Rear Diff Whine
Discussion in '1st Gen Tundras (2000-2006)' started by bmwahba, Dec 31, 2021.
  1. Dec 31, 2021 at 4:14 AM
    bmwahba
    bmwahba [OP] New Member
    My rear diff is making some gear whine and was wondering if theres a recommended fluid I could put in there that is heavier than the DINO 90 that's recommended in the manual to quiet it down.
    Otherwise, does anyone have a good and used 3.91 rear LSD for 06 double cab that I could buy? I need to get rid of this noise! Driving me crazy!
    I'm in Central Florida in case anyone has a rear diff they could sell me.
  2. Dec 31, 2021 at 5:23 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    FrenchToasty and w666 like this.
  3. Dec 31, 2021 at 5:29 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Have you tried changing fluid to see if it helps? Sure fluid level is correct? A full synthetic change with the LSD additives would be place to start.
  4. Dec 31, 2021 at 5:58 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    So you run this without adding friction modifier? I recently changed my oil from whatever was in it when I bought the truck to Mobil 1 75W-90 with LSD (I have the factory 3.91 LSD rear). Now I'm noticing a crunching/grinding sound sometimes when I accelerate hard from a stop while turning (like at a stoplight, let's say). I am hearing that our Tundras don't like synthetic gear lube, although I have run it in my Land Cruiser and 4Runner for years without complaint. I guess I'll give it a try!
  5. Dec 31, 2021 at 6:05 AM
    des2mtn
    Shady Grove
    Tonto cover
    Yes, I've drain and filled my rear diff twice with this, no extra modifiers (I have a factory 4.10 LSD). Truck hasn't complained at all -- no whining, grinding, etc.
    w666[QUOTED] likes this.
  6. Dec 31, 2021 at 6:10 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I've used redline full synthetic for years and no issues. Has the friction modifier for LSD in it, so no additional additives needed
    Riverdale21 and w666 like this.
  7. Dec 31, 2021 at 8:39 AM
    bmwahba
    Just swapped the fluid out with the Lucas 80-90, and still same noise. When pulling the drain plug, there were some accumulated metal shavings. Little bit of thicker sludge in the oil it seemed. But the sound remains.... so i need some help.
    I am curious if it could be anything else? It's definitely gear related, as I can hear it when the truck downshifts for example it picks up speed/frequency in noise.
    It is most prevalent at 50-60mph, then after 60mph it quiets down.
    Not sure if the transfer case or the front diff would be making this whine while it's being driven normally in 2wd.
  8. Dec 31, 2021 at 8:59 AM
    des2mtn
    Shady Grove
    Tonto cover
    Does the noise disappear when it's in 4WD? If that's the case, it could indicate that the needle bearing on the driver's side of the front differential is worn out.
    There's a dedicated thread on that needle bearing and an upgrade for it. Others have reported driveline voodoo that goes away in 4WD... https://www.tundras.com/threads/ecgs-bushing-tool.59664/#post-1563580
    Regarding sludge and oil shavings, the drain plug has a magnet on it so stuff accumulating is by design. Here's what mine looked like when I DIY'ed at 150K, dealer had done it previously at 75K.
  9. Dec 31, 2021 at 9:01 AM
    bmwahba
    It's in 2wd mode doing the whine. Not 4wd dependent.
  10. Dec 31, 2021 at 9:04 AM
    des2mtn
    Shady Grove
    Tonto cover
    If you can't recreate the whine while in 4WD then I'd wager it's the needle bearing.
  11. Dec 31, 2021 at 9:10 AM
    bmwahba
    Shoot let me give that a try today....standby..
  12. Jan 1, 2022 at 8:54 AM
    bmwahba
    Ok... sound is the same in 4wd as it is in 2wd.....
  13. Jan 1, 2022 at 12:41 PM
    bmwahba
    Anyone parting a 4wd DC that I could steal a diff off of? This sucks!
  14. Jan 4, 2022 at 3:23 AM
    bmwahba
  15. Jan 4, 2022 at 3:47 AM
    w666
    Maryland
  16. Jan 4, 2022 at 3:58 AM
    bmwahba
    Yeah or core charge for +600 but not sure if it’s LSD or not, doesn’t really specify. I’ll call and check
  17. Jan 4, 2022 at 4:03 AM
    w666
    Maryland
    There's another thread on here somewhere that describes the different types LSDs, Lockers, eLockers, et al. I didn't really take the time to digest it all because my tiny brain is already pretty full. I only made a mental note for future reference...when my time comes I'll want to replace it with stock.
  18. Jan 4, 2022 at 7:43 AM
    bmwahba
    Ok, called them up. For the base $750 price it's basically just an open diff.
    Now I need to decide if I want to spend the extra $500 for the TrueTrack upgrade....pretty spendy now.
    My ideal would be to find a verified good working order used diff for now! Anyone got any leads on a part out anywhere that would work for me?
  19. Jan 4, 2022 at 9:03 AM
    w666
    Maryland
    Did you ask how much/how long to rebuild yours?
  20. Jan 4, 2022 at 9:06 AM
    bmwahba
    Yep, $1300 for the local shop to rebuild.
  21. Jan 7, 2022 at 7:07 PM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I used that Mobil 1 and continued to have the shudder from stop. I added two tubes of friction modifier over 12000 miles. Shudder from stop started again 2500after the second change. Recently changed to amsoil fluid. So far it’s been great, but quite spendy. I tow a ton though so probably a harsher use case than most.
  22. Jan 7, 2022 at 7:19 PM
    I though double cabs all had the 3.91 gears? Maybe I’m mistaken
  23. Jan 7, 2022 at 7:24 PM
    he’s got that O4. Insert unicorn emoji
    des2mtn and FrenchToasty[QUOTED] like this.
  24. Jan 7, 2022 at 7:30 PM
    I was testing you…… hahah thanks
  25. Jan 7, 2022 at 7:46 PM
    no worries, I made the opposite mistake in another thread thinking they all had 4.10’s. But see, I’m learning!
  26. Jan 7, 2022 at 8:29 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    And it’s not a wheel bearing?
