disconnected right now, I’m not even 100% if it could crank….
    GUess I’ll go through and reconnect things
  5. Nov 21, 2021 at 5:18 PM
    #125
    This is literally exactly what went through my head when I saw the box...
    empty_lord[QUOTED] likes this.
  6. Nov 21, 2021 at 5:18 PM
    #126
    empty_lord
    05 rollover special
    90% sure that box is your problem... just from experience. multiple times
  7. Nov 21, 2021 at 5:22 PM
    #127
    kirbotc
    2001 tundra
    I'll bet you guys are right.
    I checked the starter relay fuse under the dash, and.... It's dead.
    I'll start looking through the wiring diagram again, but I feel like if the problem was on the engine side of the harness, that fuse would still be powering up.
  8. Nov 21, 2021 at 5:24 PM
    #128
    empty_lord
    05 rollover special
    those alarm boxes cut power to ignition when they trip the alarm
  9. Nov 21, 2021 at 5:25 PM
    #129
    That's my thought too.
    I used to install Avital, Clifford, DEI, and not many years before your truck was born. In fact, close to the date stamped on the underside of that black box. But that specific box doesn't look familiar to me, I can't nail the brand down.
    Best advice would be to untape the bundles and work your way back, connecting like-to-like, where possible.
    However, if you want to be more metered, gimme some shots of any identifying details. I'll see if I can dig something up.
    However, you may want to dig back thru EWD to see what wire colors you need to be hunting for in the IGN/starting circuits.
  10. Nov 21, 2021 at 5:26 PM
    #130
    kirbotc
    2001 tundra
    Hmmm.... Most everything else seems to be powering up though. Turning the key turns all the lights on, and even clicks the "pwr outlet" relay in the engine bay fuse box....
  11. Nov 21, 2021 at 5:28 PM
    #131
    Yeah, I don't necessarily think the alarm is 100% your problem here, but it's definitely something you want to un-fuck out of the system so you know it's not part of the problem.
  12. Nov 21, 2021 at 5:31 PM
    #132
    kirbotc
    2001 tundra
    Appreciate that offer. I'll head back out and start working on unhooking stuff. There's also some aftermarket speaker wires under there, just to confuse things even further. But the radio doesn't work anyway.... So anything that doesn't look factory can just come right out.
    And like you said, even if it's not the problem....
    I definitely don't wanna be driving it, feeling like there's a ticking time bomb of some old alarm waiting to shit the bed
    shifty`[QUOTED] likes this.
  13. Nov 21, 2021 at 6:41 PM
    #133
    kirbotc
    2001 tundra
    This is gonna be even more fun than I thought
  14. Nov 21, 2021 at 6:45 PM
    #134
    kirbotc
    2001 tundra
    Half of these wires aren’t even soldered or crimped. They’re held together with electrical tape and a hope
  15. Nov 21, 2021 at 7:00 PM
    #135
    Typical for fly-by-night shops and DIY'ers.
    Any chance you can pop the four screws off the bottom, take the top off and shoot a pic of the PCB? Looking for a specific model number on the PCB since everything is gone on the box. The oval sticker has a manf'er date to match what's stamped with the month/year circles embossed on the plastic, but the scratch-out, I can't make anything out of it.
    What's got me scratching my head is these two white molex plugs. Note, they cut the blue wire in half, then spliced in a section of white wire. But for what? FML, that's some Homer ass shit right there.
  16. Nov 21, 2021 at 7:01 PM
    #136
  17. Nov 21, 2021 at 7:13 PM
    #137
    myktundra
    myktundra New Member
    2011 Tundra DC TRD SAP
    what a mess! I used to install stereos and alarms too. In all honesty pulling shitty wiring and putting things back to stock is so satisfying these days for me. When I got my tundra it had some sort of alarm/ignition kill. It wasnt working anyway and not giving me any problems but it came straight out! lol
  18. Nov 21, 2021 at 7:36 PM
    #138
    kirbotc
    2001 tundra
    Well, so it looks like the whole alarm must have been partially removed/bypassed already. When I started yanking wires, it didn’t look like the factory harness was really cut any where and there was a lot of shit unplugged.
    There’s maybe 2 or 3 wires that I’ll need to spend a little more time figuring out. Small plugs under the dash with nothing in them…. Two wires into the factory harness that don’t go anywhere…
    That white splice wasn’t the weirdest thing I saw…. I’ve got wires into the headliner running out into the engine bay and things I can’t make any sense out of…
    But I just cut out anything that didn’t look factory, and right now I’m still where I started.
    Turning the key clicks, but no power to the starter relay.
  19. Nov 21, 2021 at 7:42 PM
    #139
    empty_lord
    05 rollover special
    the wires going to the engine bay are likely going to an ignition coil or a loud speaker for the alarm
  20. Nov 22, 2021 at 12:03 PM
    #140
    That's one hell of a pile. I can't tell you what that box is, but if I had to guess, the green Rayex box on the corner is a relay, as are the 4 Siemens controllers if I'm not mistaken. The dip switches are typically what you'd use to configure the modules or alarm brain to suit the install. The fact there's only 4 makes me think this is a secondary or add-on module, full-on brains would have 10+ at least. Has me wondering if this add-on unit isn't a remote-start module, which is why it remained semi-wired.
    That's my guess on this: The larger 24-pin connector went to the alarm brain, removed before you purchased. This smaller black box you just disassembled was a remote start add-on, and was left intact to avoid interrupting the starter wiring.
    Given some of the corrosion I'm seeing on the corner of that board by C16, which I think is a ceramic cap, maybe it got wet at one point and shorted?
    Again, you got me on this one.
    Punk1974 likes this.
  21. Jan 11, 2022 at 12:54 PM
    #141
    kirbotc
    2001 tundra
    Just a quick update for anyone playing along, I haven’t died, or given up…
    But, working for UPS, the last couple months have been more than a little hectic. Now that I’m back to a 5 day work week, plus a little more opportunity for taking random days off, I’m gonna dive into it again.
    I just finished rearranging my garage and I have just enough space to pull the truck all the way in and close the door. And I’ve got a big propane heater out there now.
    The plan is to have it up and running, with new wheels, tires, suspension, bodywork and brakes by the summer. And road trip down to GA to bring home a small 5th wheel camper I bought from a buddy down there.
    So hopefully I’ll have a real update soon
    Sirfive, w666, bmf4069 and 2 others like this.
  22. Jan 11, 2022 at 5:30 PM
    #142
    Awesome! I've plugged you a couple of times recently and meant to come here and post for updates but forgot. Got my own damn problems :D
    Whereabouts in GA you planning to head, if I may ask? We've got a few members here.
  23. Jan 16, 2022 at 7:02 PM
    #143
    kirbotc
    2001 tundra
    Oh it’s way down there, not far across the border from Jacksonville.
    Wasn’t looking for another project any time soon, but a buddy of mine was selling it, and he needed the money. So here I am…
    As the tundra…. Anybody recognize these two wires? There the only real leftovers after I pulled out the remote start/alarm or whatever exactly it was.
    Didn’t get much of a chance to mess with it over the weekend, but I did spend a little time poking around and remembering exactly how I left it…
  24. Jan 16, 2022 at 7:29 PM
    #144
    @kirbotc can you confirm the colors on those are purple or violet w/white stripe and black with yellow stripe?
  25. Jan 16, 2022 at 7:31 PM
    #145
    kirbotc
    2001 tundra
    Yup, correct on both.
  26. Jan 16, 2022 at 7:33 PM
    #146
    I do have some 'open' (unplugged) connectors in my truck. That single conductor black/yellow is interesting to me I'm less concerned about tht one, more worried about the purple/white. Have you consulted the electrical wiring diagram (EWD) for your year?
  27. Jan 16, 2022 at 7:34 PM
    #147
    kirbotc
    2001 tundra
    I have not yet.... I'll pull that up on lunch break tomorrow and start searching for it
  28. Jan 17, 2022 at 9:46 AM
    #148
    bmf4069 likes this.
  29. Jan 17, 2022 at 10:01 AM
    #149
    Violet-white appears to possibly be the airbag detection? (1st pic)
    Black-yellow is used in a few places, including a relay for the VSS and stuff in the cluster, "VTA" related to throttle position, tees off fuse block "10A GAUGE", and also from ECU to "Center and ignition coil No. 3" (of 8), and an EFI relay, at least.
    Search the EWD for B-Y and V-W, I believe that's how I found.
  30. Jan 17, 2022 at 5:07 PM
    #150
    kirbotc
    2001 tundra
    Hmm, a few of the dash gauges don't work. So that might be part of it...
    Doesn't sound like any of those are causing my main issue though.
    Thanks so much for finding that though. Every time I start searching through wiring diagrams my eyes start glazing over.
    shifty` likes this.
